Posted: Thu Dec 12, 2013 12:26 pm Post subject: ResQ Disc |
What do you all think? Cheap. Somewhat effective. Small. Light weight. Simple. Re-usable....
http://www.water-rescues.com/index.html _________________ "We can go over there...behind the 'little one'....."
Joined: 02 Nov 2003 Posts: 20841 City/Region: Pensacola
Posted: Thu Dec 12, 2013 3:44 pm Post subject: |
Looks pretty good. Cost $80. I still feel for a boat the Life Sling is a better choice for about $160 for the Life Sling 2, because it gives you floatation, and a way to get a person aboard. There is also the Scotty throwing bag for $25. _________________ Bob Austin
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Thu Dec 12, 2013 4:34 pm Post subject: |
I don't know about the disk, but I do know that unless it is CG approved it will not meet the requirement for a throwable. The always figured the Lifesling I have in the cockpit was good until I was inspected by the CG last time. Fortunately I had an old cushion with the approved label hidden away in a cubby hole. I had to dig it out to be legal. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Posted: Thu Dec 12, 2013 9:46 pm Post subject: Q |
Life Sling 2 is US CG approved type IV device--and should have the label in the unit. The older Type Life Sling is not CG approved. Canada I have a question about. We sailed in Canadian waters for a number of years with a Life Sling 2 aboard. We were boarded by CG Canada, and no problem with the "life Sling 2" However in the past Transport canada required the traditional Ring Buoy
Current ISAF OFFSHORE SPECIAL REGULATIONS
Canadian Yachting Association Prescriptions
JANUARY 2012 - DECEMBER 2013 states the following: "here CYA prescriptions specify items meeting Canadian laws, in some cases Transport Canada permits visiting yachts to use equipment that complies
with the laws of the country in which the yacht is usually
kept....CYA prescribes that where the word "Lifesling" is used it shall be read as the "Lifesling or functional equivalent". CYA prescribes that the lifebuoy in OSR 4.22.1 a) above shall be a Lifesling."
Transport Canada safe boating guide notes that for our size boat:
"2. One (1) buoyant heaving line at least 15 m (49’3”) long
OR
One (1) lifebuoy attached to a buoyant line at least 15 m (49’3”) long
3. *One (1) reboarding device" (The reboarding device is required if the gunnel is over 1" 8" from the water).
Current Transport Canada web site states: "Lifebuoys
When buying a lifebuoy look for a Transport Canada approval sticker. Store this piece of equipment where it can be easily accessed in an emergency. Lifebuoys must be at least 610 mm (24 inches) in diameter. Smaller lifebuoys and horseshoe-type devices are not approved."
So it sounds to me to be proper in Canada, that the ResQ disc would count as the needed device. (although it would not in the US, since there is no requirement for a floating line.) |
Posted: Fri Dec 13, 2013 12:47 pm Post subject: |
Even if it does not count as approved, it does look to be very functional. Better throwing range than a throw cushion.
I carry a "Mustang Throw Stick" ( actually Mustang Survival Rescue Stick), to have something with better throw range, but it does not have the retrieve line that the throw cushion does.
http://www.mustangsurvival.com/recreational/mustang-survival-rescue-stick-0?country=25
>Can be thrown accurately 100 feet or further
>Automatically inflates in seconds when immersed in water providing rapid emergency flotation
>Offers 35lb of buoyancy - twice the flotation of a typical life jacket
>Easy to repack and reuse - insert a new bobbin and screw in the replacement handle containing
Good options, all things we would like to have on board and hope to never need.
SleepyC
