cabin top hand rails
moonular
C-Dory Model: 19 Angler
Photos: moonular
PostPosted: Fri Jan 27, 2012 12:27 am    Post subject: cabin top hand rails Reply with quote
Hi there, simple question here. i need to set up a solar panel rack system for my 2004 Angler 19 and I need to know the rail diameter of the cabin top hand rails. Ya, sounds strange but the boat is stored quite a long ways away and i want to take the parts with me to the boat. Can anyone tell me the diameter? Triton Marine said they are either 3/4" or 1". Apparently C-Dorys that were built during that time period had both depending on the boat length.
Moonular
Connie Fisher
Guest
PostPosted: Fri Jan 27, 2012 9:13 am    Post subject: Reply with quote
Hello from Iowa,
Seeing your request, I went out and measured the top hand rails.
on our 2004, 19’, C-Dory Angler.
You will not believe this, but the hand rail measures 7/8” wide/diameter.
Regards,
Ron Fisher
berryst
City/Region: Kingston
C-Dory Year: 1985
Vessel Name: Margaret Ann
Photos: Sea Major
PostPosted: Fri Jan 27, 2012 3:53 pm    Post subject: Reply with quote
They may have been thinking Bimini frame size.
Chris
The road to hell is paved with good intentions
moonular
Photos: moonular
PostPosted: Fri Jan 27, 2012 8:56 pm    Post subject: Thanks! Reply with quote
Thank you for the info!
I will be using these slick "Split Jaw Mounts" from Gemini to attach my solar panel (bullet proof SC24w from Sunwize) to the cabin top hand rail. They provide for a "standoff" so you can still grab the handrails.
http://www.geminiproducts.net/gemini-side-mounts/
PS
I tried to post the picture here - will have to work out how to do it for future posts. I'll post a pic of the setup when its done.
Thanks again!
Page generation time: 0.0529s (PHP: 48% - SQL: 52%) - SQL queries: 16 - GZIP disabled - Debug on
