Flushing muffs on '08 BF50 - no go
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Thu Jul 26, 2012 3:42 pm    Post subject: Flushing muffs on '08 BF50 - no go Reply with quote
Ran into something interesting with the new-to-me BF50 today. I can't use traditional ear muffs on it.
I hooked them up covering the water intake, just as I do on my BF90 - but the engine, she no pee. The stream was there and strong last night while putting around the marina. I readjusted the muffs and water pressure just to make sure, and tried again - nope. Less than a minute overall running, so hopefully no impeller damage.
I Googled a bit, and seem to find some BF40/50 users have no problem with the muffs, but saw a couple other posts indicating there's a third pickup underneath the cavitation plate - somewhere the muffs don't cover.
Sure enough, I got out a tub and filled it with water - and upon submersing the engine and firing it up, it spit out water immediately.
Anyone else encounter this? The tub method isn't a big deal, but it's certainly a little less convenient (particularly on the road) than the muffs.
Tux Will, C-Brat Nerd Tux
Ray
City/Region: Pamlico River
Vessel Name: Seaweed
Photos: Seaweed
PostPosted: Thu Jul 26, 2012 4:05 pm    Post subject: Reply with quote
I have an Evinrude 50 on my fishing skiff with the same thing.
Just put a piece of blue painters tape (easily removable) over the cavitation plate intake when using the muffs. The motor will then draw (enough) water through the muff intakes alone.
The hard part is remembering to take the tape off!!!!!
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Thu Jul 26, 2012 5:00 pm    Post subject: Reply with quote
Bill, I try to always use a flush bag (Specialty Marine Products?) instead of a set of mouse ears. I cooked an impeller on my BF 8 a couple of years back while using the ears.
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Thu Jul 26, 2012 6:39 pm    Post subject: Reply with quote
Thanks, Steve - those bags look slick. A cheap Rubbermaid tub works great at the house, but might need to pick one up for the road trips.
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Thu Jul 26, 2012 6:44 pm    Post subject: Reply with quote
Like Ray, I just put tape over the lowest intakes on the BF50 I had on my CD-16. Worked fine. I used BRIGHT yellow duct tape, and left one very long tail piece of the tape running up the lower unit so it would be hard to forget to remove it.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Wandering Sagebrush
PostPosted: Thu Jul 26, 2012 7:56 pm    Post subject: Reply with quote
Bill, I like them a lot. Word of caution... if you put a Permatrim on, be sure and measure twice to get the right size. Mine is a bit of a stretch on the BF 90 with Permatrim.
Page generation time: 0.033s (PHP: 60% - SQL: 40%) - SQL queries: 19 - GZIP disabled - Debug on
