CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Tue May 17, 2005 11:25 pm Post subject: Leaking Lazarette Hatch |
The port lazarette hatch leaks on my 22 cruiser. I removed the gasket and it has a slight defect which I think is causing the leak. My research so far seems to show it is a Bomar inspection hatch? Has any one found a source of new gaskets? I could only find one source that sells the material in 10' lengths for $25. That seems a little high to me since I could buy a whole new hatch for $55. Any ideas for alternate gasket material? I did find a source for 0-ring cord in 3/8" OD which would fit in the hatch groove. Not sure if this would seal properly. Any help/ideas would be appreciated. Thanks. _________________ Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas |
dogon dory
Vessel Name: DogOnDory
Posted: Tue May 17, 2005 11:59 pm Post subject: |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Wed May 18, 2005 1:18 am Post subject: |
Thanks Dan. I didn't ask what it was made of. I will have to call again tomorrow and check. The old gasket was pretty soft and squishy so a very hard material probably wouldn't work. |
Posted: Wed May 18, 2005 9:06 am Post subject: |
The O-ring cord (if it is soft and durable enough) will work just fine. In a previous place of employment we had a kit that could be used to make custom o-ring of most any size - it consisted of:
1) various diameters of o-ring cord
2) a simple device with channels in it for each diameter of cord and a slot through which a razor blade would fit - this allowed one to easily make nice perpendicular cuts on the cord
3) Some "super glue - like" glue to glue the ends together and
4) a jig that would keep the ends aligned while gluing.
I beleive the kit was from Parker O-rings. BTW - it is also possible to get the cord in a design that is flat on two sides. A good source for O-ring parts (and for all kinds of other hardware) is McMaster Carr. Go to their web site (www.mcmastercarr.com) and do a search on o-rings - a lot of good information on types of cord stock, hardness, material type etc will come back as will links to products. Scroll down and you'll see links to their o-ring splicing kits. You can also view and price these by going directly to their catalog pages - page 3238 of thier courrent catalog has the splice kits listed. The "inch kit" in silicone "includes four 7-ft. long pieces of cord stock in diameters of 0.103", 0.139", 0.210", and 0.275" (unless noted)", goes for $46.67 and includes a simple jig and glue.
I might also point out that McMaster Carr is also great source for other hardware including stuff made from stainless.
Roger on the SeaDNA _________________ Roger on Meant to be
Luna C
Joined: 25 Feb 2004 Posts: 404 City/Region: Lake Goodwin/Center Island
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
Posted: Wed May 18, 2005 9:58 pm Post subject: |
Thanks R-bum. Thats Mcmaster-carr. The extra 'r' seems to be important in linking to the site! _________________ Janet & Chris without CD22 Luna C
Now with Panthera 255 TC
Posted: Wed May 18, 2005 10:21 pm Post subject: |
Luna C wrote: | Thanks R-bum. Thats Mcmater-carr. The extra 'r' seems to be important in linking to the site! |
you mean McMasterCarr - (the s is important too)... we both misspelled it - I edited the link to correct my spelling error.
Luna C
C-Dory Year: 2019
Photos: Luna C
Posted: Thu May 19, 2005 11:09 am Post subject: |
oops. all good now! |
MOOSE
Joined: 07 Nov 2003 Posts: 622 City/Region: Rainy Lake - Int'l. Falls
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
Posted: Fri May 20, 2005 4:57 pm Post subject: |
You may want to edit your post as well, as "misspelled" has two 's's!
(sorry, I couldn't resist; I love this one.)
Al _________________ .....and remember, if the women don't find you handsome, they should at least find you handy. |
Posted: Fri May 20, 2005 7:11 pm Post subject: |
MOOSE wrote: | You may want to edit your post as well, as "misspelled" has two 's's!
Al |
No worries - you got me there. The edit is DUN (I mean done). |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Fri May 20, 2005 10:04 pm Post subject: |
Thanks guys. While you were deciding how to spell McMaster-Carr, I checked out the web site and you are right-a lot interesting stuff. I found a source for o-rings locally but they only had Buna-N which was very hard. I was afraid it would not work. I finally settled on some foam weather strip from NAPA. Seems ok with just a hose test. I'll know more after a good hard rain. Thanks. |
DodgeRam
Joined: 26 Nov 2004 Posts: 199 City/Region: Vancouver Isl. CANADA
Vessel Name: SeaRam
Photos: SeaRam
Posted: Mon Jun 20, 2005 10:33 pm Post subject: |
HI Ken I am glad you mention those leaky Bomar hatchs , on my 22 2005 both side leaks like sieve. My theory is that the surface where the flange is screwed is not totaly level , and the lock mechanism does not tork the door thighted enough. So if you use different O ring and it work please tell us thank you . I love this this C Brat forum. Gary & Sharon |
dogon dory
Posted: Mon Jun 20, 2005 11:08 pm Post subject: |
Mighty Bite
Joined: 02 Nov 2003 Posts: 456 City/Region: Fairbanks, Alaska
Vessel Name: Mighty Bite
Photos: Mighty Bite
Posted: Tue Jun 21, 2005 12:46 am Post subject: |
Ditto on my hatch's. Both leak significantly and from the sound of things a lot of us are candidates for a "group" leak fix. I've had it on my agenda to troubleshoot but have been too busy to get to it as yet. _________________ Mark on Mighty Bite |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Tue Jun 21, 2005 1:56 am Post subject: |
Well the news is not good. I thought I had the leak fixed with the soft foam weatherstrip from NAPA. After a couple of hard rains, it is still leaking. I may have to spring for the manufacturers OEM gasket. It is very spendy. |
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
Posted: Tue Jun 21, 2005 2:34 am Post subject: |
On my 2005 the port hatch leaks but the starboard is fine. I guess I need to see what the difference is between them and maybe the cause the leak will show itself. _________________ Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981- |
