2005 25 Cruiser, $64,000 (Anacortes, WA)
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Aug 17, 2013 2:22 pm    Post subject: 2005 25 Cruiser, $64,000 (Anacortes, WA) Reply with quote
2005 C-Dory 25 “Anna Leigh” Licensed 2013 WA State
Cabernet Trim / New cabin upholstery by factory supplier 2012
Exterior/Deck/Cockpit
Windline BRM-4 Anchor Roller/Mount
10 KG Bruce type anchor w/ 25 ft chain and 275 ft rode
Digital rode counter at helm
Lewmar Anchor Windlass NEW 2012
2 Additional s/s handholds on visor
Tall radar arch
Full canvas camper back (Cabernet) from The Canvas Riggers, Oak Harbor. s/s hardware w/ quick release fittings, privacy curtains
Swim step and ladder / Strbrd side Grab bar added above step
6 fenders (Cabernet)
Bow Guard
Bennett Trim tabs with helm indicator light panel and switches
Oversized scuppers with one-way flapper valves
Upgraded wipers to pantographic type with full sweep
Cabin
Wallas diesel heater w/ ducts to V berth & cabin floor NEW 2012
Refrigerator w/ wood front panel
Custom built cabinet under galley with 2 roll-out storage racks
Pull-out cutting board under helm seat
Custom overhead galley storage cabinet/ wine glass rack, paper towel holder
New galley laminate, New galley faucet
Chart book holder above table
Chart rack on overhead roof
Red overhead night map light over helm
Added shelving in two large cabinets on port side
Hot water heater (115 v )
Factory Shore power w/ cord
Plexiglass safety cover over breaker panel
S/S grab bar in front of port seat
Second reading light in V-Berth
Port and Starboard storage shelves in V-berth
Overhead storage in V-berth for hatch screen
Helm seat attached with slide-a-part hinges for easy removal for more counter space
2 ABC fire extinguishers
Water tank level viewing port on vertical bulkhead below V berth
½” interlocking closed foam padding under carpet
Privacy curtains
New cabin upholstery NEW 2012 installed by factory supplier
Bulkhead cutout like a Tom Cat for access to V berth
Porta Potti (original head, macerator, hoses removed. Waste tank cleaned and top removed and is now storage)
Third access port added in between two factory ports aft of cockpit to access new storage
New aluminum gas tank correctly installed to replace old tank NEW 2012 (Installed by Cap Sante Marine, Anacortes)
Wider cockpit steps installed port and starboard
Jet pump replaced 2012
Guest charger NEW 2013
Electrical/Electronics (EQ Marine installed)
Batteries. New 2012. 3 AGM 60 amp/hour. 2 house and 1 engine w/ Honda Battery Distribution Cluster 33200-ZY3-000AH (Automatic voltage sensing switch)
Electronics cabinet mounted under the factory shelf with “glove compartment” and dedicated fuse panel, houses 2 marine VHF’s and AM/FM/CD and 2 window fans
Raymarine C-80 MFD Package w/current update
Navionics XL/XL3 Gold navigation chip for C-80 Olympia, WA to N. Vancouver Is., BC
Raystar 120 WAAS GPS Seatalk Version
Raymarine DSM-250 digital depth sounder module
KVH Azimuth 1000 Electronic Compass
Richie B-51 Magnetic compass
Raymarine Pathfinder 2kw radome
Raymarine P66 high speed depth transducer with speed/temp
Raymarine Autopilot S1000
Icom 402s DSC VHF radio
Standard Horizon VHF w/fog and loud hailer
2 way outside speaker
Shakespear stainless heavy duty rail ant mounts
2 Morad 156HD ans 146HDAntenna 4.5 FT @ 6db
AM/FM/CD player w/ speakers mounted above windows on port and starboard side
Navman 3100 Electronic fuel monitor
2 extra 12 v receptacles
Momentary window wiper switches port and starboard bulkhead
2 / 12 v fans under electronic shelf for port and starboard windows
1000 Watt inverter mounted near house batteries and wired to dedicated plug-in w/indicator lamp in galley
Engine
Honda BF 150 (800 hours) factory/dealer serviced
Honda S/S prop
Extra Prop Honda S/S extra castle nut, cotter pins, etc.
