Throttle Play
Lipidman
City/Region: Campbell Creek
Vessel Name: Thisaway
Photos: Bobby Lou
PostPosted: Wed Apr 17, 2013 9:44 am    Post subject: Throttle Play Reply with quote
The throttle on my 2006 Yami 90 hp on Bobby Lou (19' Angler) has a long throw with no response, then suddenly kicks up fast. If I am not careful passengers suffer. The cable seems tight and I don't know where else to adjust it. Any ideas?
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Wed Apr 17, 2013 10:31 am    Post subject: Reply with quote
Hi Roger.... on the side of the control box is an adjustment screw...that is for minor adjustment of tension...other than that something inside the box could be out of adjustment....it is real easy to take that control apart and lube it... could be a kink in the cable..or corrosion in the cable....if the box is fine, then just replace the cable....
Joel
SEA3PO
Page generation time: 0.0344s (PHP: 36% - SQL: 64%) - SQL queries: 15 - GZIP disabled - Debug on
