Stainless Steel Prop
PostPosted: Tue Nov 05, 2013 7:21 pm    Post subject: Stainless Steel Prop Reply with quote
Just in case any one is interested, before I just about give my prop away on ebay, if you are looking for one, you can bid on my old one here.
http://www.ebay.com/itm/200983006729?item=200983006729&=&sspagename=ADME:L:LCA:MOTORS:1123&vxp=mtr
Colby
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Thu Nov 07, 2013 12:17 am    Post subject: Reply with quote
Colby..........
You need to run in deeper water.
Jack
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
PostPosted: Thu Nov 07, 2013 10:13 am    Post subject: Reply with quote
I run in Lake Michigan also, but still prefer the aluminum... Smile
DuckDogTitus
City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
PostPosted: Thu Nov 07, 2013 10:21 am    Post subject: Reply with quote
I'm a neophyte to this, what is the benefit to aluminum over stainless?
Dustin
PostPosted: Thu Nov 07, 2013 10:26 am    Post subject: Reply with quote
Dustin, stainless steel is much stronger than aluminum. But it's also much heavier. Line of thought is if you hit something with your prop, you would rather have the prop break, than your driveshaft, so aluminum is better in that case. However, you can still suffer shaft damage with an aluminum prop hit. I've heard some say that they feel the SS performs better. I have not witnessed that on either my CD-22, or on my prior Searay 268 Sundancer. (26' heavy cabin cruiser). Aluminum is cheaper and easier to repair. SS maintains it's shape better. As far as my experience goes, the only advantage I've seen to SS, is it's strength. But I've never had a problem with Aluminum's performance, and I prefer it's weight and cost advantages. Colby
PostPosted: Thu Nov 07, 2013 11:17 am    Post subject: Reply with quote
DuckDogTitus wrote:
colbysmith wrote:
I run in Lake Michigan also, but still prefer the aluminum... :-)
I have run both--currently aluminum on the 22 and SS on the Caracal. The SS will not scar up and often does not show dings which the Al will show--especially running in sandy or muddy waters.
If you hit something really big/unmovable the aluminum will also bend the prop shaft or even damage the gears--so there is no guarantee that an al prop will protect the shaft--but in general it is believed to do that.
The SS prop does not deflect or "bend" as much under load. The SS prop will often be faster--but that depends on the boat, load and many other conditions, including the design of the prop. The SS can be made with thinner blades--and thus less resistance--especially in a high speed or racing boat.
I am going to make a generalization--and that can be "dangerous"--but generally the more specialized props are SS, and the stock props are Al. For example I don't need anything special on the 2, but the Caracal, being a single engine cat--needs some special requirements--more cup, 4 blades, and a bit more rake than stock aluminum props provide.
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
PostPosted: Thu Nov 07, 2013 11:24 am    Post subject: Reply with quote
interesting, sorry to hijack your thread colby, but thanks for the info guys Beer
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Nov 07, 2013 12:53 pm    Post subject: Stainless Steel Prop Reply with quote
We normally have a stainless prop on as we tend to be in shallow areas sometimes that get shoaled up with sand and mud i.e. New Jersey and Florida. When we travel to rocky areas like Maine we put on the aluminum prop.
D.D.
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Thu Nov 07, 2013 1:53 pm    Post subject: Reply with quote
Ive run both SS and aluminum, but prefer aluminum now. The weight difference is really substantial on the ones Ive compared.
When docking with a heavy stainless prop I was concerned about going from forward to reverse too quickly, not letting the prop slow down enough. My theory was the extra weight had alot more momentum and could damage the lower unit. I have no idea if that is true or not as the lower unit was never damaged. I guess its a good idea to be concious of that with either type of prop, although thats not on my mind when im white knuckling the helm in a more challenging docking situation.
A big advantage I found with aluminum props is if you damage them in the field, you can fix them easy with a hammer, some J.B. weld and sandpaper if its not chewed up too bad. On the other hand, a stainless prop may not show any damage from the same mistake made in the boat.
Page generation time: 0.0419s (PHP: 64% - SQL: 36%) - SQL queries: 26 - GZIP disabled - Debug on
