85 E-Z load trailer for 22' C Dory Angler rear roller broken
Tony NFTF
City/Region: Port Orchard
C-Dory Year: 1985
PostPosted: Mon Jul 22, 2013 6:22 pm    Post subject: 85 E-Z load trailer for 22' C Dory Angler rear roller broken Reply with quote
purchased new in 1985 from the Tolands at C Dory in Kent a 22' Angler and E-Z load M 6 3100 trailer. I was unaware that they modified the trailer and installed lateral bunks and a large roller across the back. Well the roller broke and C Dory and E-Z load are no help finding a replacement, anyone know if those rollers are still available somewhere.
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Mon Jul 22, 2013 6:56 pm    Post subject: Reply with quote
picture would help a lot
Richard
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Mon Jul 22, 2013 8:09 pm    Post subject: Reply with quote
Tony, check drift boat trailer sources. They often use rollers all the way across the back.
PostPosted: Tue Jul 23, 2013 12:19 pm    Post subject: Reply with quote
The trailer parts are not made by C Dory or the trailer manufacture. We don't have any idea of what type of roller you have: length, diameter in the center, diameter at the ends, diameter of steel bar which goes thru the center. Once you have these measurements, you can go on line and find a replacement. Just search "trailer roller" . You will find a replacement there. Also there is most likely a trailer parts outfit near where you live. Again with the measurements you can call around and find the item you need.
Page generation time: 0.0537s (PHP: 49% - SQL: 51%) - SQL queries: 17 - GZIP disabled - Debug on
