haliman
C-Dory Model: 19 Angler
Posted: Sun Feb 10, 2013 8:01 pm Post subject: 2008 19 Angler coaming box and downrigger mount install pics |
Hello all you 19' owners. I thought I would post some pics of my install of my coaming boxes and Cannon downrigger mounts/bases I did this weekend. If you have any questions please message me and I will answer best I can. I have also replaces both tanks so can give so help on removing them. The whole reason for the coaming boxes was to get access to mount the downrigger bases . Had to have acesss to get the nut and body washer on. I figured if I had to cut the boat up I might as well install something useful.
Cheers!
chromer
Joined: 27 Jan 2006 Posts: 952 City/Region: Anacortes
Photos: Checkpoint II
Posted: Sun Feb 10, 2013 8:16 pm Post subject: |
Nicely done _________________
Checkpoint II (SOLD 10/2020)
Alure Bertram 28 |
Lipidman
Joined: 18 Sep 2012 Posts: 31 City/Region: Campbell Creek
Vessel Name: Thisaway
Photos: Bobby Lou
Posted: Mon Feb 11, 2013 8:31 am Post subject: |
Very nice and quite useful. Where did you get the inserts? |
haliman
Posted: Mon Feb 11, 2013 10:36 am Post subject: |
Lipidman wrote: | Very nice and quite useful. Where did you get the inserts? |
Boatoutfitters but you can get them from SSI plastics who is the maker of them. They are about $86.00 a piece. |
DuckDogTitus
Joined: 31 Jan 2013 Posts: 1034 City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
Posted: Mon Feb 11, 2013 1:56 pm Post subject: |
very good idea and clean looking install!
next picture should be the first fish! _________________ Dustin |
Doggyjazz
Vessel Name: Chase.n.Me
Photos: Chase.n.Me
Posted: Sat Nov 28, 2015 11:51 am Post subject: |
Hello,
When you cut into the side of your boat, are there any wires I need to be aware of when I get my jigsaw out to also install an access port ?
Thanks
My Scotty down-rigger base only has screws into the fibreglass and I want to attach some wood underneath so I can bolt it down. It would be a sad day if I snagged up and saw my scotty get tipped out and into the deep ! |
Posted: Sat Nov 28, 2015 12:28 pm Post subject: |
Normally there are no wires or cables on the port side. Starboard there will be both the steering and shift cables, Plus a bundle of wiring. There are several options. I would either look thru the lazerette on the Starboard side. This is a case where the Fein saw can be used if you are cutting square or rectangular access. For circular, a Rotozip on a radius attachment, with the bit, set only 1/8" deeper than the glass. Another option is a hole saw to start with, and then you can look inside to be sure where the cables are. The cables should be secured under the deck outboard, with clips or screwed down wire ties. _________________ Bob Austin
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Sat Nov 28, 2015 12:40 pm Post subject: |
Doggyjazz wrote: | Hello,
<snip> |
I know Bob mentioned this, but be careful. I have distinct memories of replacing a wiring harness on a helicopter tail boom after a metal smith drilled out a row of rivets. The bit went through the wires about every two inches, over a distance of several feet. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
