Who knows what this is??
Telsta860
PostPosted: Fri Apr 06, 2012 4:01 pm    Post subject: Who knows what this is?? Reply with quote
This is a picture of a mystery devise plumbed into the fuel tank vent line on my 1995 22Angler. I took the picture laying on my back with my head against the dual aluminum tanks looking up under the port gunnel. There's one exactly like it on the starboard side. I called the factory but they have no idea??
[img]file:///C:/Users/Acer/Documents/Pictures/C-Dory/Vent.JPG[/img]
Lately, that is the last few months, I've been having problems with water somehow getting into my fuel and I've convinced myself the intrusion is from the vent lines which are plumbed below the rub rail. Sometimes in taller seas the water washes up over the vent fittings so I ordered a couple of those Perko fuel caps with the vent built in so as to raise it all up to the top of the gunnel and, in the process of beginning the retro I've encountered these.
Since I'm really not absolutely certain as to where the water is coming from, I feel I need to pause for a second and see just what these things are. If they are some sort of water protection thing well...[/img]
PostPosted: Fri Apr 06, 2012 4:02 pm    Post subject: Reply with quote
No picture.
Telsta860
PostPosted: Fri Apr 06, 2012 4:12 pm    Post subject: Reply with quote
Well I followed the Ultimate how to post pictures thread and it didn't work out I guess. I'm out of time so I'll have to try again later, but in the meantime it's a black plastic thing shaped and plumbed kind of like an in line fuel filter. It's located on the vent line about a foot above where it comes out of the tank.
PostPosted: Fri Apr 06, 2012 4:44 pm    Post subject: Reply with quote
Just a guess w/out the pic; but could it be some sort of overflow preventer? A device in the vent line that either notifies you of a nearly "full" tank or contains a check valve of some sort that allows air in but does not allow fuel out.
Dreamer
Photos: Dreamer
PostPosted: Fri Apr 06, 2012 4:47 pm    Post subject: Reply with quote
Just a guess but I have used something like that in the past. It's a whistle that tweets away as the tank is being filled. Because of its shape, when the first drop of fuel reaches it, the whistling stops and you should stop filling at that point. It prevents overfilling and spills. Now, lets see the photo and see if I'm all wet or not!
Dreamer- Sold 25 Feb. 2013
PostPosted: Fri Apr 06, 2012 4:52 pm    Post subject: Reply with quote
http://www.boatingmag.com/gear/marine%20accessories/green-marine-fuel-whistle
Telsta860
PostPosted: Fri Apr 06, 2012 5:30 pm    Post subject: Reply with quote
LOL Thats not it.
Stand by
PostPosted: Fri Apr 06, 2012 6:01 pm    Post subject: Reply with quote
Or a check valve of sorts. Lets air out (vent) and not water in...
PostPosted: Fri Apr 06, 2012 6:04 pm    Post subject: Reply with quote
Mark, air has to go out, not in.... Wink
PostPosted: Fri Apr 06, 2012 6:28 pm    Post subject: Reply with quote
As Homer Simpson would say....DOH! Laughing Embarassed
Grumpy
City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
PostPosted: Fri Apr 06, 2012 7:21 pm    Post subject: Reply with quote
Goes out when you fill it but goes in as the $$$ flow out Shocked
M
Telsta860
PostPosted: Fri Apr 06, 2012 8:15 pm    Post subject: Reply with quote
TA-DAAA!!!
Left is up.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Apr 06, 2012 8:18 pm    Post subject: Reply with quote
When you post a photo, it has to be somewhere on the web for the address to be valid. The address for your photo is on your C drive.
PostPosted: Fri Apr 06, 2012 8:27 pm    Post subject: Reply with quote
VOILA!
Attwood fuel surge protector:
http://www.marineengine.com/products/accessory.php?in=1141675
PostPosted: Fri Apr 06, 2012 8:28 pm    Post subject: Reply with quote
M
Good point. So I was correct...sort of.... Laughing
Page generation time: 0.0539s (PHP: 52% - SQL: 48%) - SQL queries: 32 - GZIP disabled - Debug on
