Solesurfer
Vessel Name: Cheers
Photos: Cheers
Posted: Sun Apr 15, 2012 12:27 am Post subject: Steering System Keeps Turning - Low Oil Level? |
Greetings Everybody,
We have a 25 cruiser with twin Honda 90's and Seastar hydraulic steering. I've noticed than when steering, the wheel doesn't stop, but keeps turning even though the engines have reached their limit. To steer the opposite direction you have to 'unwind' the wheel until you hear the steering click and the motors turn again.
I just finished taking a engine maintenance course and I asked my teacher about it. He said that the steering system might be low on fluid. I don't quite understand how the steering system being low on fluid could bypass the stops, but then again I'm not to mechanically inclined.
I did unscrew the screw on the helm and noticed that I could see some mechanical parts. I'm very hesitant to do anything as I'm afraid I might make it worse. But could the remedy for the problem be so simple that I just need to top off the fluid?
Thank you,
Tom |
Joined: 07 Nov 2003 Posts: 7881 City/Region: marysville
colobear
Photos: C-Cakes
Posted: Sun Apr 15, 2012 11:23 am Post subject: |
If your wheel just spins for a while and then seems to "catch" and work properly you are likely low on fluid. A good diagnostic would be to put a little more fluid into the helm filler and see if that fixes the problem. It does not take very much fluid. Baystar is helpful with advice. I'd be sure to use their fluid instead of some other hydraulic fluid. My Baystar system did just that and I had to replace a seal at the helm. Another place to check is back at the steering ram, the hydraulic piston that moves the engine, for leaks at either side. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Sun Apr 15, 2012 2:28 pm Post subject: steering |
Check for leaks at the helm then in back of steering wheel then at the engines .If no leaks ? then add fluid at helm and bleed system at the back by the engines this will get all the air out of the system tighten everything and then check again for leaks .
My Baystar system leaked from the helm I bought the steering seal and put it in ( had to pull steering wheel ) then had system bled of air and it was good to go no more leaks. Good Luck Jim _________________ retired 8/08 from UAL, still working pt tm
Posted: Sun Apr 15, 2012 2:49 pm Post subject: |
As above, I would bleed the system, adding fluid. You mention twin engines. How are they tied together? If the liquid tie bar, it will be different than with a mechanical linkage. Also you need the heavy duty helm station, if you do not have it already. _________________ Bob Austin
Posted: Sun Apr 15, 2012 4:09 pm Post subject: |
The Seastar/Baystar helm is nothing but a pump with check valves to direct the pumped fluid in either direction (port or starboard,) depending on the direction you turn the wheel.
That pump is positive displacement. So if you've reached the limit of the engine swiveling and the engines stop whilst the wheel keeps turning, you're pumping air, as opposed to fluid. That's bad. So center the engines (engine cylinder in mid position) and then check and add fluid into the helm pump. The top part of that pump is a reservoir, to supply extra fluid for the engine steering cylinder movement. If you open the plug on the top and can see "stuff" inside, it's too low. Remember to center the engines, because the helm/pump doesn't know what center is, it just pumps.
If the steering is still sluggish, you probably have air inside the lines, and you need to have a Seastar dealer bleed the steering.
Good luck, and welcome to the world of hydraulics.
Boris |
Posted: Sun Apr 15, 2012 6:18 pm Post subject: |
journey on wrote: |
If the steering is still sluggish, you probably have air inside the lines, and you needless to have a Seastar dealer bleed the steering.
Boris |
You don't need a dealer to do that, you can do it yourself just follow the instructions. _________________ CHARLIE and PENNY CBRAT #100
K4KBA |
Posted: Sun Apr 15, 2012 6:54 pm Post subject: |
If you have the liquid tie bar, someone who has the electric bleeding system can do it much faster--but for the simple single engine unit, it is fairly easy to bleed. |
naptime Guest
Posted: Sun Apr 15, 2012 7:51 pm Post subject: |
Tom,
Google "seastar steering purging" and you find the manufacture approach for purging air out of a seastar system, both single and dual engine configurations. Also there are YouTube videos of the process. It sounds fairly straight forward. Good luck.
Dick |
Posted: Sun Apr 15, 2012 8:11 pm Post subject: |
Certainly, first try the hand bleeding per the factory instructions. If it's still soft, go see a dealer.
I tried the hand bleeding when I installed an autopilot. There were too many ups and downs (now there's a set of engineering terms) in the hydraulic lines, allowing the air to be trapped and turning the helm pump was too slow to get the air out of the lines.
However you do it, the air needs to come out of the lines. Welcome to the world of hydraulics.
Boris |
Solesurfer
Vessel Name: Cheers
Photos: Cheers
Posted: Mon Apr 16, 2012 1:58 pm Post subject: |
Thank you everyone for the replies. I will definitely look into adding more oil and purging the system of air. Thank you again. |
redbaronace
Joined: 29 Aug 2012 Posts: 581 City/Region: Puget Sound
Photos: redbaronace (Name TBD)
Posted: Sat Oct 25, 2014 12:34 am Post subject: |
colobear wrote: | If your wheel just spins for a while and then seems to "catch" and work properly you are likely low on fluid. A good diagnostic would be to put a little more fluid into the helm filler and see if that fixes the problem. It does not take very much fluid. Baystar is helpful with advice. I'd be sure to use their fluid instead of some other hydraulic fluid. My Baystar system did just that and I had to replace a seal at the helm. Another place to check is back at the steering ram, the hydraulic piston that moves the engine, for leaks at either side. |
Can you elaborate on how you replaced the seal at the helm.
Did you send it to be rebuilt? Or was a rebuild kit available to be ordered?
Thanks, |
colobear
Photos: C-Cakes
Posted: Sat Oct 25, 2014 1:15 am Post subject: |
There is a helm seal kit available from Baystar. I don't know the kit number off hand. The seal I replaced was at the piston in the splashwell, not the helm. By the way, in the baystar manual is a list of other fluids that can be used, most are aviation brake fluids. |
colobear
Photos: C-Cakes
Posted: Sat Oct 25, 2014 12:19 pm Post subject: |
Found the number for the wheel seal kit: seal kit part # HS5147, Note this is for systems with engine power up to 150HP. If you have more HP you have a different system and would need to contact Baystar. |
Posted: Sat Oct 25, 2014 12:26 pm Post subject: |
There are a few MIL spec hydraulic fluids which can be used in place of the (expensive) Seastar/Baystar fluid. Also, please note these are HYDRAULIC FLUIDS, not brake fluid.
First there is Mil-H-5606, a standard hydraulic fluid available at aircraft suppliers. This is what Seastar uses, though now they order it without the red dye. Somewhere they do mention that their fluid is indeed MIL-H-5606.
And there is Mil-H-83282, a synthetic non-inflammable hydraulic fluid backward compatible with Mil-H-5606. This is what I'm going to use when I re-bleed Journey On's steering this winter. Also red dyed.
And finally, for out brothers in Canada, there's Mil-H-87257, which has improved low temperature viscosity and otherwise is similar to Mil-H-83282.
And last, Seastar now offers a SeaStar Power Purge Jr which is a $220 electric purge system. Fortunately I have a Motive Power Brake Bleeder , $35, which I'll use this winter.
Boris |
