plz help with a non c dory question on kicker mountaing
kaosk
City/Region: lake almanor
C-Dory Year: 1992
C-Dory Model: 14 Angler
Vessel Name: Gansy
PostPosted: Sat May 07, 2005 3:52 pm    Post subject: plz help with a non c dory question on kicker mountaing Reply with quote
i just bought a 9.8 nissan 4 strk mechanic installing is saying my transom wont hold the weight he is trying to install it with a swing bracket type mount and says i have to take off kicker when i tow it is that normal or can i mount it with a stationary bracket can i leave when in tow 82 lbs is too much to have to put on and off i have a 86 bayliner trophy center console any help plz thx guys and i wish i had a c dory but all i could afford
PostPosted: Sat May 07, 2005 6:08 pm    Post subject: Reply with quote
kaosk-
1. If we knew what brand, type, and model the bracket was, we could look it up and see what at maximum kicker weight it was rated for and compare it to your kicker weight.
2. It might also be that your mechanic doesn't think the bracket is anchored well enough in your transom to take the weight, even though the bracket may be rated for the weight of the motor. This might be due to the way he had to mount it, or the construction and strength of your transom.
So it would seem that we can't really answer the question on the information we have at the present. Joe.
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sat May 07, 2005 7:56 pm    Post subject: Reply with quote
Kaosk, Try posting your question here http://pub12.ezboard.com/bbocweb
Pete
kaosk
C-Dory Year: 1992
Vessel Name: Gansy
PostPosted: Sun May 08, 2005 3:35 pm    Post subject: Reply with quote
the mechanic is saying its my transom that wont take the weight the bracket is ratted for up to 115 lbs he also says he cant get inside the transom to reinforce it due to just a very small hole for access he still says he will be able to mount it but i will have to take it off when i tow i will be using it at lake almanor and i live bout 10 min from lake so its not a long haul but i was thinking a transom saver or a 2 by 4 cut to make a makeshift support
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Sun May 08, 2005 3:59 pm    Post subject: Reply with quote
If he is worried about towing it with the motor on the bracket I would be worried about simply using the motor! The torque the motor can apply can be tremendous.
I would be very concerned with the mounting if the interior bolts aren't reinforced. I would want a metal strap (or aluminum angle) between the two upper bolts on the bracket if at all possible. Barring that I would want the largest possible fender washers on the bolts. You are going to have far less stress applied to the bottom bolts but even they should have at least some large fender washers.
Gary Johnson
KB7NFG
kaosk
C-Dory Year: 1992
Vessel Name: Gansy
PostPosted: Sun May 08, 2005 4:32 pm    Post subject: Reply with quote
that is what he was saying he is gonna put some metal strips on do they have to be in the inside of transom or on the outside by bracket he also said the main reason i have to take off the kicker when trolling is it said it in the manual with kicker i looked online and it says it can be taken off not that u have to take it of for trolling its a 2005 nissan 9.8 4 strk long shaft manual start/tiller by the way thx for all ur guys input )
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Sun May 08, 2005 5:18 pm    Post subject: Reply with quote
The strap has to be on the inside to do any good. You need to distribute the load across the bolts.
If this is a bracket that gets raised and lowered just leave the kicker in the down position. It should be no more stress than running the motor.
Page generation time: 0.0459s (PHP: 45% - SQL: 55%) - SQL queries: 20 - GZIP disabled - Debug on
