Radar Removal
Goto page 1, 2, 3, 4, 5  Next
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Mon Aug 27, 2012 6:30 am    Post subject: Radar Removal Reply with quote
I just removed the monitor and monitor bracket for my old radar. To remove the Radar dome do i just cut the cable as short as possible/remove the four ( 4 ) . bolts that secure the dome to the cabin roof and pull.Is there anything else beside sealant holding the dome down. Tug
PostPosted: Mon Aug 27, 2012 6:34 am    Post subject: Reply with quote
As long as you plan to junk it Tug, cut the cable. As far as sealant goes Question , kinda hard to see from here. Rolling Eyes
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Mon Aug 27, 2012 6:37 am    Post subject: Reply with quote
Charlie . thanks...now i can go fishing. Cool Tug
PostPosted: Mon Aug 27, 2012 10:38 am    Post subject: Reply with quote
Cutting the cables trashes the radar, which is OK. Another approach is to remove the radome, disconnect the cable from the inside and feed it back through the hole in the (I assume) cabin top.
Either way will work, just depends on the purpose.
PostPosted: Mon Aug 27, 2012 10:46 am    Post subject: Reply with quote
Tug-
I don't know how far north Issac will get before it dissipates after landfall, but you might want to plug that hole if you think it's gonna' rain!
PostPosted: Mon Aug 27, 2012 11:33 am    Post subject: Reply with quote
Sea Wolf wrote:
Tug-
Thumbs Up Thumbs Up Duck tape!
Hope the Midwest gets some of that rain!
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Mon Aug 27, 2012 1:46 pm    Post subject: Reply with quote
Removing the cables intact could well make your used systems worth some money on e-bay. You never know what people are looking for out there.
Testosterone Tales-Amazon.com
KG7RC
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Mon Aug 27, 2012 5:48 pm    Post subject: Reply with quote
I did just that...i removed the Radome and disconnect all those little snap connections and feed the cable thru the hole in the roof.When i removed the Radome i was surprise how clean and new it looked..really sparkled.Tommorrow i will seal the holes with West System Epoxy, remove the wiring from the boat and store it in the basement with everything else. It's probably an easy fix if some-one wanted to buy it but i don't know how you would go about shipping something this big. Tug
PostPosted: Mon Aug 27, 2012 10:38 pm    Post subject: Reply with quote
Tug, don't seal the hole up until you get your new radar and see if you can use the old hole. Tape it up and wait! Thumbs Up
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Tue Aug 28, 2012 7:24 am    Post subject: Reply with quote
Charlie..thanks for the tip...i went out and measured. The Si-Tex holes are approx..210 mm and from the Furuno 1715 on-line operators manual the new holes are approx. 160 mm. Tug
PostPosted: Tue Aug 28, 2012 7:29 am    Post subject: Reply with quote
You can always use "more hole". What if you want to put it on a pedestal and run other cables through there too?
PostPosted: Tue Aug 28, 2012 8:44 am    Post subject: Reply with quote
That old Si-Tex is worth something if advertised as "parts." Someone will want to fix theirs.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Tue Aug 28, 2012 9:15 am    Post subject: Reply with quote
Had to cut the 10 meter cable...the wiring and electronics must of been installed when the boat was new...The cable was so interwound with the other wiring i was afraid that i would damage the existing wiring.
Good idea ..i will advertise it on Ebay.. Tug
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Aug 28, 2012 10:32 am    Post subject: Reply with quote
WOW 210 mm is over 8" hole Shocked
Brent Barrett
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Tue Aug 28, 2012 1:22 pm    Post subject: Reply with quote
Probably means hole pattern, right? 160mm square vs 210mm square.
Page 1 of 5
Page generation time: 0.0525s (PHP: 65% - SQL: 35%) - SQL queries: 32 - GZIP disabled - Debug on
