Help with the name of a fitting...
Mike B
City/Region: Staten Island
State or Province: NY
Vessel Name: Remembrance
Photos: Remembrance
PostPosted: Mon Dec 26, 2011 8:48 pm    Post subject: Help with the name of a fitting... Reply with quote
Hello guys,
Quick question. I own a 2007, 22' Angler, bought it used less than a year ago and I need to know the name of a part. The rubber gasket/seal/whatever, that all the lines go through the bulkhead to the engine. Mine is all rotted and needs to be replaced . I need to know what its called and if you know where I can get one. Thanks
PostPosted: Mon Dec 26, 2011 9:15 pm    Post subject: Reply with quote
It's called a boot.
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Mon Dec 26, 2011 9:17 pm    Post subject: Reply with quote
Rubber or Vinyl Cable Boots or Rubber Grommets can be used.
Chris
City/Region: Bend
Vessel Name: Rana Verde
PostPosted: Mon Dec 26, 2011 10:32 pm    Post subject: Reply with quote
Cable Boot or Motorwell Boot. Problem is...they used different types from time to time...and there are a zillion different sizes available. Best to take off the old boot and take it to the marine supply and match it up...otherwise you will end up drilling more holes to mount the new boot. Also...unless you are feeling really energetic...just cut one side of the boot to remove it...taking all those cables and wires apart to remove the boot isn't fun. And some of the new boots come already cut.
Chris
Rana Verde
Mike B
Photos: Remembrance
PostPosted: Tue Dec 27, 2011 9:12 am    Post subject: Reply with quote
Thanks, I had no idea what it was called and have never known anyone that has changed one.
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Tue Dec 27, 2011 10:11 am    Post subject: Reply with quote
Mine was also in bad shape when I bought the C-Dog. I aquired a piece of wetsuit material. I cut it to the shape of a truncated cone,wrapped it around the cables & sewed it by hand in place negating the need to disconnect the cables to install. Worked out great & it was blue to match boat. Vern
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Tue Dec 27, 2011 11:13 am    Post subject: Scissors Reply with quote
When you get your new boot. Just take a pair of scissors and split it open. Then install it and use about 3 or four cable ties to cinch it back together. Put the split at the bottom. It will keep the rain and transom waves out good enough. No need to disconnect and re run cables. That would be a nightmare. Your boot will have a hole pattern already in the fiberglass. Make sure you get a boot with the same hole pattern. If you are worried about the split being completely waterproof. Don't. Water can already enter where the cables enter at the top of the boot cone anyway.
Testosterone Tales-Amazon.com
KG7RC
Jim and Anne
City/Region: Cape Cod
Vessel Name: CompanionShip
PostPosted: Tue Dec 27, 2011 11:31 am    Post subject: Reply with quote
Hi Mike B,
I have a 2007 as well and the motor well boot rubber has rotted and needs replacement. It's on my list of winter projects. When I removed the rotted one there were no identifying numbers or name on the boot. So I'll have to see what the local WM or other shops have so I can try to match up the hole pattern with what's already on the boat. They do sell a boot that is already split, which will make it easier to install.
damason
City/Region: Valparaiso, Florida
Photos: CHARITY
PostPosted: Tue Dec 27, 2011 12:03 pm    Post subject: Cable Boot Reply with quote
Go to www.thmarine.com. Click on search and type "boot", cr. Select your required boot, order, and install. I have not ordered from them yet but will when my boot wears out. Laughing
Marlene and Dave Mason
Once a C-Brat - Always a C-Brat!
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Tue Dec 27, 2011 12:26 pm    Post subject: Reply with quote
The boot on my boat was falling apart when the boat was new. The dealer sent me the following, which fit the existing hole pattern perfectly.
Rob
http://www.amazon.com/Attwood-Corporation-12820-5-Motor-Well/dp/B0009TS3VU
potter water
City/Region: Logan
C-Dory Year: 1997
Vessel Name: Poopsy
PostPosted: Tue Dec 27, 2011 2:56 pm    Post subject: sea dog 5.5 inch. Reply with quote
Mine was the 5.5 inch sea dog. That is what the hole pattern is on my 2007 22.
Page generation time: 0.1271s (PHP: 51% - SQL: 49%) - SQL queries: 24 - GZIP disabled - Debug on
