Lane
Vessel Name: Genuine Hawken
Photos: Genuine Hawken
Posted: Wed Mar 30, 2005 12:29 am Post subject: Trolling motors |
I'm looking for the right troller. Have a Suzuki 90 4 stroke. Have a swim ladder mounted starbord so I'd need to put the kicker on port side. Is there an electric out there that will push a 22' Cruiser? Any help would be appreciated.
Lane |
Joined: 07 Nov 2003 Posts: 7935 City/Region: marysville
Posted: Wed Mar 30, 2005 1:35 am Post subject: |
sea wolf has the ele trolling motors mounted on his cav. plate on the main engine but i have not heard how well they worked . do a search as i know he posted pic and what he thought about it. if you are thinking of useing it in salt.. then think about a gas kicker. _________________ Thomas J Elliott
Posted: Wed Mar 30, 2005 2:31 am Post subject: |
Lane-
Here's the link to the discussion of my electric set up:
http://www.c-brats.com/viewtopic.php?t=1263
It works great trolling for trout up to 2 mph in fresh water lakes. It has 44 lbs of thrust, and with 4 group 27 batteries, will run for about 9 hours w/o serious recharging.
They also make double and triple motor jobs with up to 165 lbs, but the battery drain on these bigger units is awsome. Mine draws 36 amps at full power and the 165 would draw 140 amps!!! I actually troll at about 60-70% of full throttle, or about 20-25 amps of draw.
What I think Tom (starcraft) means about getting a gas motor for salt water use is that you generally need a stronger motor in saltwater trolling. Saltwater models are made, but might not have the power to deal with the heavier wind, current, chop, etc. and/or the battery drain would be prohibitive.
Both MinKota and MotorGuide make engine mounted models, and there are a couple of smaller outfits that convert regular transom mount models over to engine mounted models as well. Let me know if you have further questions after reading the discussion linked above! Joe. _________________ Sea Wolf, C-Brat #31
Redƒox Guest
Posted: Thu Mar 31, 2005 2:04 pm Post subject: |
Check out the new YammerHammers!! They have this new troll-feature that is a little rocker-switch (on the tiller) that bumps-up the rpm by 50, each time. It always takes a little finess doing it all with the throttle alone. |
Lane
Posted: Thu May 05, 2005 12:22 am Post subject: Yammer Hammer |
Redƒox wrote: | Check out the new YammerHammers!! They have this new troll-feature that is a little rocker-switch (on the tiller) that bumps-up the rpm by 50, each time. It always takes a little finess doing it all with the throttle alone. |
Redfox,
What is it? A troller? Website??
Lane  |
