Sea Angel
Joined: 29 Dec 2003 Posts: 736 City/Region: Virginia Beach, VA
Photos: Sea Angel
Posted: Fri Oct 19, 2012 11:30 am Post subject: |
Tom,
You are correct as to the setup of the CD25 cover. The cover does go inside of the side rails (but snaps along the gunwale). It is set along the forward top inside of the splash well, along the gunwales, up the sides of the cabin and across the roof, forward of the the molded lip above the cabin door.
The full camper back on Sea Angel shares all the snaps that are used with the mooring cover. It is a very tight cover when set.
Hope I did not confuse you.
http://www.c-brats.com/modules.php?set_albumName=album607&id=Bartlett_1&op=modload&name=gallery&file=index&include=view_photo.php
Maybe this will help. Here is a photo of Sea Angel and crew. Notice the snaps along the rails and splash well as well as how the top is snapped to the roof.
Art _________________ Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4 |
Posted: Fri Oct 19, 2012 8:45 pm Post subject: |
HI Tom,
I know the 25 has the rails and is set up differently. OK. The same principal apply. If I was doing a mooring cover, I would want it tight, snug and cover everything.
See how this one is not so tight, and fits inside the cockpit? I would look to avoid that. I would probably figure a way to run a line, (1/4" nylon, temporarily -- for when the cover is being used -- that would help support the weight, -- wet, leaves, or snow load -- aside from just the snaps.
On my cover, (that goes over the bow pulpit), it has reinforcement for the rails, cleats and the radar, and the same could be done on the 25. I would run a single line from the handrails on the cabin top, down to outside the splashwell, and do that on each side of the cockpit. And then I would run a second set of lines from the same handholds on top diagonally across the cockpit to the opposite corner, again to help support the canvas load.
If you are making this cover, or having it made, you have some input in how it is done and how well it will work. Make sense
SleepyC _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Sea Angel
Photos: Sea Angel
Posted: Sat Oct 20, 2012 4:22 pm Post subject: |
Tom;
If it would help I will try to remove my camper back and mount the cockpit cover. The cover has been several years in storage and I have to get my hands on it. Hopefully any pixs I can get will answer all your questions. This hopefully will be next week, as long as I find my "Note To Self" (old man stuff ). Besides, I should have a pix of it for my documentation.
I do remember how challenging it was till it got stretched a little for the fitting. The factory cover serves as both a mooring and travel cover. When it was in use I did not have any water, or stuff, in the cockpit or bilge.
Harvey is absolutely right as to the setup needs. I think the pix displayed above does show the snap locations along the rails to allow for a tight fit. The owner seems to have left the canvas loose for access, at least while he appears to be retrieving the boat toward a dock or ramp. ( Just an opinion.)
Art |
Tom on Icarus
Joined: 15 Sep 2007 Posts: 175 City/Region: Campbell River, Vancouver Island
Vessel Name: Tranquil~C
Photos: Tranquil~C
Posted: Sat Oct 20, 2012 10:49 pm Post subject: |
Art,
Please don't go to any trouble to find and deploy your mooring/travel cover. I see the snap pattern at the stern in your pics and I think I can figure it out.
I just thought if someone had pics, already taken, I could see them.
Really, a good canvas maker should be able to figure it out.....you're right.
Thanks everyone for your help.
Cheers,
Tom _________________ 22 Cruiser "Icarus" 2005 - 2011
25 Cruiser "Tranquil~C" 2011 - 2019
30 Commander (to be named) 2019 - |
