pinstripe?
slowtrot
City/Region: dawsonville
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Dabbler
PostPosted: Thu Feb 20, 2014 5:58 am    Post subject: pinstripe? Reply with quote
I will have to repaint the bottom of my new used 19. The hull has a nice small approx 1/4 inch pinstripe just above the paint line. When I pressure washed the boat pieces of that pinstripe went by by. Question: is the pinstripe paint or applied tape and was it put on at the factory. Anyone know the standard practice?
slowtrot
PostPosted: Thu Feb 20, 2014 7:39 am    Post subject: Reply with quote
Could be either but probably tape and that's the easiest re application.
C-batical
City/Region: Pinckney
Vessel Name: C-Batical
Photos: C-Batical
PostPosted: Thu Feb 20, 2014 8:49 am    Post subject: Pinstripe? Reply with quote
It is 1/4 inch tape. Depending on the color, most large automobile parts and accessory stores carry it. I think I got my last roll at Autozone. I have also purchased some online.
Rollie/C-Batical
Pinckney, MI
slowtrot
PostPosted: Thu Feb 20, 2014 1:05 pm    Post subject: Reply with quote
I love this place. Cause somebody knows.
Slowtrot
PostPosted: Thu Feb 20, 2014 8:00 pm    Post subject: Reply with quote
Tape. Like what they use on cars.
PostPosted: Fri Feb 21, 2014 3:27 am    Post subject: Reply with quote
Tape -- yes. Factory ...ahh most likely not, but not impossible, just not gel coat or paint.
Have considered doing that because I like the look, but have not done it for the very reason you are asking now.
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Fri Feb 21, 2014 8:46 am    Post subject: Reply with quote
We had 2 stripes around the cabin top of our Venture that were badly worn, to the point they ceased to exist in some areas and seemed weather burned in others. After puttering with the material I determined it was tape and not paint. I then found some marine grade 1/4 inch vinyl and retaped the area 1 year ago. It still looks like new and the job only took about 10 minutes. We are very happy with it. We actually changed the color from the original and used a dusty silver color that has a subtle biege tint to it in the sun. There are a lot of color choices though. It was hard to see the real colors on the computer screen so I called the company and they were happy to send me a color pamphlet at no charge. The minimum tape length available is 150 feet so there is more than enough to work with. I bought from a company named Stripeman:
http://www.stripeman.com/mm5/merchant.mvc?Screen=PROD&Store_Code=Graphics&Product_Code=00035-Pin-Stripe-pinstripe-Tape-Vinyl&Category_Code=Boat
With this said, I have no idea how well it will work for a waterline. Maybe the company can speculate in this regard?
Rob
PostPosted: Fri Feb 21, 2014 9:37 am    Post subject: Reply with quote
Since were on this topic, this tool makes taking them off much easier. Just watch your rpm's so you dont' burn the gelcoat/paint.
http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_Z7_RJH9U5230GE3E02LECIE20S4K7000000_nid=BZVN4V5PK4beRJ5GMFSMV0gl
Page generation time: 0.0354s (PHP: 66% - SQL: 34%) - SQL queries: 25 - GZIP disabled - Debug on
