Mechanical Help Needed! Any thoughts would be appreciated.
Sundog
Vessel Name: SUNDOG
Photos: Sundog
PostPosted: Tue Jun 21, 2005 8:25 pm    Post subject: Mechanical Help Needed! Any thoughts would be appreciated. Reply with quote
Hello, I thought maybe someone here has run into this before and would be able to help me out.
Here is my problem (not my only as my friends will point out!)
My Port engine is occasionally not starting. When I turn the key I get the normal whistle saying it is ready and then when I go to turn the key the rest of the way to make ignition happen I get nothing, no noise or sound like the starter is not working or anything. It only happens occasionally, It does not seem to be related to having it correctly in Neutral as I play with this and it does not seem to fix it - but if I wait a little bit it works fine - but with out any rhyme or reason to why.
The thoughts I had are
Bad Cellonoid
Bad Starter
Maybe even related to heat as if I wait a little bit it starts fine.
The motors run great and once the problem alleviates itself they start right up an purr.
They are 2 Stroke Tohatsu 50 stroke motors
Any thoughts would be appreciated, I am hoping to get out to the Naked I. adventure - Lord Willing and Weather willing.
Here are the pics from my Fathers Day Trip: http://www.alaskaphotography.com/2005trips/fathersday/
Thanks in advance for any advice - I am a rookie mechanic
Cheers,
Joe with the Sundog
Hot
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Jun 21, 2005 9:11 pm    Post subject: Reply with quote
Joe,
I would start by cleaning the battery terminals and clamps and also cleaning and tightening where the cables are attached on the starter solenoid and the ground stud or bolt.
Also check the connections where the cable from the key switch connects to the powerhead wiring harness. Any loose or corroded bullet or spade connectors should be cleaned and tightened.
I hope this helps!
Larry H
A C-Brat since Nov 1, 2003
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Tue Jun 21, 2005 9:28 pm    Post subject: Reply with quote
Larry posted excellent advice!
If you have a voltmeter you can try checking the voltage at the solenoid on the motor next time you are having problems to make sure it is getting power. Also check the battery voltage with the key in the start position to see if it is having any drain put on it. If not we know it is a bad connection somewhere!
You can also try jumping the solenoid to see if the motor turns over. If it does the problem is likely between the motor and the key.
I hate intermittent electrical problems! But more than likely this is simply a corroded battery terminal.
Gary Johnson
KB7NFG
Page generation time: 0.0429s (PHP: 58% - SQL: 42%) - SQL queries: 16 - GZIP disabled - Debug on
