Power adapter for marinas
Mike_J
City/Region: Victoria, BC
C-Dory Year: 2011
Vessel Name: Natural C-lection
Photos: Natural C-lection
PostPosted: Sat May 11, 2013 12:31 am    Post subject: Power adapter for marinas Reply with quote
Hi, I am not yet planning to set up my CD22 to have a 120 V system on board, but am tempted to get an adapter that will allow me to use a regular 3 pin outdoor extension cord to power the odd device aboard. Is there a fairly standard adapter that is used for getting power at marinas, or do most marinas also support a standard 15A 120 V plug?
Mike and Monica Jackson, Victoria, BC
http://naturalc-lection.blogspot.ca/
Dreamer
Photos: Dreamer
PostPosted: Sat May 11, 2013 2:37 am    Post subject: Reply with quote
Mike,
If you're referring to Friday Harbor, The pedestals have just 30 amp outlets as I recall. Pretty easy to get a 30 amp male and a 15 amp female connector at Home Depot wit a couple feet of #8 3-wire cable and make up an adapter.
Dreamer- Sold 25 Feb. 2013
Morning Star
City/Region: Roseville
Vessel Name: Morning Star
PostPosted: Sat May 11, 2013 7:47 am    Post subject: Reply with quote
West Marine carries a Marinco adaptor for around $50. It is an easy way to go. http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=1004518&catalogId=10001&langId=-1&storeId=11151&storeNum=50523&subdeptNum=50524&classNum=50526#.UY4vEsu9KSM
Mike_J
C-Dory Year: 2011
PostPosted: Sat May 11, 2013 8:09 am    Post subject: Reply with quote
Thanks! I may pick up the west marine adapter unless the Home depot bits are much cheaper.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat May 11, 2013 9:24 am    Post subject: Reply with quote
Mike,
The parts at HD are more together than the West Marine item as I recall. We have a good relationship with the WM in Friday harbor and they give us a discount on many items while we are there so you might want to make sure they have what you need and then get it there. We do not have "shore power" on our boat but I do have a GFI protected setup I'll be glad to show you while we are there.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Mike_J
C-Dory Year: 2011
PostPosted: Sat May 11, 2013 9:51 am    Post subject: Reply with quote
Should the following items work?
http://www.homedepot.ca/product/15-amp-locking-plug-125vc-2-pole-3-wire/903849
and http://www.homedepot.ca/product/pvc-connector-3-wire-yellow/903730
I think I may wait until Friday harbor and see what others have... Under two weeks now! Smile
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat May 11, 2013 10:54 am    Post subject: Reply with quote
I have the "home depot" version and it works fine. BUT, the regular marine adapter will serve you better over time. I have had my boat in one marina where the dock walker came along and told me that I needed a marine certified adapter, not my HD special to be legal with their marina requirements. So that is something else to consider. They like that bright yellow color. I also think that the marine adapter will hold up to corrosion in salt environments better. So saving a buck may not be the best investment. I built the HD special because I couldn't find a marine adapter near buy at the time and couldn't wait for shipping.
Testosterone Tales-Amazon.com
KG7RC
Mike_J
C-Dory Year: 2011
PostPosted: Sat May 11, 2013 3:49 pm    Post subject: Reply with quote
Thanks for that heads up Susan/Harry. I am now thinking I will wait until next weekend and see what they have at the Friday Harbor West Marine.
PostPosted: Sat May 11, 2013 5:13 pm    Post subject: Reply with quote
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Sat May 11, 2013 8:05 pm    Post subject: Power adapter for marinas Reply with quote
colobear wrote:
Mike,
Me too Barry. I would like to see your set up.
Martin.
PostPosted: Sat May 11, 2013 10:25 pm    Post subject: Reply with quote
Hmm, sometimes strange things happen--and a blank post.
The point was that the 15 amp plug at Home depot was most likely a difference spread and slightly different spade design than the 30 amp marine which Home Depot also sells. Best to go with the marine version and a 10 gauge yellow cored between the 30 amp plug and connector for 15 amps.
I make my own adaptors, but they are with marine components--probably less corrosion. The current one is a 10 gauge heavy duty extension cord with the molded 15 amp connector, with a 30 amp marine plug--all yellow and weather sealed.
primative
City/Region: Portland
Vessel Name: Primative
Photos: Primative
PostPosted: Sun May 12, 2013 2:25 pm    Post subject: Reply with quote
Happy Mothers day.
I have the same set up as Bob, although this happened the 1st time I planned on using it.
I was at the marina I would be using a couple months prior to a planned trip and looked at the outlet which was 30 amp. So I made up the above rig and ready to go for four days at oregon coast in Feb. (blessed with a reasonable weather window). I come in at the end of the day with some bay dinner and glad to be with my visiting brother from Alaska, recuperating from hip surgery. I proceed to set up for the evening when I discover every pedestal on the dock arm I'm on is 20 amp. It turns out the dock arm I had checked earlier for sizing was for commercial/charter boats and the dock arms for recreational boats which I was assigned were 20 amp. Hmmm. We just ran the Wallas more without the quartz heater I had brought to suppliment, and had the right sleeping bags. We had good time. So I still have never used shore power at a dock, but am softening up some and will be in the future.
I guess an additional 20 amp rig of sorts for this type of marina is best.
Tom
(Primative)
Page generation time: 0.0693s (PHP: 70% - SQL: 30%) - SQL queries: 25 - GZIP disabled - Debug on
