PvL
Joined: 27 Jun 2011 Posts: 44 City/Region: Sunshine Coast
Vessel Name: Lately
Photos: Latley
Posted: Sun May 06, 2012 10:26 pm Post subject: Comments on mounting a 9.8 Tohatsu on a 22ft Crusier |
I am planning to mount a 9.8 Tohatsu Long shaft (20") on the transom of our 07 22ft cruiser, next to my 90 Honda (port side). Yes I do have trim tabs. Does any one have this set up? If so are you happy with it? I am looking for pros and cons.
Thanks _________________ PvL |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Sun May 06, 2012 11:40 pm Post subject: |
Hi, I had that set up on my old 22, which I sold two years ago. I like the motor for the most part. It ran well, started easy, pull or electric start, idled well. I like that it had a larger altanator then most kickers. There were several time that the batteries died in the night and I was able to pull start the kicker and let the alt run for a hour while I had breakfast and then start the main.
Now for the bad. I had a hard time keeping the engine in the up postion. The release/ catch is not very good. I had to use a bungee cord to keep it in place. That model would be 8years old so maybe they have changed it. Many times in rough water the kicker would fall into the down postion. It was also hard to put the engine in the up postion unless you have long arms and legs, which I do. Susan could never put the motor in the up postion by herself. Its not the act of pulling the motor up but reaching down the side of the motor and releasing the lock. Its a long reach even for me. Most motors have the release on the front of the motor near the handle. The motor idles well but would not hold a set rpm. The throttle lock never held well and the motor would slow down all the time unless you had your hand on the handle. Of all the kickers I have used on others boats I think the yamaha 8 to 9.9 is the best. Hope this helps. _________________ Thomas J Elliott
sculpin
Joined: 13 Feb 2012 Posts: 14 City/Region: Atascadero, San Luis Obispo County
Posted: Mon May 07, 2012 11:55 am Post subject: |
Similar problems with the motor unlatching and falling to the down position. I have the 8 hp. But the motor has worked flawlessly otherwise and I would buy another one, especially for the price. _________________ SJD |
PvL
Vessel Name: Lately
Photos: Latley
Posted: Mon May 07, 2012 5:49 pm Post subject: TOHATSU |
Thanks for the info. Did you use a long shaft and was it mounted on the transom? Did that work ok? |
Posted: Mon May 07, 2012 5:56 pm Post subject: |
Mine was mounted on a plate that was mounted in the motor well. should be able to find a pic in my album. I had les at E.Q. do the install if you need advice on how. Les is always willing to talk about how he did some thing. |
Matt Gurnsey Dealer
Joined: 11 Nov 2008 Posts: 1532 City/Region: Port Orchard
Photos: Kitsap Marina
