BayStar Hydraulic Steering
RobMcClain
City/Region: Summerlin, NV
State or Province: NV
Vessel Name: Freedom
Photos: Freedom
PostPosted: Thu Oct 03, 2013 1:29 pm    Post subject: BayStar Hydraulic Steering Reply with quote
Our Venture is powered by a Honda BF150 and the steering is assisted by a BayStar hyrdraulic unit. This is the first powerboat I have owned that has hydraulic steering so I am not accustomed to it. I am used to having a quickly responsive helm so that when I turned the wheel (or tiller) the engine (or rudder) also moved at a similar rate and the boat noticably began to respond. I guess you might call it "tight" steering, like in a car.
With our current BayStar system, it seems to take several rotations of the wheel to get the engine to meaningfully turn. Even little course corrections take a lot of wheel movement, not just a slight turn of the wheel but a big rotation to get any response. Maybe this is normal with hydraulic steering, but I really don't know. The wheel certainly turns easily; it is just the amount of turns required that I don't like.
The hydraulic fluid is properly full and when I had the boat serviced many months ago the tech said the system operated just fine. So is this normal and something I just need to adjust to? I would really like a tight responsive system, one that quickly responds to movement of the wheel and not one that is so loose. Is there something I can do to tighten it up?
Rob
beermanPDX
City/Region: Portland
Photos: Jean Marie
PostPosted: Thu Oct 03, 2013 1:44 pm    Post subject: Reply with quote
Hi Rob,
The easiest way to figure out if you have an issue is to count the number of full wheel turns, hard over to hard over. The Baystar system states that it should be 5 full wheel turns, lock to lock.
http://www.seastarsolutions.com/products/hydraulic-new/outboard-new/baystar/
If it takes you more than 5 turns, then you have an issue. Most likely air in the system and it needs to be bled. If it's 5 turns, then it's working as designed....unfortunately. In order to reduce that number, you'd need to get the pump to push more fluid than it's designed to. I'm not aware of any way to accomplish that.
You could change out to a bigger helm pump in order to push more fluid (reduce lock to lock), but you'd need to be sure that the cylinder could handle it.
Cheers Beer
Rob
2008 25 Cruiser - Sold
2002 Nordic Tug 32/4 - Sold
1989 40 Tollycraft Sport Sedan
RobMcClain
Photos: Freedom
PostPosted: Thu Oct 03, 2013 2:45 pm    Post subject: Reply with quote
Thanks Rob. I suspect it is 5 turns side to side but will check. I've also downloaded the manual from the website for reference. Should have done that before... Might be I just need to adjust to this.
Rob
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Thu Oct 03, 2013 3:05 pm    Post subject: Reply with quote
Hi Rob. The Baystar is rated to 150hp so you're right at the limit. The seastar helm and ram may be a better fit. We have the Seastar on 90 hp mostly as I wanted the tilt helm. We're 5 turns lock to lock. One thing I've noticed is quite a few people want to "steer" the boat a lot. My partner was oversteering for quite a while. You don't need to correct for every little deviation from course. It results in PIO. Pilot Induced Occilation. The c dory tends to want to go strait. It may take a few hours to get used to. Enjoy the boat! George
PostPosted: Thu Oct 03, 2013 3:34 pm    Post subject: Reply with quote
It it takes a a revolution of the wheel to begin to turn, there is most likely air in the system, and it needs to be bled. Look at the engine when at rest, as you turn the wheel, the engine should begin to noticably turn, with a 1/8 of a turn of the wheel. There is a little slack in hydraulic steering--but not as much as you describe.
AK Angler
City/Region: South Central
Vessel Name: Rod Holder
Photos: Rod Holder
PostPosted: Thu Oct 03, 2013 3:37 pm    Post subject: Reply with quote
It shouldn't take several rotations of the wheel to get the engine to turn. Sounds to me like there's either air in the system and it needs to be properly bled, or there is some component(s) in the system that has failed - possibly a bad check valve in the helm.
I'd contact customer service at SeaStar Solutions and ask them what they think.
