G4 HT chain for windlasses
Goto page 1, 2, 3  Next
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Thu Nov 17, 2011 10:18 pm    Post subject: G4 HT chain for windlasses Reply with quote
I am trying to pick out chain and rode from Defender for our 22. We may eventually get a windlass so I want to make sure this will work. I'm planning on getting Acco G43 1/4" HT chain (50'), but right before I ordered I noticed that it said it was "short link". I couldn't find specific enough specs on the Lewmar site to tell if short link is what I'm looking for. I don't want to have to ship back 40 lbs of chain! Here's the chain:
http://www.defender.com/product.jsp?path=-1|10391|32295|321083&id=32561
Also, I'll be getting a pre-cut 200' 1/2" 3 strand line:
http://www.defender.com/product.jsp?path=-1|10391|311417|322366|1041169&id=37067
The galvanized shackles on Defender look sketchy so I might get some locally. They have some Crosby shackles, but I can't tell if an oversize (5/16") shackle will fit in the 1/4" chain links, so I might just get them locally.
Thanks!
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Nov 17, 2011 10:44 pm    Post subject: Reply with quote
The chain and windlass are matched so it is important to do as you are, think about it in advance; I know of at least one brat who bought a long piece of expensive chain only to discover it wouldn't work in his windlass. Our Lewmar V700 uses the 1/4" short link. The long link will not feed through the gypsy as far as I know. I've tried to use 5/16 shackles with little luck so you might find 1/4" is best. If you go on the Lewmar site I think you can see their chain recommendations.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Fri Nov 18, 2011 2:25 am    Post subject: Reply with quote
ferret 30-
Most windlasses we use fit 1/4" GS 40 HT (High Test) short link galvanized chain.
The GS 43 and GS 40 appear to be fairly similar in strength and manufacture with the GS 40 having slightly smaller links, though they both are usually pretty much interchangeable.
"Gr 40
High Test
Strength levels are the same as Gr 43 but the dimensions of the chain links are smaller using ISO standards. Primarily used for boat windlasses, this grade has become a standard for that industry. The Grade 40 designation was exclusively used by ACCO Chain until 2005 to designate their High Test grade chain. They now use "43" in keeping with the rest of the industry. The chain is hallmarked "G4" on every link. Not for overhead lifting."
Gr 43
High Test
This is a higher strength chain used for years in the trucking industry for tie downs that meet DOT specifications. Made from a higher carbon steel, its strength surpasses proof coil working load limits, size for size, by a factor of 2 to 1. Hallmarked every 1 to 3 feet with manufacturer's symbol and grade marking: 4, 40, 43 or 400. Not for overhead lifting."
Reference source: Chain Grading
Here's the Acco/Peerless pdf catalogue (see page 16):
http://www.peerlesschain.com/downloads/peerless-acco-2010.pdf#page=16
Good Luck!
ferret30
Photos: Lily Pad
PostPosted: Fri Nov 18, 2011 3:39 am    Post subject: Reply with quote
Thanks guys, I'll place the order tomorrow.
I have a 200' 1/2" 3 strand rope that came with out boat that has a thimble on one end, and unfortunately a bad looking fray about 80' from one end. I'm thinking of cutting this one at the fray so I don't ever accidentally use it. Also, I'm going to use the last 8' or so (including the thimble) and turn it into a snubber to attach the new line to the bow eye at anchor. And I'll use another piece to practice back splicing to a chain!
Fun stuff!
PostPosted: Fri Nov 18, 2011 4:23 am    Post subject: Reply with quote
My apology for not answering your question on the "thisaway" thread. What you are doing should work fine. Some folks find that the plait lines work better in the windlass--but I have always used 3 strand. As I recollect you can use 1/2" or 7/16" in the Lewmar. Joe has covered the chain well--stamped G 4 works well. (1/4"). I will have to check, but I believe that I have always used a 5/16 shackle. However, I agree, that many of the current shackles from China can be sketchy. Hight test shackles are available. I would be cautions about SS especially from China--since I have seen some bad castings. Plus I prefer not to mix galvanized and SS. If you go with 1/4" shackle--make sure it is high test.
