2006 Tomcat 255 fuel fumes in Cabin
squidslayer
City/Region: El Sobrante
Vessel Name: ShirleyMae
Photos: Shirley Mae
PostPosted: Wed May 22, 2013 9:37 pm    Post subject: 2006 Tomcat 255 fuel fumes in Cabin Reply with quote
For many years on my 2006 Tomcat .. at least the last 5…. I have been getting an intermittent gasoline smell in the cockpit…usually when I am running and the door is closed. I stuffed a pillow in the opening between the dashboard and starboard hull to keep the smell out from the cabin and keep the door open when running. I had tried many times to trouble shoot it took all the opening covers and reached in to the fuel tank and felt…smelled and tightened the ……….fill……..vent and outflow hoses fittings... and clamps…..to no avail. You can smell fuel around the tank depending on the breeze coming in……. I see no signs of leak and there is no fuel in the bilge. I can only barely see and feel a small part of the edge of the tank…so I cannot inspect the majority of the tank for any weeping fuel. Since there is no sign of a major leak…but concerned for safely I have installed a engine compartment type safety blower vent that should prevent any dangerous levels of fuel vapors to build up. I plan to keep an eye on it for any liquid fuel and to treat it as a nuisance of concern. The only way to see the whole tank to inspect would be to cut the whole floor out of the bathroom or more…….many many thousands$$$$
Any advice would be deeply appreciated
DickE
El Sobrante Ca
"ShirlyMae"
"Shirley Mae"
255 Tomcat 2007
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Thu May 23, 2013 7:28 am    Post subject: Reply with quote
I've had the same issue with my 2008. Any time the wind comes up or we travel over 15 knots we have to open the door to vent the smell. I checked every hose and connection and added more clamshell vents but nothing has worked.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
Sasscom
City/Region: St. Michaels
State or Province: MD
Vessel Name: ViewFinder
Photos: ViewFinder
PostPosted: Thu May 23, 2013 10:15 am    Post subject: TomCat Fuel Smell Reply with quote
Hmm. We have a 2009 TomCat and have never experienced this. We can run 20-25 knots with the cockpit door closed and have never smelled fuel. However, I'll keep my eye on this post, as I'm now curious and concerned. I hope you find the solution, and that it's not having to remove the tank. I can't imagine what that would cost since the tanks are not accessible.
George & Stacey
"ViewFinder"
2009 TomCat
Suzuki 150s
squidslayer
Photos: Shirley Mae
PostPosted: Thu May 23, 2013 11:07 am    Post subject: Reply with quote
Is your smell on the starboard tank side??....if you open up one of the round hatches or take the 3 ft starboard side shelf out I can smell it....but on the port side I cannot.
It has been an issue for years...but I have not blown up yet.....there is nothing in that area to spark...and fumes although noticable....does not seem to be strong enough to be a hazard...just an annoyance and a concern. I will be checking it often...and like I said put a blower to vert while operating and a solar powered vent when not....just to be safe.
Have you talked to your dealer?
PostPosted: Thu May 23, 2013 11:23 am    Post subject: Reply with quote
I'm on my second 2006 TC255 and have not experienced a problem like this.
dabfd
City/Region: Thousand Oaks
Vessel Name: Patriot (was Tom-a-Hawk)/sold
PostPosted: Thu May 23, 2013 11:54 am    Post subject: Reply with quote
Have not experienced any fumes on our Tomcat. You might try to isolate the leak by applying low pressure or vacuum to the tank to see if it holds. While the tank is pressurized check for leakage. If you don't find any leaks then most likely you have a venting problem or spillage from the fill hose, the vent line or the fuel supply line. Also try replacing all the hoses. Be very careful while trouble shooting this problem.
Dave & Donna
42' Catalina sold
07 Tomcat 255, Patriot sold
42' Catalina Mk II, Legado
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Thu May 23, 2013 12:15 pm    Post subject: Reply with quote
Dick, plastic or aluminum tanks ?
Marc
Wefings Marine Website
Since 1909
squidslayer
Photos: Shirley Mae
PostPosted: Thu May 23, 2013 12:45 pm    Post subject: Reply with quote
Marc
Aluminum with black hoses
Pacificcoast101
Photos: No Pressure
PostPosted: Thu May 23, 2013 1:17 pm    Post subject: Reply with quote
I haven't found any leaks. We don't smell the fumes all the time, only when running at least 15 knots.
Wefings
Dealer
PostPosted: Thu May 23, 2013 1:22 pm    Post subject: Reply with quote
The reason I asked is the plastic tanks were permeable . In your case I would check and see if the hose is permeable . New EPA regs require non permeable hose .
The other place to look is at the senders . They have a gasket and can leak a bit .
Marc
squidslayer
Photos: Shirley Mae
PostPosted: Thu May 23, 2013 2:00 pm    Post subject: Reply with quote
Marc
What and where is a sender?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu May 23, 2013 2:08 pm    Post subject: Reply with quote
I would be very careful putting the tank under pressure and risk damaging the seams, and would contact the tank vendor for technical assistance
Brent Barrett
PostPosted: Thu May 23, 2013 2:10 pm    Post subject: Reply with quote
Marc
The sender is the fuel level device. Sends signal to your gauges on the dash. It's located just about under the step in the forward corner of the cockpit. Access through the round access hole either in the step or in the wall. Just about where your fuel fills come down from the deck and the vent goes up.
Wefings
Dealer
PostPosted: Thu May 23, 2013 4:26 pm    Post subject: Reply with quote
Thanks Charlie , I got sidetracked . They can leak if not torqued down evenly .
Marc
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu May 23, 2013 4:34 pm    Post subject: 2006 Tomcat 255 fuel fumes in Cabin Reply with quote
I don't have a Tomcat but it almost sounds like your fuel vent is getting supercharged at over 15 mph by wind as you are bopping along. Maybe the vents can be rotated to the rear as not catch so much air. We put clam shells to block air and water from causing any issues with our fuel vents. I'd check all your hoses and try to tighten the top plate on your fuel sender.
I did not sleep at Holiday Inn Express last night either
D.D.
Page generation time: 0.0322s (PHP: 77% - SQL: 23%) - SQL queries: 28 - GZIP disabled - Debug on