-Rod
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Thu Oct 03, 2013 5:41 pm    Post subject: Reply with quote
I switched from cable to hydraulic. The cable was more responsive in that it took 3 1/2 turns stop to stop but was a lot harder to turn & gave quite a workout. I put a suicide knob on my wheel that makes turning much easier & I can turn with one hand. I'd never go back. Vern
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Thu Oct 03, 2013 8:14 pm    Post subject: Reply with quote
The Baystar system is prone to leaking at the cylinder at the engine . Feel around the splashwell for oil and see if you feel some where the shiny stainless shaft comes out of the cylinder . The oils is clear and light .
They are max rated at 150 HP . They often have issues in the first couple years .
Marc
Wefings Marine Website
Since 1909
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Thu Oct 03, 2013 8:31 pm    Post subject: Reply with quote
My baystar, pushing two 50hp motors is tight. Move the helm an inch or two and the motors move. Love it way more than the mechanical links.
Testosterone Tales-Amazon.com
KG7RC
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Fri Oct 04, 2013 3:25 pm    Post subject: Saving money Reply with quote
FYI........the seals in the cylinder end caps can be replaced with new ones for approx. $28 from a good hydraulic shop. The new end caps from SeaStar are approx. $125.
PostPosted: Fri Oct 04, 2013 4:24 pm    Post subject: Reply with quote
Not an informational comment, because I don't have any, but just to say I'm reading with interest. My boat has cable steering, which so far seems to work fine, but.... a couple of hours running is a bit of a workout, which seems to "settle" into my neck muscles. So I have hydraulic steering on my list of potential future upgrades. It's more complicated than just that though (of course, it's a boat! Cry) because my autopilot is not one that would work with hydraulic, so that would also have to be replaced. Hence I'm reading and considering future moves.
At any rate, if Freedom's steering was "normal," I was thinking I would rather have the cable, which at least feels like "direct drive." But reading further, it sounds like the hydraulic is normally tighter, and would likely be an improvement I would enjoy. Good discussion, thanks Thumbs Up
AK Angler
Photos: Rod Holder
PostPosted: Fri Oct 04, 2013 4:52 pm    Post subject: Reply with quote
Sunbeam wrote:
.... a couple of hours running is a bit of a workout, which seems to "settle" into my neck muscles. ...
That's why I'll never own a cable steered boat again. I've found that hydraulic steering is much easier on the captain - especially during long runs.
redbaronace
City/Region: Puget Sound
Photos: redbaronace (Name TBD)
PostPosted: Fri Oct 04, 2013 6:14 pm    Post subject: Reply with quote
I too installed a suicide knob / necker knob, on our boat and it is a great way to get the steering wheel turned in a hurry. I have found it to be very helpful for manuvering in tight quarters and you can turn the wheel with your left hand quickly while maintaining throttle control with the right hand.
Highly recommend it as an inexpensive $20 upgrade.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Fri Oct 04, 2013 6:18 pm    Post subject: Reply with quote
We've put 1100 hours on our Baystar steering. Had to replace end seals on the piston at the engines at about 800 hours. The steering is tight, just a slight movement to get movement on the engines. No problems with broken or rusted cables, no need to take them out every year or two to re-lube; we're happy with the hydraulics. By the way, if you look at the baystar owners manual it will note that several brands of aviation brake fluid are approved substitutes for the very pricy Baystar fluid, cuts costs by about 50-75%.
Patti and Barry
formerly C-Cakes, now
rving around N. America
colobear
City/Region: Denver
Photos: C-Cakes
We've put 1100 hours on our Baystar steering. Had to replace end seals on the piston at the engines at about 800 hours. The steering is tight, just a slight movement to get movement on the engines. No problems with broken or rusted cables, no need to take them out every year or two to re-lube; we're happy with the hydraulics. By the way, if you look at the baystar owners manual it will note that several brands of aviation brake fluid are approved substitutes for the very pricy Baystar fluid, cuts fluid costs by about 50-75% when you have to do maintenance.
Page generation time: 0.0537s (PHP: 75% - SQL: 25%) - SQL queries: 32 - GZIP disabled - Debug on
