Source for square drive screws around interior window frames
Malia Kai
City/Region: Hawi
State or Province: HI
C-Dory Year: 1994
Vessel Name: Malia Kai
PostPosted: Wed Sep 26, 2012 4:42 pm    Post subject: Source for square drive screws around interior window frames Reply with quote
It's time for me to replace much of the hardware on my '94 22' cruiser. Many of the square drive screws on my window frames are rusting and need to be replaced. They are square drive, flange head(also called truss head, stove head, or oven head) and probably stainless steel sheet metal screws. I've done multiple google searches and cannot locate this type of screw anywhere. I tried ordering some pan head screws from McFeely's, but the pan head has a significantly smaller diameter/surface area than the original truss heads. Does anyone know where to find these screws???
Thanks.
PostPosted: Wed Sep 26, 2012 5:29 pm    Post subject: Reply with quote
Welcome to the wonderful world of Canadian square heads. That's all you can get in Canada, so those parts made there use those screws. And if you go to Canada, you can buy all you want. And they're proud of it.
What's wrong to changing to Phillips head sheet metal screws? Except for the head, they are the same thread. Slip a washer under the head if you want a larger bearing area. I used a lot of Phillips to replace those around the windows/doors/etc. And I bet you can find those locally.
Here's some truss head, square drive screws: Jamestown
Walldog
City/Region: Port Isabel
State or Province: TX
C-Dory Year: 2014
C-Dory Model: R-27 Tug
Vessel Name: Willie's Tug
PostPosted: Wed Sep 26, 2012 6:24 pm    Post subject: Reply with quote
West Marine has them in small quantities.
Walldog aka Herb Stark
2014 R31 Tug "Willie's Tug"
Port Isabel TX/Ballard WA
http://walldogsjourneys.blogspot.com
Malia Kai
City/Region: Hawi
C-Dory Year: 1994
PostPosted: Wed Sep 26, 2012 6:36 pm    Post subject: Reply with quote
Thanks Boris,
I took a look at the link to Jamestown you provided. Those screws are made by Simpson Strong-Tie and unfortunately they do not manufacture them in lengths shorter than 1" and these screws are 5/8". BTW, do you happen to know the diameter of these, #6, #8, #10?
Yes, I have found multiple sources for phillips flange head stainless screws, but I generally prefer to use square drive or torx drive screws whenever possible as I've stripped out too many phillips head screws.
I found this website, which I think is in England, with 302 stainless screws, I'm just not sure what "gauge" size to order. Would you happen to know?
http://www.shop4fasteners.co.uk/acatalog/Pozi_Flange_Head_Self_Tapping_Screws_Stainless_A2.asp
Bill
PostPosted: Wed Sep 26, 2012 6:48 pm    Post subject: Reply with quote
Well, Bill, my experience has been the opposite, Phillips head has worked great for me. I use a 1/4 ratchet with a Phillips bit so that I can get more pressure on the screw. The ratchet provides the torque and I can lean on the drive. Just getting old.
Also, the existing screws have already cut the thread, so the new ones are easier to drive.
As for size, I found this chart for sheet metal screws:
Size Thread Diameter
Decimal Nearest Fractional
4 0.11 7/64
6 0.14 9/64
8 0.17 11/64
10 0.19 3/16
12 0.22 7/32
14 0.25 1/4
PostPosted: Thu Sep 27, 2012 12:01 am    Post subject: Reply with quote
Call harbor marine is Everett. They have them in stock. I am sure they would ship to you.
1402 W Marine View Dr
Everett, WA 98201
(425) 259-3285
rjmcnabb
City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
PostPosted: Thu Sep 27, 2012 2:25 am    Post subject: Reply with quote
Malia Kai,
Hi. You might try searching for these screws a "Roberts head." Rod
Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later)
C-Green
City/Region: Houghton
Vessel Name: C-Green
Photos: C-Green
PostPosted: Thu Sep 27, 2012 11:34 am    Post subject: Reply with quote
I got some from Diamond Sea Glaze which is Canadian, of course. Harbor Marine sounds sounds less complicated, no customs, tax issues.
goldpan
City/Region: Campbell River
Photos: REEL KNOTTY
PostPosted: Thu Sep 27, 2012 1:00 pm    Post subject: Reply with quote
actually i believe they are robertson screws
former owner of 22 Cruiser
Former owner of 85 32 Farrell
looking for CDory
Malia Kai
City/Region: Hawi
C-Dory Year: 1994
PostPosted: Thu Sep 27, 2012 5:04 pm    Post subject: Reply with quote
Thanks Guys.
I'll pursue the Harbor Marine and Diamond Sea Glass leads and let you know how it goes. B.T.W., they are #8x5/8" sized. I was able to locate my screw size gauge to verify.
Page generation time: 0.0726s (PHP: 49% - SQL: 51%) - SQL queries: 27 - GZIP disabled - Debug on
