Extra Hose?
Ray
City/Region: Pamlico River
Vessel Name: Seaweed
Photos: Seaweed
PostPosted: Mon May 28, 2012 6:16 pm    Post subject: Extra Hose? Reply with quote
Hi all! Newbie, here.
So I see that my new-to-me Honda BF150 on my new-to-me CD25 has an
extra hose and filter/one-way valve with a barb hanging out the end. There does not seem to be any mating hoses anywhere in the vicinity. The freshwater flush hose connector is separate, the fuel like is there, the throttle cables are there, there are two other "vacuum" type hoses there and connected (speed and ??). What is this extra one for?
I haven't had a chance to run the engine yet, so I guess this would be a good time to get some input on this hose.
Can any of you clue me in as to what this hose is for, and whether it should be terminated somewhere important?
Thanks for any input,
Ray
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon May 28, 2012 6:49 pm    Post subject: Reply with quote
Most likely a pitot tube hose to run a line up to a pressure speedometer.
PostPosted: Mon May 28, 2012 7:11 pm    Post subject: Reply with quote
The pitot tube does come out of that rubber pass-thru grommet. It's called the "speed sensor tube A" according to the manual.
I'd pull the motor lid, look at the other side of that grommet and see where the tube goes. If it heads down under the engine, into the lower leg, that's it. Next I'd see of there is a matching tube coming back from the instruments. It may have gotten disconnected. If not, and the tube is unplugged, there'll be water coming out of it when you're moving. So see if the end is plugged to keep water from spraying over the back of the boat when you're under way.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Mon May 28, 2012 7:22 pm    Post subject: Reply with quote
A wild card would be a carb vent hose. (If the engine in carbed). Looking at the tiny hole in the end of the fitting makes me think that the hose IS terminated with that fitting for some magic purpose. It isn't a nice big hole...at least the barbed fitting doesn't look like what you'd normally see as a "splice" type barbed fitting. Could also be an ambient air pressure sense point because of the possibility of wildly varying ambient pressures inside the cowling???? Ah the mysteries.
In any case, I'm betting that it doesn't go anywhere and that it is good as it is, for whatever purpose.
Testosterone Tales-Amazon.com
KG7RC
JGrider
City/Region: Laplace
State or Province: LA
Vessel Name: Jeannie's VOO DOO
Photos: Jeannie’s VOO DOO
PostPosted: Mon May 28, 2012 10:02 pm    Post subject: Reply with quote
I have the same looking thing coming from the lower unit of 2005 Honda 75. Always thought it was for a speed indicator tube.
John & Jeannie Grider
Jeannie's VooDoo
Home port: LaPlace, Louisiana
PostPosted: Tue May 29, 2012 7:00 am    Post subject: Reply with quote
John, it IS!
Ray
Photos: Seaweed
PostPosted: Tue May 29, 2012 8:24 am    Post subject: Reply with quote
Thanks, guys!!!
Page generation time: 0.0338s (PHP: 62% - SQL: 38%) - SQL queries: 24 - GZIP disabled - Debug on
