cleaning the outside of the door
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue Feb 18, 2014 1:48 pm    Post subject: cleaning the outside of the door Reply with quote
The cockpit side of the door in my 1996 22' has gotten some mildew on it from sitting all winter covered. Anyone have a miracle cure to remove the mildew. I had some fiberglass cleaner sitting nearby and tried that but it didn't phase it. Somewhat afraid to try a clorox solution.
PostPosted: Tue Feb 18, 2014 1:54 pm    Post subject: Reply with quote
What material was used to construct the door on that model year? If it is made of white starboard, then softscrub with bleach works great. If it's one of the older style (with the vinyl like woodgrain), I'm not sure what to recommend but others will know.
Spike
City/Region: Kent
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
PostPosted: Tue Feb 18, 2014 3:37 pm    Post subject: Reply with quote
Try Simple green Try it undiluted. Good stuff.
Chuck
Bootleg Hooch
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Feb 18, 2014 3:48 pm    Post subject: Reply with quote
Any product you use requires a certain amount of contact time that is the time the item being treated remains wet with the disinfectant (cleaning agent) to be effective. This should be on the product insert or instructions for use and might require multiple treatments and elbow grease.
You need to be careful using bleach. It can damage fabrics and dont mix bleach with ammonia.
Brent Barrett
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Feb 18, 2014 5:56 pm    Post subject: Reply with quote
The miracle cure for us is Mr. Clean magic erasers. They really do seem to work magic getting the dirt and grime out of that textured starboard with minimal effort. I use them all over the interior surfaces of the boat as well.
lloyds
PostPosted: Tue Feb 18, 2014 6:22 pm    Post subject: Reply with quote
On my boat it is, I believe, the starboard material. It isn't the vinyl. I will try the simple green first and see what happens. Never have tried the magic erasers, but that will be next, if necessary, thanks.
Chester
City/Region: home
Photos: Chester
PostPosted: Tue Feb 18, 2014 8:16 pm    Post subject: Reply with quote
X2 on the magic eraser for starboard.
Page generation time: 0.0336s (PHP: 60% - SQL: 40%) - SQL queries: 20 - GZIP disabled - Debug on
