Survey: problems with fuel tank holddown system
dogon dory
Vessel Name: DogOnDory
PostPosted: Mon May 02, 2005 1:01 am    Post subject: Survey: problems with fuel tank holddown system Reply with quote
PostPosted: Mon May 02, 2005 5:18 am    Post subject: Reply with quote
Dan-
When I bought my "87 Cruiser used in "98, both the starboard tank's forward cleats were loose. I cleaned out the holes and some very minor rot, filled the spaces with Marinetex epoxy, and jammed oversize sheet metal style stainless screws in the holes, using the hydraulic pressure of the screws to push the wet epoxy into the spaces. No problems after 7 years. None of the other cleats has ever loosened up. Good survey idea. Joe.
PostPosted: Mon May 02, 2005 9:30 am    Post subject: Reply with quote
We either did not have any problems, or were not aware of them, for the two years we owned our CD22...
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Mon May 02, 2005 4:49 pm    Post subject: Reply with quote
1. Yes
2.2002
3.2004
4.Front and side starboard tank- no problem on the port tank.
5.Minor softening of the balsa about 3/4" dia around pulled screws.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
flagold
City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
PostPosted: Mon May 02, 2005 6:34 pm    Post subject: Reply with quote
1. Yes
2. 2003
3. 2003
4. Screws loosened, tanks bulged, no rot, sealed and re-installed screws.
Mr. Fisherman
Vessel Name: Sea Lion
Photos: Sea Lion
PostPosted: Tue May 03, 2005 12:43 am    Post subject: Reply with quote
Yes,
1995
2004
Both
welded new supports to the tank and lagscrewed them into the deck and sealed with 5200. Some have pulled out and I need to come up with a better repair.
Live to Fish
Fish to Live
C-Sick
City/Region: Renton
C-Dory Model: R-25 Tug
Vessel Name: Gratitude
Photos: C-Sick
PostPosted: Fri Jul 22, 2005 2:02 am    Post subject: Add Another 2003 Reply with quote
I just noticed on my return trip from Blakely that my Port Side front chalk is pulling out. I will have to explore the damage that might be done.
2003 22ft Cruiser
C-Sick
In A Bad Way
Mr. Fisherman
Photos: Sea Lion
PostPosted: Fri Jul 22, 2005 2:09 am    Post subject: Reply with quote
1. Have you had a problem with the screws pulling out that hold the cleats/chocks in place around the fuel tanks? Yep. A 58 gallon tank held in place by 6 #8 screws was just plain crazy.
2. When was the boat built? 1995
3. If you've had the problem when did it show up? While I was out halibut fishing last year.
3. Which chocks came loose? Front, sides or both. One tank or both? Screws pulled out on the Port side then the weld on the tank support started to tear.
4. Have you noticed any rot in the holes that the screws backed out of? Nope, I filled them in with 5200.
Page generation time: 0.0268s (PHP: 67% - SQL: 33%) - SQL queries: 25 - GZIP disabled - Debug on
