How to remove decal from boat
Anita Marie
City/Region: Oak Harbor
Vessel Name: Anita Marie
PostPosted: Sun Mar 27, 2005 8:05 pm    Post subject: How to remove decal from boat Reply with quote
What is the preferred method for removing a decal from the boat?
Thanks
Fred
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sun Mar 27, 2005 8:28 pm    Post subject: Reply with quote
Assuming you're talking about decals on the hull itself, I've always had good luck with using a hair dryer or heat gun on medium setting when removing decals from fiberglass. Carefully warm the decal up and it will peel off fairly easily. Just take your time and raise the temperature slowly.
Mary & Don Anderson
Brat #483
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sun Mar 27, 2005 10:10 pm    Post subject: Reply with quote
Hair dryer is what I used Fred. And a safety razor blade to get under the edge to get it started. Just takes time and patience but when I was through and waxed the area you couldn't tell anything had been there.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Mon Mar 28, 2005 9:40 am    Post subject: Reply with quote
Fred,
Ditto on the hair drier and safety razor or plastic scraper to lift the corner of the letters. " Turtle Wax Bug and Tar Remover" cleans up the glue residue; works:thup .
Mike 'Levity'
Anita Marie
PostPosted: Mon Mar 28, 2005 2:32 pm    Post subject: Reply with quote
Thanks for the help. I think I will use my heatgun on low and like you guys said, take my time.
Fred
Redƒox
Guest
PostPosted: Mon Mar 28, 2005 2:38 pm    Post subject: Reply with quote
Careful with "heat gun" Exclamation I found both fiberglass and gelcoat doesn't take to kindly to a lot of heat... Exclamation
catdogcat
City/Region: Soldotna
C-Dory Year: 1988
Vessel Name: Plankton
Photos: catdogcat - TBA
PostPosted: Mon Mar 28, 2005 7:53 pm    Post subject: Reply with quote
How do you remove Duct Tape? Smile
PostPosted: Mon Mar 28, 2005 8:27 pm    Post subject: Reply with quote
If the duct tape is fairly fresh, simply strip it off by hand, and then remove the remaining adhesive with a suitable solvent. I like to use laquer thinner, as it has a half dozen solvents in it that will dissolve just about anything. Dont spill it anywhere you don't need it. Wax the hull after the removal, as the solvent removes the wax, too. Old duct tape works the same way, except tht almost all the adhesive is left behind and has to be dissolved. Joe.
Sneaks
Vessel Name: C-Brat
PostPosted: Mon Mar 28, 2005 8:40 pm    Post subject: Reply with quote
Goof-off (a product, not a pastime) is great for duct tape adhesive removal as well as dozens of other nasty removal tasks. Lots safer than more volatile substances, though I've also used barbecue fire starter fluid successfully.
Don
PostPosted: Mon Mar 28, 2005 9:04 pm    Post subject: Reply with quote
Acetone works very good for the sticky stuff. Robbin has some in her purse, I'm sure. I remember that time at the pub in Olympia when her and C-Lou were comparing purse contents. Good chance she has several things in there that would work. But finger nail polish remover is just expensive acetone with some perfume in it, I do believe.
Kinda sad, ain't it Fred? Maybe you should let Brock peel the name off for you. You know he won't mess anything up, him being Mr. Neatness and all.
Anita Marie
PostPosted: Mon Mar 28, 2005 11:24 pm    Post subject: Reply with quote
You know Mike you are right. They say to use a blow dryer to get the decal off. If I remember right when Robbin dumped her purse that night I think a blow dryer fell out. Sometimes I am not sure I need a tool bag when she is along.
Purse dump
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Tue Mar 29, 2005 12:06 am    Post subject: Reply with quote
All this talk about solvents reminds me of a very handy solvent I use often: WD-40. If you have acetone, paint thinner, or Goof-off they work great, but usually I need to remove some sticky mess when I don't have them available. I almost always have some WD-40. As a bonus it is very safe to use.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Cynthia - CLou
C-Dory Year: 1986
Vessel Name: C-Lou
Photos: C-Lou and Pee Wee
PostPosted: Tue Mar 29, 2005 12:44 am    Post subject: Reply with quote
Robbin clearly won...
CLou Teeth
"CLou" on the C-Lou
AKA / "Nurse Ratchet"
Page generation time: 0.0515s (PHP: 50% - SQL: 50%) - SQL queries: 25 - GZIP disabled - Debug on
