CD22 Storage
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Tue Jun 05, 2012 4:39 pm    Post subject: CD22 Storage Reply with quote
We made two changes over the winter that we were just recently able to test on a five day river trip. Both turned out even better than expected.
The first was removing the foam and adding hatches to the space under the v-berth. This was a pretty big job that we didn't really see much benefit from until it came time to really load the boat up for our trip. The v-berth storage access is really good because you can get to the two main hatches without moving the porta pottie or the mattress. We stored clothes for two people, shoes, tools, spare parts and prop, extra anchor and rode, extra rope and extra life jackets with some room to spare.
The second change was adding a cooler rack made of Trex from Lowe's. For full disclosure, we copied this rack from another C-Brat. It works very well, is solid, required no holes or mounting hardware on the boat, and was fairly inexpensive for a boat accessory. This did a great job of freeing up cockpit space, which is always at a premium on a CD22 with three people and two coolers.
Two pics are below and there are more in our album.
Rob, Karen & Riley
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Tue Jun 05, 2012 4:50 pm    Post subject: Reply with quote
Really, really nice upgrades.
Both home-runs.
I especially like the rack "required no holes or mounting hardware on the boat".
I hope the factory is paying attention.
Pete
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Tue Jun 05, 2012 5:24 pm    Post subject: Reply with quote
I've got 2 Imtra hatches lying around for when I get the time to replace the lazarette hatches. Now I know *exactly* what to do with the old leaky ones!
What kind of tool did you use to cut the fiberglass inside? I was thinking a jigsaw would take big chunks of gelcoat off as it made the cut. Maybe a dremel with a tile cutting tool?
Rob & Karen
PostPosted: Wed Jun 06, 2012 8:21 am    Post subject: Reply with quote
Pete...thanks.
Sean...we used a saber saw with a fine tooth blade. We also covered the glass to be cut with blue masking tape before starting. It is hard to tell if the masking tape helped, but it certainly didn't hurt.
Rob
JGrider
City/Region: Laplace
State or Province: LA
Vessel Name: Jeannie's VOO DOO
Photos: Jeannie’s VOO DOO
PostPosted: Wed Jun 06, 2012 11:35 pm    Post subject: I thought there would be foam on that area. Reply with quote
The added storage looks like something I might want to do. Do you still have the hatch model numbers and what did you find when you cut the opening. I hate surprises and I thought there would be foam in that area.
John & Jeannie Grider
Jeannie's VooDoo
Home port: LaPlace, Louisiana
Rob & Karen
PostPosted: Thu Jun 07, 2012 9:25 am    Post subject: Reply with quote
Hi John & Jeannie,
The hatch is a Bomar / Pompanette G8812 in off-white. Defender's item number is 901303.
The area was pretty much full of foam and it was a big job to remove. After removing the foam, we then had to cut and file the points of any screws and bolts that penetrated from the bulkhead. Finally, we finished it with two coats of paint.
Rob, Karen & Riley
JGrider
PostPosted: Thu Jun 07, 2012 11:22 am    Post subject: Reply with quote
Thanks for your reply. I want to wait for fall to start but I will let you know how this works out for us.
berryst
City/Region: Kingston
C-Dory Year: 1985
Vessel Name: Margaret Ann
Photos: Sea Major
PostPosted: Thu Jun 07, 2012 12:04 pm    Post subject: Reply with quote
very sweet !
Berryst
The road to hell is paved with good intentions
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Thu Jun 07, 2012 4:51 pm    Post subject: Reply with quote
That looks great-- my v-berth access is under the cushons, I may just have to copy that one- thanks.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Thu Jun 07, 2012 7:04 pm    Post subject: CD 22 Storage Reply with quote
Nice job Rob. First one's I have seen with side access. I guess there are pros & cons to everything. With top access, you can cram more stuff in (but have to be able to get it out again!), however you do have to move the v-berth foam and anything else in the way to get at them. With side access two are easy to get at, but the one behind the porta-potti requires work to get at. Installing side and top access could be an option, assuming it does not compromise the strength of the construction fwd.
While we are up in the forpeak. Instead of glassing in the anchor locker and adding a hatch, I was thinking of using starboard, bolted at the bottom, glued and sealed top and sides. Instead of installing a hatch, I am thinking of using a flush round inspection plate (the screw type). Has anyone else tried this? I see them for sale 8" diameter, anyone know if they come in 10" or 12" sizes ?
Martin.
PostPosted: Fri Jun 08, 2012 10:57 am    Post subject: Reply with quote
I've seen some messages in the past about the removal of foam. But I guess I'm a little concerned about removing something that must have had a purpose in the first place. Why is the foam there in the first place, and what effect does it have to remove it? I would love to have more storage if the space is available. Then again, I suspect more storage would just allow me to carry more stuff (weight) that probably isn't really necessary. Colby
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Fri Jun 08, 2012 2:40 pm    Post subject: CD22 Storage Reply with quote
My 22 cruiser, 2009 model came brand new with no foam and 3 hatches installed. So I guess the factory have OK'd no foam.
Martin.
Pandy Girl
City/Region: Westfield, NC
Vessel Name: Pandy Girl
Photos: Pandy Girl
PostPosted: Fri Jun 08, 2012 10:28 pm    Post subject: Reply with quote
Hi Rob, Those looks great I have got get on the Ball & Start doing some of those on ours. I purchased a new Seat but have not got it instaled yet. I will post Pic when I get it done.
Pandy Girl
Page generation time: 0.056s (PHP: 61% - SQL: 39%) - SQL queries: 26 - GZIP disabled - Debug on
