Paint the trim tabs ?
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Mon Oct 07, 2013 3:18 pm    Post subject: Paint the trim tabs ? Reply with quote
In one of the photo albums I saw the owner has anti-foul painted the trim tabs. I have never seen or heard of this before. Anyone have an opinion ?
Martin.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Mon Oct 07, 2013 4:00 pm    Post subject: Reply with quote
From my ocean marina days, the gunk grows on anything submerged. I'd bottom paint the tabs if I had my boat in seawater.
Testosterone Tales-Amazon.com
KG7RC
ddenver
City/Region: Quilcene
Vessel Name: C-Renity
PostPosted: Mon Oct 07, 2013 6:57 pm    Post subject: Reply with quote
Not sure if its standard procedure or not but they painted our trim tabs when we had the bottom paint applied. It seems to have helped, pulled it out earlier this month after being in the marina for 5 months (the longest we have ever left it in) and pretty darn clean.
Gotta figure out how to deal w/ the remaining little white barnacle rings left on the sonar transducer though as I mentioned in another thread. Any suggestions?
Dan, Tanya, and Hannah on C-Renity
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Mon Oct 07, 2013 7:39 pm    Post subject: Reply with quote
Tabs being aluminum, need priming and surface prep for bottom paint for aluminum. In Canada we use Interlux Trilux II. I generally keep tabs and rams coated with wax. Collinite paste same as on hull. To do the tabs in paint is quite pricey to do it well. Clean, etch, prime, paint etc. Transducers can be waxed with good results. Just wipe them regularly. I avoid that by bonding the t'ducer inside up forward. George
PostPosted: Mon Oct 07, 2013 7:58 pm    Post subject: Reply with quote
I have owned Lenco, Banett, and Boat Leveler Trim tabs--all were Stainless steel. I have primed SS with epoxy and then used the same paint that is on the rest of the bottom.
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Mon Oct 07, 2013 8:19 pm    Post subject: Reply with quote
After 4 years of failed coatings- I found one that works in here in Florida.
Apply Pettit 6455 primer (West Marine carries it) to your shiny, clean stainless steel tabs
Apply Pettit 6627 "Tie Coat" (like a liquid rubber stuff) to bond the primer to the bottom paint
Apply your bottom paint (I used Pettit Vivid white) to the tie coat.
Don't forget you need zincs on your tabs.
ghone
C-Dory Year: 2011
Photos: Kerri On
PostPosted: Mon Oct 07, 2013 8:32 pm    Post subject: Reply with quote
My error Bob. You're correct. I wanted to say treat tabs much like you would aluminum. Cleaning and etching for epoxy primers then paint. Bennet web site has a good FAQ section. Keeping zincs in contact with bare tabs for protection is important. I tried something this season where I used Aquaguard. A new water based anti fouling on the tabs and did the zincs ever get eaten up fast. Something went on that had the zincs going to paste in 6 weeks. I pulled the boat and sanded all that paint off and applied wax. For spring we'll be refreshing the bottom paint and using Micron CSC on bottom and tabs. I found in summer the tabs want scrubbing every month or so if waxed.
PostPosted: Mon Oct 07, 2013 8:47 pm    Post subject: Reply with quote
Good points--and using a "system" (even though each paint manufacture has similar coatings), is the best way to go, with special surfaces. Running gear of any sort is always a problem--especially high speed props, as found in inboard power boats is always a problem. I suspect I have tried a dozen or more systems--from baby diaper rash products to several two part applications on running gear...Some of the new stuff works, and some doesn't as George found out--no way of knowing until you try it...
PostPosted: Mon Oct 07, 2013 9:26 pm    Post subject: Reply with quote
Another vote for painting the trim tabs. We use Micron CSC Extra - stays effective even when on the trailer and dunked back in.
Since those trim tabs stand out from the hull, they get some sun that contributes to the slime growth. The ablative paint makes it easy to wipe/scrub that slime off.
http://captnjim.blogspot.com/
PeterQ
City/Region: Annapolis & Mt Victoria
State or Province: MD
C-Dory Year: 2013
Vessel Name: Sea Wings
Photos: Sea Wings
PostPosted: Mon Oct 07, 2013 10:59 pm    Post subject: Reply with quote
Mine are painted with Petit Multiseason ablative just like the rest of the bottom and they clean up easily with a hose and brush..
Peter Nyce III
Aviator & Lifelong Boater
2013 C-Dory 25 Cruiser
Hurricane SD191
Hobie Wave
Each day is a gift - especially if it's spent on the water!
Alexander
City/Region: Stuart
Vessel Name: Alexander
Photos: Alexander
PostPosted: Tue Oct 08, 2013 1:19 pm    Post subject: Reply with quote
Anybody ever tried the spray on zinc coating (cold galvanizing) that some of the big boat guys are using on their running gear these days? I've never used it but some of my trawler friends swear by it for growth prevention.
PvL
City/Region: Sunshine Coast
Vessel Name: Lately
Photos: Latley
PostPosted: Sat Mar 18, 2023 10:19 pm    Post subject: Anti Fouling Trim Tabs Reply with quote
Is there anything new on the anti-fouling trim tabs front? In the past I have attempted to sand, prime and apply Micron CSC. This system kept the fouling at bay but washed off when I did my winter clean up. Since then, I have applied baby zinc which helps but I still get some growth. We keep our boat in the water from April to October.
In an earlier post Alexander inquired about spray on zinc coating ... Tue Oct 08, 2013 1:19 pm
Has anyone used zinc spray? https://www.go2marine.com/SEAGUARD-ZINGA-ZINCSPRAY
Thanks....PvL
PvL
PostPosted: Sun Mar 19, 2023 12:46 pm    Post subject: Reply with quote
I reviewed the subject on Trawler Forum over the last 15 years threads. Propspeed is the most preferred product. It must be put on exactly as per directions and is not cheap. It helps, but if in high fouling waters, such as the keys in Fl. there still can be some growth.
There is Pettit Prop Coat Barnacle Barrier, both spray cans and brush on. Pettit also makes a zinc spray prop coat. This does not seem to be as effective as Propspeed.
The Zinc spray (can be cheap zinc coatings, as well as specifically for running gear,) seems to help some in the cooler waters such as PNW. Rustoleum has a product which is 93% elemental zinc and is less than $10 a spray can at big box hardware stores.
I have been happy with two part epoxy and then hard antifouling over it for the trim tabs. I have also used it on slow turning large props as on my "motorsailers).
PvL
Vessel Name: Lately
Photos: Latley
PostPosted: Sun Mar 19, 2023 9:52 pm    Post subject: trim tab anti fouling Reply with quote
Thanks Dr. Bob. As always, your practical nautical expertise shines through.
I am going to try to locate some of the Pettit Prop Coat Barnacle Barrier, and use it this season. If not, I will try some low-cost high zinc hardware paint.
Will there be problems if I use the zinc paint on my transducer and outboard clamping brackets?
Thanks, PvL
Karl Konecny
City/Region: Glide
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
PostPosted: Thu Mar 23, 2023 11:44 am    Post subject: Reply with quote
Last year I used Pettit Prop Coat Barnacle Barrier and it worked well although has already worn through in some areas of the trim tabs so I will add another coat this year. Which Collinite wax did you use on the transducer? Does it prevent barnacles and green growth?
Page generation time: 0.0546s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
