ShellBack
Vessel Name: Thalassa
Photos: Thalassa
Posted: Sun Apr 08, 2012 4:29 pm Post subject: Hull ID Number |
Happy Easter Everyone. I wonder if anyone can tell me where to find the hull number on a 22 Cruiser and do you think the factory would offer any history on it.
Cheers Terry |
jkidd
Joined: 23 Oct 2006 Posts: 1615 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2375 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sun Apr 08, 2012 5:12 pm Post subject: |
The HIN is usually on the back of the transom imprinted into the glass. Mine was on the port side if I remember right. That is where it is on the 25. It should read something close to
CDO22 xxx (A-L) xxx
CDO22 stands for C-Dory 22
xxx would be the production number of the boat ie. 065 would be the 65th boat built
A-L is the month of production. A=Jan L=Dec
and the last xxx would be the day (first xx) and the last x would the year.. I may be off on the last xxx. the last two xx's may be the year. ie. 05 = 2005 _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Posted: Sun Apr 08, 2012 5:46 pm Post subject: |
I think the third digit from the last is the year the build was started and the fourth (the letter) is the month. So, for example, if the HIN ended in J708* the build would have been started in October of 2007 and (from the last two numbers) the boat designated as a 2008 model year boat.
Also, I think the builder ID was originally DOR and went to CDO around 2000.
*This HIN scheme started in 1984 and was slightly different before that year. |
ShellBack
Photos: Thalassa
Posted: Sun Apr 08, 2012 6:43 pm Post subject: |
Thanks for the replies. You are a awsome group of people. I have been hunting for awhile and may of found the right one. We shall see ?
Thanks
T |
C-Otter
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: C-Otter
Posted: Sun Apr 08, 2012 8:46 pm Post subject: |
My 1985 has two HIN's, one hidden under the roof overhang (eyebrow) or whatever it's called. I believe it's required> Dr. Bob should know. C-Otter |
Posted: Sun Apr 08, 2012 10:49 pm Post subject: |
Usually the primary HIN is on the Starboard upper transom. The "hidden" is under the eyebrow.
After August, 1984 the HIN are thus:
First three letters relate to the manufacture. C Dory has had a number of different Manufacture Identification codes used for C Dory boats that I know of: DOR, CDO, GXK, MFN, CCR, UWH, MEH, CMC, (several of these are the Venture/Cape Cruiser) The next 5 digits are the serial number. Usually the hull length, and then build number, maybe not in sequence. Next is a letter which is the month of the year and a digit of the year of certification or manufacture. (Usually when the hull is started) Finally two digits model year. _________________ Bob Austin
