Honda 50 hp trim/tilt not working
mattk
City/Region: placerville
PostPosted: Thu Feb 23, 2012 11:36 pm    Post subject: Reply with quote
I'm not sure what you mean by continuity. The plug comes right out of the relay. Two wires, green and blue. I believe that you should get 12v either positive or negative between the two when you hit the switch.
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Feb 24, 2012 12:03 pm    Post subject: Reply with quote
I don't know if it's the same on Honda's but we had problem with a bad tilt/trim relay on our 2006 Suzuki 90hp. The motor started raising up and down at random before finally stopping. It was a fairly inexpensive part, it was replaced and no problems since then.
Good luck in your trouble-shooting. Sorry it's taking so long to figure out.
Peter & Caryn
Email: pjamero@gmail.com
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Fri Feb 24, 2012 3:34 pm    Post subject: Reply with quote
Does the BF 50 have a tilt control rocker switch on the motor and throttle like my BF75? Will neither activate the tilt motor? You know the motor is good and grounded, so it seems like the problem would have to be a switch or relay as Peter suggested.
mattk
PostPosted: Fri Feb 24, 2012 8:27 pm    Post subject: Reply with quote
it does have switches both on the throttle and and on the side of the engine.
I can hear the switch click. So i suspect the relay also.
I know this isn't the proper way to go but I just purchased a $6 25amp three way switch from Frys and see if it will operate that way.
Phone
mattk
PostPosted: Mon Feb 27, 2012 12:19 am    Post subject: Reply with quote
I suspect that Peter is right that the relay or its associated wiring is bad. But not being able to find that part, I installed a double throw, double pole switch with a 10 amp fuse straight to the motor and mounted it on my dash. It works perfect. I just can't operate the T&T from the side of the engine. Just happy to be operational.
kennharriet
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Mon Feb 27, 2012 1:09 am    Post subject: Reply with quote
Glad you got it working at a reasonable cost!
mattk
PostPosted: Mon Feb 27, 2012 1:28 am    Post subject: Reply with quote
Thanks for pointing me to the motor and Boats.net.
Jazzmanic
Photos: C-Dancer
PostPosted: Mon Feb 27, 2012 2:50 am    Post subject: Reply with quote
I'm glad my suggestion helped. Although I didn't actually find and replace the part myself, my mechanic did troubleshoot the problem to the relay, which in the Suzuki was a small electrical part. Since my motor was under warranty, it got replaced for free. I'm pretty sure the part was under $20. Perhaps the relay is similar on Hondas? In any case, congrats on finding a solution.
Page generation time: 0.0254s (PHP: 62% - SQL: 38%) - SQL queries: 26 - GZIP disabled - Debug on
