SS PROP
jerryb6647
PostPosted: Sun Jul 01, 2012 12:52 pm    Post subject: SS PROP Reply with quote
Hi C-Brats . I have a 19 feet C-Dory with a BF90D Honda ,i cruise at 4100 rpm and don't tow a dinghy . i like to put on a SS Prop .What do you C-Brats recommend .Thanks for you help. Jerry
PostPosted: Sun Jul 01, 2012 2:39 pm    Post subject: Reply with quote
If you like how the boat performs now, why not use the same dia and pitch? Use the alum one as a spare.
PostPosted: Sun Jul 01, 2012 2:41 pm    Post subject: Reply with quote
The SS will flex slightly less, but probably can go with the same size. What is your speed at 4100, and what is the WOT RPM and speed?
berryst
City/Region: Kingston
C-Dory Year: 1985
Vessel Name: Margaret Ann
Photos: Sea Major
PostPosted: Sun Jul 01, 2012 8:50 pm    Post subject: Reply with quote
stainless performs a little better
If you have a prop strike stainless may blow your bottom end
If you have a prop strike with aluminum you will loose the prop
Chris
The road to hell is paved with good intentions
TOGO
City/Region: Newport
C-Dory Model: 19 Angler
Vessel Name: TOGO
Photos: TOGO
PostPosted: Sun Jul 01, 2012 10:05 pm    Post subject: Reply with quote
I have a 19' angler with a BF90 Honda and run a 13.5x15 Honda aluminum prop. WOT is just a bit below 6000 RPM. This is with me 160 lb with a heavy crew about 260 lb aboard and 48 gallons of fuel. I work in rivers where 7 ft of water is deep. I usually visit the prop shop at least once a year. I am probably going to change to a composite prop. in the future. They are easier on the lower unit and cost less to repair. I am willing to give up a little performance.
What I am trying to say where you use and what you do is a big consideration in your selection.
Guy
Page generation time: 0.0315s (PHP: 52% - SQL: 48%) - SQL queries: 18 - GZIP disabled - Debug on