Trailer Licensed 2013 WA State
King tandem axle KRTY7000B2DSC
LED lamps, Disk Surge Brakes
Trailer jack replaced 2011
Galvanized Metal boarding ladder under bow, bolt mounted to winch support upright
Metal galvanized 6 ft.catwalk along port side of winch
Manuals for all equipment
Always stored undercover and heated
Click on Anna Leigh Albums on left for construction pics and Anna Leigh 25 pics
Contact David using either email or PM buttons below
On edit by Da Nag - Price Change
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Sat Aug 17, 2013 6:28 pm    Post subject: Reply with quote
Some one is going to get not only an excellent boat, but one where the many upgrades were well documented from the molding of the hull to full forced air diesel heat!
PostPosted: Sat Aug 17, 2013 9:13 pm    Post subject: Reply with quote
Say it isn't so! What is this all about? A Grand Banks next or what? This boat is the cat's meow! David is a master craftsman, I was lucky he duplicated a few of his upgrades for Daydream, but unlike Daydream (which is not for sale), Anna Leigh has been stored inside, so no oxidation, this boat is pristine in every way. It really should go for something close to a new boat, this price is a frickin' STEAL!
Alyssa Jean
PostPosted: Sat Aug 17, 2013 9:39 pm    Post subject: Reply with quote
Maybe I should ask more??
sportner
City/Region: Buckeye
C-Dory Model: 26 Osprey
Vessel Name: Glory Days
Photos: Traveler
PostPosted: Sat Aug 17, 2013 11:15 pm    Post subject: Reply with quote
David,
So what is the brand of the new boat?
RUSS & TONI
Alyssa Jean
PostPosted: Sat Aug 17, 2013 11:16 pm    Post subject: Reply with quote
Nothing on the horizon yet.
Alyssa Jean
PostPosted: Tue Sep 24, 2013 11:44 pm    Post subject: Reply with quote
I forgot to add that the inflatable that lives on the roof is included also.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Wed Sep 25, 2013 12:24 am    Post subject: Reply with quote
If it just had twin engines, I'd be in!
Testosterone Tales-Amazon.com
KG7RC
PostPosted: Wed Sep 25, 2013 12:46 am    Post subject: Reply with quote
Harry,
We could have a bidding war ---- I check for twins too Laughing Laughing
SleepyCMoon
potter water
City/Region: Logan
C-Dory Year: 1997
Vessel Name: Poopsy
PostPosted: Wed Sep 25, 2013 10:19 am    Post subject: Reply with quote
Seems that most of the 25's come with the big ol hawg 150 or so on the back. It ruins the proportions of the boat to my eye. Then to have a funny little kicker off to one side just looks wrong for this style of boat. But that is just me. I may end up having to stay with my 22 and it's twin Suzys just to keep my artistic sense intact. Unfortunately, a new 25 powered the way I want is out of the question in my retired state and my new added health costs from Obama care.
Alyssa Jean
PostPosted: Sat Jan 04, 2014 5:08 pm    Post subject: Reply with quote
New Year, New Price. $64,000. You won't find a better equipped or maintained 25 anywhere.
PostPosted: Sat Jan 04, 2014 8:14 pm    Post subject: Reply with quote
Wow, I am surprised that this boat has not sold before--now with a price drop--here is a very well cared for and updated C Dory 25 at an excellent price.
Alyssa Jean
PostPosted: Sat Jan 18, 2014 4:58 pm    Post subject: Reply with quote
Anna Leigh has been sold. She will still be living on Guemes Island.
Page generation time: 0.0756s (PHP: 62% - SQL: 38%) - SQL queries: 30 - GZIP disabled - Debug on
