Anchor Shackle
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Fri May 10, 2013 3:11 pm    Post subject: Anchor Shackle Reply with quote
I get the impression that most of us who use a shackle (excluding swivel shackles) to join the chain to the anchor, use a bow shackle, including myself. Why do we do this? What is the difference between a bow shackle and a straight shackle?
Martin.
dabfd
City/Region: Thousand Oaks
Vessel Name: Patriot (was Tom-a-Hawk)/sold
PostPosted: Fri May 10, 2013 5:57 pm    Post subject: Reply with quote
Hi Martin,
It's my understanding that bow shackles are better suited when
Pulling loads are multiple directional. Still the load strengths are
decreased as the load moves from a straight pull to a side pull.
Straight shackles are designed for straight pulling. When we retrieve
our anchors or while we are anchored in heavy changing wind directions
the angle of the chain to anchor is constantly changing.
Dave & Donna
42' Catalina sold
07 Tomcat 255, Patriot sold
42' Catalina Mk II, Legado
PostPosted: Sat May 11, 2013 10:21 pm    Post subject: Reply with quote
Well, I'm used to shackles for connecting halyards to sails and shackles to connect anchors to chain and anchor line. There are tack shackles, stamped shackles, snap shackles, headboard shackles, etc.
So what's the difference? As far as I can see, each is designed to take the load for its designed use. And if you're using a shackle to connect parts of an anchor rode together, as mentioned above the anchor chain and rope will not always be in a straight line. So the bow/anchor shackle has a bow in it to allow misalignment.
You can get anchor/bow in either stainless or galvanized. but the galvanized will have a painted steel pin.
Was that the question?
Page generation time: 0.0414s (PHP: 37% - SQL: 63%) - SQL queries: 16 - GZIP disabled - Debug on
