glennmarina
Joined: 18 Jun 2009 Posts: 18 City/Region: Vista, Southern California
C-Dory Year: 1982
Vessel Name: La Pesca Dory
Posted: Tue Sep 11, 2012 10:42 pm Post subject: My tanks are shot. Need to replace. Any suggestions |
1982 22' Angler. It had the split 20's in the rear. I would like to go to 80 gal. if possible (made be up the center). Has any done this type of up grade? Or should I just get the same ones re-made?
glenn |
Posted: Wed Sep 12, 2012 12:27 am Post subject: |
I can't speak to 80 gallons, or specifically to your generation of Angler -- which may render this info pointless since I think the splashwell is different, but just in case -- I can tell you that the Moeller port and starboard 23-gallon tanks that fit under a post-1986 22 Cruiser are available and can be purchased through any Moeller dealer. They are in the neighborhood of $250 apiece. There are drawings of them in my album if you want to take a look at them. These are the tanks that are being put in the new 22's now, and were also used in some of the 2000's 22 Cruisers (mid- to late-2000's, I believe). |
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Wed Sep 12, 2012 1:54 am Post subject: |
Your best bet will be a custom Aluminum tank. The early anglers are entirely different than modern boats in the transom area--and you can rework the entire area to accumulate this size tank. However, 80 gallons is a lot of fuel--about 500 lbs vs the 36 or so gallons which were there.
I have seen several boats with a single aluminum tank of at least 50 gallons, so 80 is certainly do-able. Another option is two 20 gallons aft, and then 20 under each gunnel in saddle tanks. _________________ Bob Austin
Joined: 07 Nov 2003 Posts: 7892 City/Region: marysville
Posted: Wed Sep 12, 2012 10:36 am Post subject: |
catch -22 built saddle tanks for his older angler. not sure how many gallons but more then 20 each. look in his album. _________________ Thomas J Elliott
Discovery
Joined: 08 Dec 2003 Posts: 1240 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Wed Sep 12, 2012 10:52 am Post subject: |
Glennmarina,
I bought saddle tanks from Overtons. Not sure of the maker. I covered them with sheet aluminum. 20 gal/side.
This was on a 1984 Angler. The original tanks were two 12 gal. steel tanks under the motorwell. This gave me a total of 64 gal. if needed. I eventually put the batteries under the motorwell and just used the saddle tanks. _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
Posted: Wed Sep 12, 2012 2:43 pm Post subject: |
Thanks for posting that photo. I can see that the tanks made for a "modern" 22 Cruiser would be totally out of place. I like the look of that access to the transom you have with that boat - nice set up. |
haliman
C-Dory Model: 19 Angler
Posted: Wed Sep 12, 2012 5:24 pm Post subject: |
I just replaced my tanks in my 2008 19' Angler. Moeller 23 gallon tanks, FT2339 AND FT2340 are the model numbers. Bought them from Fisheries Supply in Seattle. $201.98 a piece. |
Posted: Wed Sep 12, 2012 5:34 pm Post subject: |
haliman wrote: | I just replaced my tanks in my 2008 19' Angler. Moeller 23 gallon tanks, FT2339 AND FT2340 are the model numbers. Bought them from Fisheries Supply in Seattle. $201.98 a piece. |
Those part numbers are the same tanks I mentioned above -- turns out they're more optimized for the "modern" splashwell/cockpit set-up. |
Posted: Sat Sep 22, 2012 8:25 pm Post subject: |
Moderators, please move this out of the For Sale forum. Thanks. _________________ CHARLIE and PENNY CBRAT #100
K4KBA |
