Permatrim slowing me down?
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Wed Feb 15, 2012 5:23 pm    Post subject: Permatrim slowing me down? Reply with quote
I am thinking of removing the Permatrim on my Honda; think it’s slowing me down. I have raised the motor up a notch and still the permatrim is submerged at speed. If I lift the motor the final notch I don’t think it will make any difference.
I was wondering if anyone else with trim tabs has removed their permatrim, and if so what performance characteristics have you noticed.
Don’t think I’ll have any problem with the removal process; and for the initial trial I’ll just cover the cavitations plate holes with waterproof tape.
So, any thoughts…I’m sure there are.
As always I appreciate the feedback.
Boatless for now but looking
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Wed Feb 15, 2012 5:44 pm    Post subject: Reply with quote
The permatrim should not slow you down, the plates on my engines are just below the waterline when under way. I'll be interested to see if you find any difference.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Wed Feb 15, 2012 6:17 pm    Post subject: Reply with quote
Some numbers would help: wot rpm & speed' cruising speed at 4200 rpm, and how you have the engine trimmed. It the Permatrims are submerged they will probably slow you down a knot or two. They should be right at the surface at cruise speed. Yes the combo of tabs & PermTrims improve the ride into chop.
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Wed Feb 15, 2012 6:24 pm    Post subject: permatrim Reply with quote
I would say that over all permatrim has helped to increase my speed because of stopping the pounding. My trim tabs levels the boat at speed but never did a lot to keep the nose down and boat from pounding. If the permatrim is not submerged some I don't think it could do what it is designed to do, just like the trim tabs need to be submerged. My speed is very effected by weight, wind and water conditions. Good luck with your test.
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Wed Feb 15, 2012 6:38 pm    Post subject: Reply with quote
I just put a brand new 90A Suzuki on my boat, tried it with the Permatrim, then took it off, I don't miss it at all, but I do have trim tabs. The 90A is 75 lbs. lighter than the 90 it replaced, and my boat floats higher in the stern. Just seems like something my boat doesn't need and there is definitely more drag. Just my 2 cents worth.
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Wed Feb 15, 2012 6:41 pm    Post subject: Reply with quote
Jay,
On my 22, the Permatrim was kind of optional. The main difference was how efficiently it would cruise at 12-14 mph. With the Permatrim, the boat/motor woud do very well at 12-14 mph. With it off it moved that speed up the 14-16 mph. For me it was a matter of engine loading. Will it slow you down, probably, drag is drag and a Permatrim in some respects is added drag.
On my 25, it is a different story. The trim tabs are not big enough and I don't think they can be big enough without getting in the way of something. The Permatrim adds the extra control to lift the stern up.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Wed Feb 15, 2012 7:18 pm    Post subject: Reply with quote
I just added Permatrims to my twin Honda’s last summer & already had Bennent trim tabs. Main reason I wanted them was for the heavy loading I do when on an extended Alaska cruise where I carry along with all the other stuff an additional 60 gal of fuel all in the very back of the cockpit. With the Bennet Trim Tabs fully down still couldn’t keep bow down as much as I wanted for getting on plane & into chop. Like Tom said there is some additional drag. I had Propulse adjustable pitch 4 blade composite props that were already adjusted for the highest rpm possible at max throttle. I went from just making specs, 5100 rpm at the high altitude of Yellowstone lake to 4800 rpm, so had to buy new props. Changed to a larger diameter lower pitch 10 x 12 stainless prop & am now set perfect for either the high altitude low weight or sea level with max weight. Before the Permatrims have had ventilation problems with whatever props I used depending on how the boat was loaded. Now there is absolutely none no matter how I distribute the weight. The end results of adding the Pematrims & new props lowered the speed I start to plane & increased my max speed about 2 mph. So, no doubt there is increased drag with the Permatrims, but that is overcome in my case by their allowing me to get a better boat trim which actually increasing its efficiency going through the water giving me quicker planning, higher speed & better mileage
Jay.
PostPosted: Wed Feb 15, 2012 8:26 pm    Post subject: Reply with quote
Ah, the other eternal question; To Permatrim or NOT to Permatrim... Laughing
I still haven't decided. Confused
PostPosted: Wed Feb 15, 2012 9:08 pm    Post subject: Reply with quote
My Quarter is still up in the air Confused Rolling Eyes Shocked
Half/Pint
City/Region: Rocky Mount/Wilson (NC)
Vessel Name: Half/Pint
Photos: Half/Pint
PostPosted: Wed Feb 15, 2012 10:15 pm    Post subject: Reply with quote
I have a Permatrim that I purchased for my boat (1993-22') w/75 Merc 4 stroke I will give to anyone who wants it. If I remember correctly, I had to run 3 or 4 hundred more RPM'S to maintain the same speed without them, also top end speed was lower.
Most of us have to much stern weight, large 4 stroke engines, house batteries extra gear in lasseretts etc.
I never had a problem getting the bow down until I replaced my perfectly good 2 stroke 70 HP Johnson with the 4 stroke Merc., added two group 31 house batteries in the stern, and air conditioning all this to please the First Mate.
After I moved some weight forward & got my boat back in balance my problem went away. Now I can get the bow down on the Half/Pint at most any speed low enough to bow steer, without undo stress on the engine & transom without trim tabs & the Permatrim.
In my opinion if your boat is rigged correctly you don't need them.
Yes my engine is set up at the right height.
Sam
PostPosted: Wed Feb 15, 2012 11:51 pm    Post subject: Reply with quote
I really depends on three other factors:
1) Singles or twins?
2) Fuel injected or carbureted? And
3) Rollers vs. bunks on the trailer? Wink
PostPosted: Thu Feb 16, 2012 7:07 pm    Post subject: Reply with quote
Exactly!!! Laughing
You forgot: Trailered or moored? Wink
bjidzik
City/Region: Juneau
Vessel Name: Betty Joe
Photos: Betty Joe
PostPosted: Thu Feb 16, 2012 8:20 pm    Post subject: Reply with quote
My Honda dealer talked me out of adding a Permatrim. To drill or not to drill. He preferred not.
2002 16' Cruiser (Cachita) traded in 10/2009
2009 25' Cruiser (Betty Joe)
Brian & Helen Idzik
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Thu Feb 16, 2012 8:44 pm    Post subject: Reply with quote
Rogerbum,
My boat with green trim is definitely more efficient than those ugly blue-trimmed ones! You forgot to mention that!
Nick
"Valkyrie"
breausaw
Photos: Triple J
PostPosted: Fri Feb 17, 2012 2:31 pm    Post subject: Reply with quote
Sorry, kind of forgot about this post; been crazy busy lately.
From the response and reading others experiences along with my own fist hand knowledge; think I’ll forgo this experiment. Getting the bow down into the chop is a common necessity in PWS especially when leaving Whittier on most afternoons or evenings, I wouldn’t want to lose or minimize that ability even for one trip; the permatrim stays on.
Like many time in the past, the group has changed my mind from wasting my time.
Thanks again for the valuable feedback; what the heck was I thinking!
Page generation time: 0.0796s (PHP: 50% - SQL: 50%) - SQL queries: 28 - GZIP disabled - Debug on
