HOT WATER Dumb question of the day.
Alexander
City/Region: Stuart
Vessel Name: Alexander
Photos: Alexander
PostPosted: Sat Sep 28, 2013 3:57 pm    Post subject: HOT WATER Dumb question of the day. Reply with quote
In our diesel inboard powered boats we had the ability to route heated water from the fresh water cooling system through the heat exchanger in the water heater so we had nice hot water at the end of each cruising day.
I have never owned a big outboard engine powered craft and I was wondering if anyone has figured out how to make an outboard produce the same hot water.
PostPosted: Sat Sep 28, 2013 5:00 pm    Post subject: Reply with quote
There have been reports of folks who ran hoses from outboards--but none I am aware of in C Dory land. Most of us rely on "sun showers" in the smaller boats without water heaters. With the water heaters the Honda 2000 is the favorite--although some are using the Yamaha 2000 or 2400.
The other option (which I am not crazy about) is some thing like the Zodi or Coleman propane fired almost instant water heater.
The ones which use the outboard heat, tap into just off the thermostat. There are issues with the water not being hot enough to work in the relatively inefficient heat exchangers in the water heaters. The other issue is another set of hoses to run up under the gunnel and to the water heater. A round trip run of about 30 feet.
We have had excellent results in our Tom Cat and 25 with the Honda EU2000. We had air conditioning, the water heater, and a high output battery charger for the battery dedicated to the freezer/refer combo. So there were other uses for the generator.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat Sep 28, 2013 5:05 pm    Post subject: Reply with quote
I've not done it and can't imagine a way to do it. Outboards are using fresh cool water right out of the pond that may not get to a usable temperature for heat exchanging to a water heater. I suspect it would be quite a plumbing hack job to make such an idea work, but who knows.
I remember an old Evinrude sign that showed a guy with a lathered face, in the water shaving using the bypass water from the running engine. Evinrude was touting that as a feature. I have often wondered if the guy didn't get mighty sick breathing the monoxide coming off that engine that was exhausting right in his face. Not to mention that the prop was about crotch high and within a few inches of his unmentionables.
Testosterone Tales-Amazon.com
KG7RC
Alexander
City/Region: Stuart
Photos: Alexander
PostPosted: Sat Sep 28, 2013 6:20 pm    Post subject: Reply with quote
Thanks for the info. Looks like the little gen set is the simple and reliable way to go. I just have a lot to learn about the ins and outs of these little beauties.
Flyer
City/Region: Littleton
PostPosted: Sat Sep 28, 2013 7:48 pm    Post subject: Reply with quote
Check this out: http://www.thehulltruth.com/boating-forum/155248-hot-water-project-yamaha-outboard.html
and:
[url]
http://www.ifish.net/board/showthread.php?p=515166[/url]
I don't know why it would not work with a larger outboard, its just a matter of getting to know the engine.
Rick
Alexander
City/Region: Stuart
Photos: Alexander
PostPosted: Sat Sep 28, 2013 8:16 pm    Post subject: Reply with quote
Thanks Flyer , that's pretty close to what I was thinking was possible. Every engine makes heat, it's just determining if it's feasible to harness it.
PostPosted: Sat Sep 28, 2013 10:22 pm    Post subject: Reply with quote
The problem with both of these "hot water" is that it is not really hot and not at a high volume. The first one wanted warm water to stick inside of his wet suit and either warm it before diving and/or after coming out of the water. The second one was warm water (it turned out to be about 120 degrees). Neither of these would do to heat the water in a normal marine water heater, which basically uses a cylinder in the center of the tank to heat the water in the tank. There is not going to be enough temperature differential, by the time run thru all of the tubing to get to the water heater.
The diesel will have water running very close to 180 degrees, and in good volumes, after it has gone thru the engine block, and then to the water heater before going thru the heat exchanger. We also hooked up a diesel to supply about 25,000 BTU thru a "Red Dot" heater, when the cooling water (closed system--vs open system for outboard), was returning to the heat exchanger, and then back to the coolant tank.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sat Sep 28, 2013 11:54 pm    Post subject: Reply with quote
You're right it was a dumb question. Laughing
Boatless for now but looking
Alexander
City/Region: Stuart
Photos: Alexander
PostPosted: Sun Sep 29, 2013 11:04 am    Post subject: Reply with quote
Thanks all, I'll be going with the little Honda generator (When I get a CD) which will do much more than just heat some shower water. It can be my household back up during hurricane season too, if I haven't taken the boat nort for the summer. Bob
roydawn
City/Region: No Fort Myers
PostPosted: Mon Sep 30, 2013 7:04 am    Post subject: Reply with quote
Dr Bob, may I ask what type of hot water you used with your Honda 2000i. I have the same gen, just added a house battery charger, AC going in this winter, hot water is next, haven't even researched it yet. Thanks Roy
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Sep 30, 2013 3:03 pm    Post subject: Reply with quote
Roy, 2 ways to go . The classic Seaward 6 gallon with hear exchanger [no use on C Dory]
Or as C Dory did at one point , the instant on demand H2O heater.
Either one will work with the Honda .
Lets see if Dr Bob agrees .
Marc
Wefings Marine Website
Since 1909
Ray
City/Region: Pamlico River
Vessel Name: Seaweed
Photos: Seaweed
PostPosted: Mon Sep 30, 2013 4:00 pm    Post subject: Reply with quote
The instant-demand water heater shows a 3600W power consumption.
What would the 1800W Honda 2000eu do with this? It may overload and shut down. At the very least, the heating would not be sufficient at only 50% of the requirement.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Sep 30, 2013 4:08 pm    Post subject: Reply with quote
Honda 2000 genset specs
AC Output 120V 2000W max. (16.7A)
1600W rated (13.3A)
DC Output 12V, 96W (8A)
Brent Barrett
PostPosted: Mon Sep 30, 2013 4:59 pm    Post subject: Reply with quote
The Chronomite water heater that Marc linked to is 3600 watts, and there is also an 1800 watt version (probably what Marc was referring to). Even the 1800 watt version is going to be too much for the Honda. The Standard water heater on the C Dory is 1500 watts and will run on the 2000 Honda. I am aware of some folks putting the 240 volt water heater in these, and that will only draw about 750 watts, and can be run on the 1000.
I tried one of the flow thru "instant" water heaters, but it turned out that at least the one I tried is not made for continuos pressure, but rather is to be used when the faucet is open and no real pressure on the tank. I had hoped to recoop the space the 6 gallon tank occupies. There may be some instant tanks which will withstand the pressure, and that would be a good option.
Papacorn
City/Region: Pincher Creek
State or Province: AB
PostPosted: Mon Sep 30, 2013 9:48 pm    Post subject: Reply with quote
There are NO dumb questions, there are, however, people that are dumb enough not to realize that.
Page generation time: 0.0498s (PHP: 62% - SQL: 38%) - SQL queries: 28 - GZIP disabled - Debug on
