1986 C Dory 26 Pilot House Cruiser, $30,000 (Vermont)
PostPosted: Tue May 21, 2013 10:43 pm    Post subject: 1986 C Dory 26 Pilot House Cruiser, $30,000 (Vermont) Reply with quote
Posted on behalf of c-dory 26.
1986 C Dory 26 Pilot House Cruiser, Serial No. 26005E686 Located South Hero, Vermont (Lake Champlain) Fresh Water Boat, Dry Sailed for at Least 20 Years Since Launching
170 Hp OMC Cobra V6 GM 4.3 L I/O rebuilt 2004 San Juan Fresh Water Closed Cooling Cabin Heat with Two Speed Fan Yamaha Hi Thrust 9.9 4 Stroke Outboard
1986 EZ-Loader Tandem Axle Trailer, Galvanized SE # 1ZE1LEZ22GA022533 Custom Canvas Enclosure for Cockpit
160 Gallon Fuel Capacity with Port and St’Bd 80 Gallon Aluminum Tanks
12 Gallon Fresh Water Tank and Lake Water Foot Pump
2 Burner Origo Alcohol Stove
Bennett Hydraulic Trim tabs
Assorted gear Allowing “Turn Key” Operation
PostPosted: Tue May 21, 2013 10:44 pm    Post subject: Reply with quote
Great Republic is one of a handful of 26’ Pilot House commercial work boats built by Roy Toland of C Dory that is known to be operational today. The only other one I can be certain of is used to carry supplies (and clients) to a fishing camp off the coast of Alaska.
I have been told that production of this vessel was limited to15.
The business plan described was that they were to be used as: “Sport Fishers,Trollers, Seiner and for Diving, Marine Surveying, towing and Walrus Hunting”. I am not sure when they went out of production or why but have been told that the market for such a boat was not large enough to support their production and sales costs.
The class was given rave reviews in the July 1986 number of Trailer Boats which described two offshore runs from Kent, WA to Southern California. Great Republic may in fact, be the very boat that Roy Tolen took offshore twice down and back along the Pacific coast though there is no way to prove it.
The boat is 26’ X 8’ 6’’, with a draft of 12” -16” increasing to 20”-24” aft with the engine down. It weighs 3,400 lbs dry and even with the trailer and a load of fuel and gear is easily towed by a full size pick up truck (350 - 380 cu inch engine with a tow package), allowing over the road travel without special permitting, vastly increasing boating possibilities.
Head room in the cabin is 6’4” and the boat sleeps two forward in V berths and two in the cabin when the dining table is lowered. The dinette is port side, galley starboard aft of the conning station. Porta Potti (not included) is forward between the after ends of the V berths and separated from the main cabin space by a closing door. The original holding tank, taken out by the previous owner is available if desired.
The boat planes at about 5-6 Knots, cruises comfortably and economically at 10 - 18 Knots and will go to the mid 20s at full throttle. The range of the boat with full tanks was described to me as being 600 miles but I never checked this.
Aside from the no frills, commercial grade construction, the principal feature of the boat is the massive cockpit space measuring 11’ fore and aft and seven feet thwart ships allowing remarkable work space or seating. We cruised with two small kayaks that fit comfortably in the cockpit and with two bikes on the cabin top.
As mentioned this was built as a work boat and is made to commercial specs. Rails are stainless no It has a 2000 lb, 40 cubic foot hold under the cockpit sole and another, slightly smaller hold under the cabin sole allowing very long range cruising.
Hull shape is moderate V forward flattening aft allowing good heavy weather performance and surprising carrying capacity.
I acquired the boat in the Spring of 1998 from a previous owner who may well have been the most fastidious owner on the planet and was ( is ? ) the C Dory dealer in Superior, WI.
He put the boat in a boat hanger after each use save for his summer cruises from Superior to Thunder Bay along the N shore of Lake Superior, a trip he did in perfect safety with a family of five (including a newborn) though no doubt keeping a good eye on the weather and the radar looking for shipping.
I have kept the boat in a hoist since acquiring it. Winter covers with shrink wrap and servicing by a local boat has been done since I acquired the boat in 1998.
Since 1998 I have used it sparingly. It has has done all of Lake Champlain, the Chambly Canal and the St Lawrence River to Montreal and the Rideau Canal on my watch and was loaded to do the ICW, a trip that was thwarted by the closing of NY Harbor after the events of 9/11.
My principal use of the boat save for short trips with friends and family has been serving as the dive boat for the marine archeological evaluation of the site of the Battle of Valcour in 1776 done by the Lake Champlain Maritime Museum.
Great Republic, though down on her lines a bit, managed to carry 4- 6 large divers with all dive gear to and from the dive sites without difficulty and regularly accommodated as many as eight divers for meetings and meals at the dock.
Equipment includes a superior Ritchie compass, a fairly new Cobra VHF with a Lake Superior sized and spec. antenna; Lowrance fathometer; a somewhat outmoded but functional Garmin 130 GPS. The Ratheon 10X is presently non functional but can be restored though listed as “Retired” by Ratheon.
Three propellors, two excellent anchors with rodes and assorted dock lines, fenders and spare parts are included.
The canvas work is custom, well done and in excellent condition. Screens are in need of replacement.
