Wire Size
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Thu Dec 15, 2011 11:26 am    Post subject: Wire Size Reply with quote
I'm in the process of connecting my GPS to my VHF radio distress function. The attachment ( plug-in ) wire is too short to reach my GPS, these wires are real small in diameter and wonder what type of wire i should use to connect the two units. Thanks Tug
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Thu Dec 15, 2011 4:06 pm    Post subject: Reply with quote
I take it from the lack of response to my question that i can use any wire approximately the same size to connect the VHF DSC connector ( wires ) to the GPS's corresponding wires. Tug
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Dec 15, 2011 4:43 pm    Post subject: Wire Size Reply with quote
I'm guessing 20-22 gauge copper stranded tin coated to avert corrosion. I would ask the manufacturer if they want the wire to be shielded in foil as it is data. Maybe the vendor of the units could front you a piece of the wire that they recommend. Buying 10' pieces of speciality wire can be hard to do.
D.D.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Thu Dec 15, 2011 4:50 pm    Post subject: Reply with quote
I never thought about doing that, i will e-mail the manufacturer and ask them just that. Thanks for the suggestion. Tug
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Thu Dec 15, 2011 7:49 pm    Post subject: Reply with quote
Tug, if you have a local marine electronics service, go in and ask some questions. I have had good luck with my local shop, but I also buy my gear from them. My guess is that same size or one size larger would be just fine, but the point about shielding is worth looking into.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Thu Dec 15, 2011 8:07 pm    Post subject: Reply with quote
I e-mailed Garmin today but ended up calling them also later. They recommended that i use 22 Gauge AWG wire, i asked if shielding was required and he said that this wire would be good. I will wait for the e-mail from Garmin before i buy any wire just to be on the safe side. Thanks Tug
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Dec 15, 2011 8:49 pm    Post subject: Reply with quote
Home Depot sells security cable buy the foot 4 conductor 24 gauge shielded. I have seen it tinned and untinned. Electrical supply house like Graybar and mining supplies will carry communication cable that will work. Look for a supply house that carries Beldon cable they make just about everything for communication cable. You can also take a old computer serial cable for a modem and cut the ends off (keep it out of the sun) the wire in that will be smaller than 24 gauge but will work just fine for what you are doing.
Jody Kidd
KE7WNG
Northern, Utah
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Thu Dec 15, 2011 9:33 pm    Post subject: Reply with quote
For serial type communications, I use CAT 5E cable and splice it using telco type crimp splices that are sealed with silicone. I strip individual twisted pair out of the cable. I don't think shielding is a particular issue with systems in our boats. The only exception would be someone operating a marine HF or shortwave transmitter.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Fri Dec 16, 2011 8:58 am    Post subject: Reply with quote
I recieved an e-mail from Garman support:
Dear Remi J Laurin,
Thank you for contacting Garmin International.
I am pleased to assist you. The NMEA wires in the GPSMAP 172C wiring harness are 22 gauge stranded wire. The wires will not need to be shielded.
Tug
Sea Angel
Photos: Sea Angel
PostPosted: Fri Dec 16, 2011 3:05 pm    Post subject: Reply with quote
Tug,
I believe you can get short pieces/rolls of 22G shielded pair audio cable.
I have used BELDON 8451 successfully for extended (>100') signal & audio runs.
I use the shield as a common(ground) wire and one of the other wires for the data send and the second for the data receive.... just don't cross connect the wires.
There are several discussions about NMEA data standards. The color of the wires are not as inportant as to where they hookup. A simple crimp connector (prefer WX proof type) should/does work fine.
ART
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Page generation time: 0.0396s (PHP: 60% - SQL: 40%) - SQL queries: 23 - GZIP disabled - Debug on
