Suzuki DF70 - Trim Sender Assy.
fidalgoisland
Vessel Name: Sea Critter
Photos: Sea Critter
PostPosted: Mon Aug 19, 2013 11:40 am    Post subject: Suzuki DF70 - Trim Sender Assy. Reply with quote
Has anyone replaced the sender unit for the trim gauge on a Suzuki DF70 or similar 4-Stroke? I had one replaced by a local shop recently and they claimed 5 hours labor. This seems excessive for just a sender unit but wanted check on similar experiences. Thanks.
Dennis
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon Aug 19, 2013 5:50 pm    Post subject: Reply with quote
The sender is held on by 2 screws and 1 plug in 2 wire clip. Takes a bout 10 minutes. But.......they may have had to remove the trim/tilt ram assembly to do it, which can either be easy, if all fasteners are well lubbed and come out easily, or hard, if the fasteners are stuck and require a lot of penetrating fluid, heat, and time, to break them loose. If you have access to a service manual you could find the section that spells out the procedure to do it. Usually the more accomplished and experienced shops can do things much faster than the less experienced ones. It does sound excessive though. Ron
fidalgoisland
Photos: Sea Critter
PostPosted: Mon Aug 19, 2013 8:03 pm    Post subject: Reply with quote
Thanks Ron.
Page generation time: 0.0466s (PHP: 37% - SQL: 63%) - SQL queries: 16 - GZIP disabled - Debug on
