Finishing Plywood Edges
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun May 08, 2005 12:10 am    Post subject: Finishing Plywood Edges Reply with quote
I am in the process of building drawers in the old ice-box hole. I purchased a sheet of the Decraguard plywood to use. The question: does anyone know what the factory uses on the raw edges of the plywood? It is a perfect color match to the surface finish on my 2002 cruiser. I have noticed on later models most edges were teak trimmed, but on mine they painted something on all the edges. Any ideas appreciated.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
AnchortownJim
Vessel Name: Coho
Photos: Coho
PostPosted: Mon May 09, 2005 1:28 pm    Post subject: Reply with quote
Ken,
When I did some work on my boat, I just took a piece of the Decraguard to the local Home Depot and had them do a color match. Then then mixed me up a quart of perfectly color matched latex paint that I used on the plywood edges. All came out great.
CAVU
Vessel Name: CAVU
Photos: CAVU
PostPosted: Mon May 09, 2005 9:46 pm    Post subject: Reply with quote
Thanks for the reply Jim. I will give it a try.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Mon May 09, 2005 9:58 pm    Post subject: Reply with quote
You might also check the iron on edge strips also available at Home Despot. Usually back where the melamite boards are sold. The off white color is a pretty good match.
Knotty C
City/Region: Vancouver, WA
Vessel Name: Knotty C
Photos: Knotty C
PostPosted: Mon May 09, 2005 10:02 pm    Post subject: Reply with quote
Does anyone know where Decragaurd can be purchased in the Portland Or area?
gotjm3
City/Region: Middle River
State or Province: MD
Vessel Name: C's the Day
Photos: C's the Day
PostPosted: Tue May 10, 2005 1:05 am    Post subject: Reply with quote
On woodworking projects the iron on edging has worked very well for me. More choices are available at WoodCraft and Wood Workers Warehouse than the big boxes. Using a flush trim bit on a router or roto-zip type tool makes for a neat trim job if iron on edging is on center which should put edges just proud enough to trim. They also have an edge trimmer with a razor blade in a right angle housing so edge is square. Have the edges trimmed tight is important so it can't be pried off if someone should catch a loose edge. Good luck on the project.
TJ + Jen
Hailing from Middle River, MD
(A drinking town with a boating problem...)
CAVU
Vessel Name: CAVU
Photos: CAVU
PostPosted: Tue May 10, 2005 2:22 am    Post subject: Reply with quote
Thanks everyone for the ideas. I will probably go with the paint. I would think the veneered edges on drawer fronts might get chipped or picked loose. If I can get a good paint match, the job would be quick and easy and would match the edges of the galley cabinet doors. Thanks.
Page generation time: 0.0314s (PHP: 59% - SQL: 41%) - SQL queries: 20 - GZIP disabled - Debug on
