wheel
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Aug 25, 2012 2:24 pm    Post subject: wheel Reply with quote
Our boat has this wheel
I would like to get one like this
Is it easy to make the switch? What make and/or model is it? Does anyone have a used one for sale?
MartyP
PostPosted: Sun Aug 26, 2012 12:18 pm    Post subject: Reply with quote
Marty,
Sports car to battle ship Question Wink
I don't know about changing wheels, but I have change the hub and I did sleep in a Holiday Inn once Embarrased
PostPosted: Sun Aug 26, 2012 12:40 pm    Post subject: Reply with quote
Marty-
You can buy a wheel like that at most marine outlets. It's called a "destroyer" style wheel. There are tons of them on eBay for cheap (Chinese origin). These will work just fine.
Most modern marine wheels for runabouts have the same spline and shaft pattern, at least as far as I know.
One note of caution: Wheel diameters can run from 11 to over 15 inches. Be sure there will be enough room for your thighs under the new wheel.
Are you planning on adding a "suicide"/"necker" knob on the new wheel? (More clearance required!)
Good steering!
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Aug 26, 2012 12:45 pm    Post subject: Reply with quote
m2cw
I like your current wheel and would add a steering knob and jazz up the wheel hub with a wood insert with the ship's name
Brent Barrett
Writer_Ron
City/Region: New Bern
Vessel Name: Muse
Photos: Muse
PostPosted: Sun Aug 26, 2012 4:37 pm    Post subject: Re: wheel Reply with quote
I believe the wheel you want is made by Sea Dog, and is available at lots of marine distrubutors. I understand that it fits the standard tapered shaft that protrudes from typical hydraulic steering "helm" units.
Given that the wheel of your dreams is the same (I'm fairly certain) "standard wheel" in our CD-25, I suspect changing over is any easy chore.
But ... do you really want to? The spokes on our wheel are showing some rusl-like corrosion, which is kinda odd for a stainless steel wheel. We've actually had thoughts of replacing our wheel with a good destroyer wheel.
Ron
Page generation time: 0.0372s (PHP: 63% - SQL: 37%) - SQL queries: 18 - GZIP disabled - Debug on
