Ray
Joined: 13 Dec 2011 Posts: 271 City/Region: Pamlico River
Vessel Name: Seaweed
Photos: Seaweed
Posted: Mon Oct 21, 2013 6:48 pm Post subject: PROJECT-A-PALOOSA!!! -- Air Conditioner |
Hey all,
So I had a 'few things' that I wanted to get done over this past winter. Well here it is OCTOBER and, finally, most of them are done. Its a big list.
Over the next few months, I'll collect the pictures and post one project at a time with (hopefully clear) descriptions.
Here's one to start...
This was my take on the venerable C-Dory air conditioner install.
I used a $89.00 special, 5000BTU unit from Wal-Mart. Nothing special so it could be easily replaced when (not if) the salt water got to it.
The first task was to make some “feet” for the bottom. I cut some notches in the feet so that it would sit in position within the window frame. The feet are epoxy-coated and glued to the bottom of the AC unit with 5200 in a carefully (2hrs of cussing and growling) measured position. Also cut to the stupid shape of the bottom of the AC pan.
Here are the feet hooked into position on the window frame.
The backs of the "feet" are cut so that they sit on the hinges of the hatch. They are cut down so that they cause the AC to angle back for good water drainage. They are just high enough, though, to keep the AC off of the lexan.
Here’s the outside view
Next we started measuring for a “sock” to try to seal up the air hole as best we could
Lisa made the sock to have the exact rectangular opening of the AC unit on one end, and the measured outer window frame on the outer edge.
I used thin aluminum strips and VERY short sheet metal screws to fasten the "sock" to the AC unit. The outer edge has 1/4" bungee cord in a hem and one of those squeeze cinch thingies.
I used a kayak "bungee button" (http://kayakfishinggear.com/bungeebutton.aspx) at each corner of the window frame. We hook the bungied hem of the sock over the four corners and it holds everything up to the window frame. These things are VERY useful for all kinds of stuff, BTW, I use them for everything!
I installed a dedicated AC outlet right next to where the AC cord would be coming out.
…..and then cut the cord off of the AC unit to just the right length. It was easier to do from inside the AC unit than messing with the breaker-plug. I cut off about 2ft from the pigtail and had to put some new push-on crimp connectors on the 3 wires.
So here is the "in use". Kind of a cheezy '70's-look with the fluffy opening cover. Standing in front of the cool breeze, it may just grow on me…..
Lisa also made a nifty stow/carry bag with a semi-rigid rubberized bottom for schlepping the thing around the boat. The towel can absorb any extra condensation drainage.
What I didn’t take a picture of is a hole I drilled in the bottom of the pan all the way at the very back corner.
Some of the AC units have the rear fan sitting in the condensate on purpose and they sprinkle cooling water onto the coils as they spin. This was a bit of a problem as there would be a quart or so of water in there at any time when you were trying the take the unit it.
I gave up on this extra feature and put the hole in where I thought it would drain out quickly and not leave much water in the pan. If you do this, BE CAREFUL drilling into the pan until you know what is behind it!!! I nearly nicked a freon tube in the process
I coated the freshly-drilled metal edges with epoxy, but I'll have to keep a close eye on it for rust, as dripping, rusty water would not be good for the bow deck.
Hope this is of use to some! All photos are in my album with abbreviated descriptions.
Best,
Ray |
Posted: Mon Oct 21, 2013 8:37 pm Post subject: |
Nice job! Looks pretty good. I haven't seen such a clean install of a window AC in a C-dory before. _________________ Roger on Meant to be |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Mon Oct 21, 2013 11:06 pm Post subject: |
I like the idea of the legs and the carry bag. We just use a piece of 2x4 on the deck to support the outside edge of the air conditioner. We also use pool noodles/ and the foam for insulating water pipes on the rim of the window to protect it. You system is much better. _________________ Bob Austin
Discovery
Joined: 08 Dec 2003 Posts: 1245 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Bill K
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
Posted: Tue Oct 22, 2013 4:40 am Post subject: |
It looks like the AC is carried in the bag on it's back.
After install it should not be run until the oil has a chance to drain back into the crankcase.
Bill Kelleher _________________ KA8BFT |
Ray
Photos: Seaweed
Posted: Tue Oct 22, 2013 7:47 am Post subject: |
Nice setup, Brent! I like the grate over the rear of the AC.
Thanks for the tip, Bill! |
DuckDogTitus
Joined: 31 Jan 2013 Posts: 1034 City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
Posted: Tue Oct 22, 2013 10:25 am Post subject: Re: PROJECT-A-PALOOSA!!! -- Air Conditioner |
Ray wrote: |
I usually gravitate to very hot weather but the way you have yours set up looks pretty cozy to me. Pretty nice looking.  _________________ Dustin |
Posted: Tue Oct 22, 2013 12:55 pm Post subject: |
Very good point about the compressor oil--we always keep ours "bottom down". |
