Propeller Replacement
Peter_BDA
City/Region: Bermuda
C-Dory Model: 22 Classic
Photos: Luna-Sea
PostPosted: Sun Feb 05, 2012 8:36 pm    Post subject: Propeller Replacement Reply with quote
Hey folks, need to replace my prop on my Yamaha 130 hp engine serial: L1L314427R. Anyone have any suggestions? I have a stainless "19K" on it now but the bushing is going....
I have emailed getaprop.com in Anacortes WA and Wholesale Marine but would rather deal with a "known" supplier....
Thanks in advance,
Peter
Peter Aldrich
Bermuda
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Feb 05, 2012 9:39 pm    Post subject: Reply with quote
I like Ken at Propgods http://www.propgods.com/Content2/Default.aspx and their forums
Brent Barrett
PostPosted: Sun Feb 05, 2012 10:01 pm    Post subject: Reply with quote
If the metal part of the stainless prop is still good, why not just get another bushing pressed into it? They do it all the time. Used to be about $75, as opposed to four to six hundred for a whole new prop! Smile
PostPosted: Sun Feb 05, 2012 10:59 pm    Post subject: Reply with quote
BINGO! Especially on a SS prop. Those are not exactly inexsensive.
PostPosted: Mon Feb 06, 2012 10:47 am    Post subject: Reply with quote
Not sure what a Yamaha propeller is like, but if it's anything like the rest of them, it slips onto a splined motor shaft. So the only parts which can wear is any part between the female spline and the prop itself. If the prop spline is worn, I'd check the fit on the motor shaft. Something might be wrong in the fit, spacing etc. If the shear device is gone, what did the prop hit? There should be a rubber sleeve between the spline and prop, to both cushion shock and to shear. This usually goes after a few years and one can replace them.
Next, I'd take Joe's advice and have it rebuilt. A new prop runs $200-$300, I've had them rebuilt for $70 for the hub to $150 as a reward for running into rocks. Bermuda must have a prop shop, it's an island.
Talk to the guy at San Diego Props if you need real advice. He just rebuilds props. OK, not his only job, he builds Baja racers in the winter.
PostPosted: Mon Feb 06, 2012 11:04 am    Post subject: Reply with quote
We have to remember that Peter is in Bermuda, so his choices may be more limited. Also Bermuda used to (probably still does) have a very high import duty on marine items.
The new rubber insert is pressed in with some glue, and is in-expensive. SS props can be rebuilt fairly easily. The splines and main part of the prop remain the same. A SS prop can be reworked. I suspect that there is someone in Bermuda who can rebuild this prop for you. I find "Boater's Choice Propellers", 19 Chapel of Ease St. David's. They have Prop Scan, which means when they rebuild it is to a high tolerance.
If not, then go with Ken at Prop Gods. Very good people to deal with in the US (Florida).
An excellent resource in Bermuda is "Doug in Bermuda" who hangs out on "The Hull Truth" and a couple of other boating forms, like Boat Fix.com. He does travel in the US during the summer recently--but I think is in Bermuda currently--and has good contacts.
PostPosted: Mon Feb 06, 2012 12:01 pm    Post subject: Reply with quote
Bob, Boris, et al:
Here's a fact I learned from guy at the "Proper Tighe" prop shop in Alameda, California about replacing rubber prop hubs:
The "glue" / lubricant they use for the process is …….Kayro Syrup (!!!)
It works as a lubricant to slide the larger hub into the smaller prop cavity under hydraulic pressure, then washes out in solution in time.
Our local "Phil's Propellers" in Redding, just uses liquid soap, to the same effect.
One can't do the process at home as it requires not only a hydraulic press, but also a "funnel tool" of the proper size to guide the rubber hub down into the prop cavity. (So he says.)
Do you suppose they'll have a question about this on Jeopardy? Laughing
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Feb 06, 2012 1:23 pm    Post subject: Reply with quote
"Ill take remote location prop repair and technology for $150 Alex"?
Marc
Wefings Marine Website
Since 1909
PostPosted: Mon Feb 06, 2012 8:39 pm    Post subject: Reply with quote
I just replaced the prop on the Honda 150. This is an aftermarket Michigan Wheel (from Thailand.) To make this an universal fit, they use a plastic insert between the prop and the motor splines. I forgot about this type of insert in my post above.
This is black plastic, square on the outside, splined on the inside. It provides the shear capability when the prop hits a rock, etc. and shatters. If your propeller uses this type of insert, just get a new one. They're cheap, $35 here: XHS Hub Kits , less shipping and import fees. You might check with your local prop shop, I once found one on Vancouver Isle as they're common.
Wefings
Dealer
PostPosted: Mon Feb 06, 2012 8:58 pm    Post subject: Reply with quote
That style of hub is used on many Mercury props. Powertech makes both rubber hub and nylon insert hub props right here in the good ole USA. Many styles to choose from. They are at www.ptprop.com. . We are a dealer, but the internet will take you where it takes you.
Marc
Page generation time: 0.0435s (PHP: 64% - SQL: 36%) - SQL queries: 27 - GZIP disabled - Debug on
