C-Dory all around light
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sat Apr 02, 2005 10:48 pm    Post subject: C-Dory all around light Reply with quote
The stock C-22 uses a Perko plug in all-around light with the base on the forward brow. The base also serves as a mounting point for the horns. Unfortunately, with a radome installed on a 5" mount, the top of the "all-around" light is almost exactly even with the top of the radome, thus the light pole needs about 5-6" height extension to become "all-around" again or I assume a separate stern light would be needed to comply with CG regs.
I've scoured the catalogs and the web, and it appears Perko does not make a longer version using the same screw down base. One solution would be to simply buy a radome mount all-around light and wire it in, another might be to install a regulation stern light. So what say you folk with radars? How did you solve the light problem? I hate having to basically throw away an $85 all around light just because it's a little short. Anybody ever fabricate an extension for the light?
Mary & Don Anderson
Brat #483
Luna C
C-Dory Year: 2019
Vessel Name: Panthera
Photos: Luna C
PostPosted: Sun Apr 03, 2005 1:24 am    Post subject: Reply with quote
We are in the same boat... er situation. Mike, of Mar T, was pointing this fact out at Jarrell Cove. Not sure what we will do yet. We will be watching this post.
Now with Panthera 255 TC
PostPosted: Sun Apr 03, 2005 10:54 am    Post subject: Reply with quote
I wonder if they mount the anchor light on the radar arch if the arch is factory installed...have to go look at the new Laurna Jo, we will have time to have C-Dory do that I guess...
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sun Apr 03, 2005 11:56 am    Post subject: Reply with quote
Pat, We should have two mountings. One at the usual place on the visor and one on the arch. Both electrically "hot". I had the option of not having the one on the visor but elected to go with both for redundancy. Will use the arch, but if for some reason it is rendered useless, ie "opps didn't think that bridge was that low", can always use the forward one.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Sneaks
Vessel Name: C-Brat
PostPosted: Sun Apr 03, 2005 9:36 pm    Post subject: Reply with quote
Update:
Perko does make taller versions, contrary to my West Marine advisor.
Here is the link!
Better yet, here is a source!
Sneaks
Vessel Name: C-Brat
PostPosted: Fri Apr 08, 2005 2:46 pm    Post subject: Reply with quote
New 30" Perko 1209-DP2 arrived yesterday. Perfectimundo. 6" longer than the Perko 1209-DP1 that comes stock, it nicely clears the radome with a couple of inches to spare.
Sneaks
Vessel Name: C-Brat
PostPosted: Mon Apr 18, 2005 11:00 am    Post subject: Reply with quote
Anybody need a spare C-22 all-round light?
Gonna be gone soon
Page generation time: 0.0247s (PHP: 68% - SQL: 32%) - SQL queries: 20 - GZIP disabled - Debug on