My boat has large fender washers, which will be adequate for "normal" anchoring. Since I will have the boat out of the water on a lift or trailer in storm conditions (most of the time hopefully), I will stick with the factory back up. In the past I have used aluminum plate under the deck, especially under a windlass and cleat together.
A lot depends on the water where you anchor. With a windlass the 50 feet of chain is good for the C dory. In larger boats I used 200 feet of chain, with up to 400 feet of rode or more in the PNW where anchorage depths are up to 100 feet. In the lakes and ICW where we are currently boating, a total of 150 feet is plenty. I'll probably have a couple of rodes. The primary will be 1/2 " line of 150 feet and only 8 feet of chain, because of no windlass.
I will also carry a back up rode of another 200 feet and 50 feet of chain. The stern line will be smaller--3/8" which is plenty strong, and easier to stow, but a bit harder on the hands if you have to pull it in by hand. Stern anchor is a 7# Fortress, and Charlie gave me back the large fortress--so it will sit in pieces under the dinette (as I recollect it is a FX 37).
You had also asked about the color of the stripes--they are black with gold accent pin stripe tape. We are raising the water line by at least an inch--because of waterway "smile" with bottom paint, and will probably put a new gold stripe on.
ferret30
Photos: Lily Pad
PostPosted: Fri Nov 18, 2011 12:49 pm    Post subject: Reply with quote
Thanks for the response Bob!
I can't wait to get all my ducks in a row so we can start doing trips in the Puget Sound in the spring. We've just been going slow with the boat so far, staying in Lake Washington and Lake Union but it should be a lot of fun to go to the CBGTs next year.
I just have to finish installing the anchor roller now. I had to make some time to do the epoxy work this week since I figured it was going to be one of the last clear 50+ degree days of the year. I ended up using a hammer to flatten the bottom of the pivoting anchor roller I had so it would sit flat on the bow (it had been bent a bit at the front lip by the pivoting part pushing down on it). I've got 2" OD 1/8" thick stainless washers for backing the roller bolts, and since I'm planning on using a snubber at anchor, the roller shouldn't have too big of forces on it.
The last big step is finding and installing a kicker!
Bob, I'm looking forward to pictures of your new boat and the projects you're doing on it!
PostPosted: Fri Nov 18, 2011 12:54 pm    Post subject: Reply with quote
Let me make one more comment, which I thought of, but didn't put down last night. I generally make the snubbers lighter than the anchor rode. For example for the C Dory I would consider 3/8" line. If not a lighter line, then a rubber snubber to take the load.
Also when I put the Starboard blocks on the transom, I will drill out new holes (based holes drilled in the starboard block)--and then epoxy fill those oversized and very slightly under cut holes (depending on how thick the glass there is)
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Fri Nov 18, 2011 1:04 pm    Post subject: Reply with quote
The G4 chain is also available at West Marine. They have specials all year round with rebates on purchases of $100 increments, might be worth checking.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
ferret30
Photos: Lily Pad
PostPosted: Fri Nov 18, 2011 1:11 pm    Post subject: Reply with quote
When you mention using 3/8" for the snubber line, do you mean for securing the anchor when stowed, or for attaching the rode to the bow eye when anchored? Or both?
I haven't figured out what to use for the anchor stowing snubber yet, a bungee or a line with some sort of chain hook at one end and a loop for the bow cleat at the other. I want to figure that one out soon since an accidental deployment just about anywhere would be pretty awful.
I'll have to take a look at our transom next year too. The transducer is mounted directly to the boat below the water line, and there are a few cable guide loops going up the transom. I'd prefer that these holes (especially the underwater ones) are very well sealed, and I don't think the guides are even that necessary.