The trailer has hydraulic brakes in good working order but the trailer tires might need replacing if trailing a great distance is required.
The general condition of Great Republic is excellent. The boat has not been in the water since the Fall of 2010 because of high water on Lake Champlain and some surgery for the owner in April of that year.
The boat is presently in the back yard of a summer cottage in Northwest Vermont. It has been “Summerized” and been run with rabbit ears but has not been launched this summer.
nimrod
City/Region: Mount Vernon
Vessel Name: 'Berta's Boy
Photos: 'Berta's Boy
PostPosted: Tue May 21, 2013 11:49 pm    Post subject: Reply with quote
photos etc.
http://www.yachtworld.com/boats/1986/C-dory-26-2504195/South-Hero/VT/United-States
PostPosted: Wed May 22, 2013 1:34 pm    Post subject: Reply with quote
I believe that this is the same boat which was listed a few months ago, and I felt it was a great buy for someone. What I would envision is to lengthen the cabin top and house by 3 feet and put in a head/shower on one side and a hanging locker on the other. This could be done with Nadi-core, and a layer or two of glass on each side to keep the weight down, move the bulkhead aft, and make a wonderful cruiser. I love the reverse shear on the forward windows.
Its a great boat for some one--as is or converted. (Sorry, I am no longer in the conversion or restoration business!)
PostPosted: Wed May 22, 2013 5:41 pm    Post subject: Reply with quote
Ditto. Very salty looking. Cool
PostPosted: Wed May 22, 2013 6:23 pm    Post subject: Reply with quote
I'm very surprised this boat has not sold yet. Wonderful design. Would make a great northwest fishing boat. great design for off shore halibut or tuna. Its the closest thing to my 27 out there. And yes Bob is right, add a head and a closet and you have my boat but with a smoother ride with the deeper v. All for 30k. In order to replace this boat you would have to go to a seaport 24-27 at 120k plus. This is a steal at 30k.
svmegatron
Guest
PostPosted: Wed May 22, 2013 11:25 pm    Post subject: Reply with quote
I apologize for creating thread drift here.
In your opinion, how hard would it be to do something like this? If you had it done professionally, what kind of ballpark amount might you expect to pay?
I've often toyed with the idea of fiddling around with the pilothouses of pilothouse boats, C-Dory and otherwise, and I don't really have a handle on how big an undertaking it is. It doesn't *look* like it would be impossibly hard, but I'm very aware of how misleading my first impressions can be!
PostPosted: Thu May 23, 2013 7:32 pm    Post subject: Reply with quote
See new thread on modification of pilot house boats.
DuckDogTitus
City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
PostPosted: Fri May 24, 2013 10:27 am    Post subject: Reply with quote
I gave this boat some serious consideration this winter, its a lot of boat for the money. the only reason I didn't was because I really wanted OB power. But man, what a cool boat.
Dustin
bobjarrard
City/Region: Boulder City
State or Province: NV
PostPosted: Sun Aug 04, 2013 10:53 am    Post subject: new price - this has to sell soon!! Reply with quote
The Yachtworld listing price is now 25K. The Cobra motor has 190 hours. It has a Yami 9.9 also. Don't like the IO setup? Fit an Armstrong bracket and put on twin 90's and away you go. If someone in SoCal wants to split the boat with me and the wife, we are all in as we live outside and this boat has it all. We spend $1500 twice a year to house boat on Shasta, doesn't take long to make this one work at 25K. Older boat - heck I just turned 66 and can outwork most teenagers. And it is a Toland built boat. Come on Brats, lets see this one sell ASAP.
Bob Jarrard
714 686-2728
Tinker
City/Region: Knoxville IA/ La Conner WA
State or Province: IA
C-Dory Year: 1986
C-Dory Model: 26 Pro Angler
Vessel Name: Great Republic
Photos: Great Republic
PostPosted: Thu Sep 12, 2013 11:09 pm    Post subject: Reply with quote
Hello everyone. I'm heading to Vermont Saturday to pick up Great Republic. I'm excited to be a boat owning C-Brat member! The plan is to take her to my home in Iowa to complete some upgrades and then get her to her final home in the Northwest for many adventures to come chasing salmon! I look forward to meeting all you NW C-Brats on the water.
Travis Cram
PostPosted: Thu Sep 12, 2013 11:19 pm    Post subject: Reply with quote
Welcome aboard, and I think you bought a great boat, which can serve you very well!
PostPosted: Fri Sep 13, 2013 12:02 am    Post subject: Reply with quote
Whew, thank you -- now I can stop thinking about it for myself Mr. Green
Congratulations, and welcome to C-Brathood! Can't wait to read about your adventures Thumbs Up
PostPosted: Fri Sep 13, 2013 12:17 am    Post subject: Reply with quote
Wow, congrats, we will look for you out here! You will be hard to miss, with that distinctive look!
Travis Cram
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
PostPosted: Fri Sep 13, 2013 10:24 am    Post subject: Reply with quote
Travis Cram
I hope you share your adventures with the new boat on here quite a bit. I think if this boat had happened to be in the Seattle area I would have given it some very serious thought. congrats on a very neat dory!
Page generation time: 0.0825s (PHP: 67% - SQL: 33%) - SQL queries: 31 - GZIP disabled - Debug on
