25 Cruiser rode locker capacity
halibut taco
PostPosted: Wed Mar 06, 2013 12:01 am    Post subject: 25 Cruiser rode locker capacity Reply with quote
Anyone know what the capacity is for the bow locker on a 25 cruiser?
I'm looking to replace the anchor rode on my 25 cruiser with a new one. I have a Simpson-Lawrence Horizon 600 horizontal windlass, so I believe I need to use 1/2" 3 strand. I hope that I'll be able to fit 500-600' of rode so that I can anchor in some deeper fishing spots. I also have 50' of 1/4 chain.
Also if you are in AK then any suggestions on locally available rodes are welcome. I'll was planning to check Alaska Rope and Wire first.
PostPosted: Wed Mar 06, 2013 12:30 am    Post subject: Re: 25 Cruiser rode locker capacity Reply with quote
I don't have information specific to a 25, however on the rode:
Another option may be an 8-plait rope such as Yale Brait. It packs down smaller than three-strand so that you can fit more in the locker (I have 200' in a box and it does fit in a smaller space than the equivalent three-strand). I checked and the 1/2" is supposed to work with a Lewmar 700 horizontal windlass (I don't have a windlass now but knew I might get one in future). I believe Sam on Retriever uses the Brait with his Lewmar 700 vertical windlass.
mmitchell
City/Region: Whittier
Vessel Name: ShiRoz
Photos: ShiRoz
PostPosted: Wed Mar 06, 2013 12:53 am    Post subject: Reply with quote
800' + 50' chain Very Happy
Life is Good
25 C-Dory ShiRoz 2006-sold 2012
32 Trawler Adirondack 2012-
PostPosted: Wed Mar 06, 2013 1:24 am    Post subject: Reply with quote
Whoa! Well maybe you won't need to worry about Brait then. Guess it's a bit bigger than the one on the 22 .
Anna Leigh
City/Region: Guemes Is., At the edge of the San Juan Islands, WA
Vessel Name: Anna Leigh
PostPosted: Wed Mar 06, 2013 10:38 am    Post subject: Reply with quote
I have the 600 with 30 of chain and about 280 of 3 ply rode. I could probably fit another 50' on top of that, but it would be prety well up to the bottom of the windlass without going up and re distributing it'
David and Kate
Anna Leigh 25 Cruiser,
Alyssa Jean 16 Angler
K7KJR C-Brat #51
U.S.C.G Licensed Captain
www.vrbo.com/292827
halibut taco
PostPosted: Wed Mar 06, 2013 12:03 pm    Post subject: Reply with quote
Do you have the vertical windlass version? I definitely don't want to be opening the locker hatch to spread the rode out on a regular basis.
PostPosted: Wed Mar 06, 2013 6:58 pm    Post subject: Reply with quote
Dave/Anna Leigh is about the max as to the amount of 3-strand anchor rode one can stuff into a C-25 anchor locker. That rode gets a little stiff with salt (no snickers.)
For various reasons I changed to plaited rode (6 or 8 plait.) That will pack down a lot more, and you can easily double the amount. The 200" of Sampson 6-plait looks small at the bottom of Journey On's locker, even with 50" of chain underneath. The plaited rope is ~10 cents/ft more expensive than 3-strand (defender prices for 1/2".) Easier to splice, too. Just soak it in water before you use it to remove the lubricant.
A comment on the Simpon 600 Vertical. The seal under the capstan allows a lot of grit to get into the gearbox and motor. Here are some photos of the inside of a 600 after it failed: Lewmar 700 Gospel . Here's an extensive discussion of replacing a 600 with a 700: Lewmar 700 Installation . The last post is the installation of a 700 on Anna Leigh.
Anna Leigh
PostPosted: Thu Mar 07, 2013 10:33 am    Post subject: Reply with quote
My mistake, I replaced the 600 with the 700V, which is the exact same size.
Post new topic   Reply to topic    The C-Brats Forum Index -> Anchoring All times are GMT - 6 Hours
Page generation time: 0.0592s (PHP: 62% - SQL: 38%) - SQL queries: 25 - GZIP disabled - Debug on