Will your Starboard completely cover the old holes you are filling in? Or are you adding pigment to the epoxy to make it more UV stable?
Sorry for the endless string of questions, and I really appreciate all the information!
ferret30
Photos: Lily Pad
PostPosted: Fri Nov 18, 2011 1:18 pm    Post subject: Reply with quote
Thanks for the response! I was thinking of buying there since it would be easier to pick up locally, but they don't have Acco 1/4" G4 HT, they only have a WestMarine brand (could be the same) and it's $0.42/ft more, so it works out to be the same when comparing the two. Also, WM's site isn't really specific about what exactly the chain is (i.e. short or long link, dimensions, etc.).
The chain at Defender is Acco G43 1/4" HT for $2.99/ft, so I think I'll get it shipped but I'll feel sorry for the delivery guy!
PostPosted: Fri Nov 18, 2011 6:02 pm    Post subject: Reply with quote
The 3/8" snubber is for at anchor. I use a rolling hitch around the anchor rode with the 3/8" line which then is secured to a bow cleat. The snubber should be about 20' long, to allow stretch.
I have used the rubber straps, and short lines for holding the anchor when trailering or running. The current boat has a hayfield type of lever to tension the chain and hold the anchor in place. I do tie off the anchor and not depend on the winch.
PostPosted: Fri Nov 18, 2011 6:34 pm    Post subject: Reply with quote
As far as chain brand is concerned, when I did the research for the chain post, I found out that Accco Chain was bought out by Peerless Chain a few years ago, so the chain at West Marine is probably the same as that at Defender anyway. One could always check the name/information/etc. on the side of the barrel.
It's my understanding that most windlasses have some moderate size tolerance in the size of chain they will accept. When you get ready to buy a windlass, take or send a short sample of whatever chain you do wind up buying to the windlass supplier and see if it fits.
Most windlass manufacturers have very through size charts for chain and everything else about their windlasses, including dimensions, electrical needs, performance charts, footprints, etc. Many will have two or more different gypsies for different size chains that will fit on a particular windlass. (European chain standards are different than American/English measurement standards, hence require different gypsies.)
And Bob's right, some of those 5" longer extensions are just 5 more inches added onto the 20" original part. I don't however, think this is true with the vertical driveshaft, as it would wobble if it weren't solid.
Keep in touch!
20dauntless
Photos: Retriever
PostPosted: Fri Nov 18, 2011 6:37 pm    Post subject: Reply with quote
Has anyone used this company for an anchor rode?
http://www.secosouth.com/mm5/merchant.mvc?Screen=SFNT&Store_Code=SECO
I need to order a new rode and their prices seem good.
And does anyone know if I can fit 300 ft of 1/2" 8 plait and 50 ft of 1/4" G4 chain in the anchor locker of a 22?
PostPosted: Fri Nov 18, 2011 7:12 pm    Post subject: Reply with quote
When buying nylon line, I like to know who made it. All 3 strand rope is not equal, and does not "lay" the same, as well as wear and age as well. I like to use New England Rope or Sampson line.
As for the question about UV exposure for the small screw holes--I would not worry about it. Even if it were exposed the small holes are not an issue--however in this case, there would be bottom paint. The Starboard block will more than cover the area where the old screw holes were drilled. It will also be painted by bottom paint.
PostPosted: Sat Nov 19, 2011 1:32 am    Post subject: Reply with quote
(Omitted url)
No, I haven't used them, but $1.84/ft is really good. Call them and find out who makes the chain. It must conform to the standards, also.
I agree strongly with Bob about the New England and Samson brand 3 strand rope. Very high quality. Some ropes are too stiff or too soft, and won't go down the rode opening right, or lay right, or will hockle up or worse.
Yes, but that's about the maximum that will fit! You can always build a hinged/folding extension to the back wall of the rode locker to help contain it, too.
Page 1 of 3
Page generation time: 0.0525s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
