AFI wiper motor...
PostPosted: Tue Nov 15, 2011 9:23 pm    Post subject: AFI wiper motor... Reply with quote
Port side wiper motor crapped out. A quick search turned up a few options, but... sticker shock! Anyone bought one of these lately, and have a good source?
Oh, and while I'm thinking about it, the cable boot on our boat is disintegrating. I know I've seen laced versions of these (so I don't have to spend a day undoing and redoing cables), but I can't seem to find one on-line. Guess I could always split one, glue it, and put the seam on the bottom. Any other suggestions?
TIA,
http://captnjim.blogspot.com/
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Nov 15, 2011 9:46 pm    Post subject: wipers Reply with quote
Jim what afi motor do you need I wonder if its the same as the cape cruiser 23 ? I have been just cleaning the window and then using rain X . Let me know what kind you have..I have to cut the windshield arm off to get the motor out so I havent done anything .
I might be able to get one or two for us ?
PostPosted: Tue Nov 15, 2011 9:58 pm    Post subject: Re: wipers Reply with quote
Hi Jim,
It's the AFI 1000. I know what you mean about cutting the motor shaft off to get the motor out - I had to do that when the starboard motor died. Dremmel worked fine for that.
PostPosted: Tue Nov 15, 2011 10:19 pm    Post subject: Reply with quote
Jim,
Texas must have milder sunshine than San Diego. The cable boot on Journey On went out years ago.
I found these: TH Marine Cable boot which has worked well for at least 3 years. Mine came with some vinyl cement and a vinyl strip that I used to seal off the slot.
C-Dory installed a boot on each side of the transom, and the one through which nothing goes is still fine. No explanation.
About the wiper motor, an AFI is a waterproof motor. For a C-25 the motor is installed inside. Could you get a non-waterproof motor? I would hope that interior of a C-Dory qualifies as a protected location. Defender carries Ongaro motors and claims that they will fit the hole pattern of an AFI.
Good luck, Boris
PostPosted: Wed Nov 16, 2011 12:45 am    Post subject: Reply with quote
Hi Jim,(s),
For the cable boot, I found a split boot at West Marine. don't remember the price but I thought it was much better than re-running all the cables. I put the split at the bottom and used cable ties to keep it snug. Hope that helps.
PostPosted: Wed Nov 16, 2011 7:56 am    Post subject: Reply with quote
Jim-
Do you need to replace just the motor, or the entire wiper mechanism?
(I remember the thread you wrote about the first wiper replacement the last time around!) Is this the same one, or the opposite side?
I have a suspicion that the wiper motor itself may be the same as this one:
http://www.autopartswarehouse.com/details/QQGMCQQ1000_SeriesQQA1_CardoneQQWiper_MotorQQ19631965QQA140154.html
AFI stands for American Foreign Industries, and I assume they have their products made all over the world by the least expensive manufacturer.
Replacing the motor only might not require removing the whole wiper assembly
through the traditional surgical techniques (!)
You did lubricate and seal the unit up bulletproof after Episode One, right? Laughing
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Wed Nov 16, 2011 9:37 am    Post subject: wipers Reply with quote
I looked at the wipers the only way to get motor off is to remove wiper arm but they do not come off easily as Jim said he had to cuss and cut with dremil to get arm off then motor comes out . I was wondering if we could use some other type of windshield wiper system ?Now I just clean wiondows and use rain x
PostPosted: Wed Nov 16, 2011 10:49 am    Post subject: Reply with quote
Thanks for the suggestions, folks. Last wiper episode was the starboard, this is the port. No movement, it just chatters and grinds, so I'm assuming the gears inside are toast. I will look into the alternatives, since the motor is inside the cabin.
West Marine has the AFI motor at $220. Shocked Doesn't matter whether it's the 80º sweep or the 110º, since that is a relative quick switch inside the motor. I did set the last one I mounted up at 110º, which wipes the entire window on our 25. The pentagraphic wiper blade still seems to be in good shape... assuming I can get it off. Yes, I did grease up the shaft after the last go-round; we'll see if that made any difference. Rolling Eyes I will have my Dremmel ready, just in case.
Good to know that the split boot is readily available - I didn't have any luck with that in a quick search.
As always, I appreciate the help and guidance here! Thumbs Up
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Wed Nov 16, 2011 12:40 pm    Post subject: Reply with quote
I see 2 brand new AFI 1000s with motor and arm for $119.95 and free shipping:
http://www.ebay.com/sch/i.html?_nkw=afi+wiper+1000&_sacat=0&_sop=16&LH_Price=50..200%40c&_dmpt=Boat_Parts_Accessories_Gear&_odkw=afi+wiper&_osacat=0&_trksid=p3286.c0.m270.l1313
Time is money and buying a new one from ebay might save you both!
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Wed Nov 16, 2011 6:25 pm    Post subject: wipers Reply with quote
I think I would have to take at least one out to see the shaft length and arbor size . and then order through e-bay thanks for another outlet instead of WM .
JIM B are you coming down to florida this winter ?? Im still checking my contacts to get the best price
PostPosted: Wed Nov 16, 2011 7:08 pm    Post subject: Re: wipers Reply with quote
Hi Jim,
We considered heading to Florida, but have decided to stay around Texas for the next couple months. Same latitude as Naples, similar climate. We plan to do a lot more boat time in the next year, but heading the other direction.
The best price I could find on the internet for one wiper motor was around $159. That post from ferret30 sounds promising at $119.95, but it is the wrong wiper arm for our application (we use the pentagraphic arm). No mention of which shaft size (no mention of 37200 item # with Marinco). I'll see what I have for paperwork (if any) on the previous motor...
Just checked: the paperwork says the motor is item # 36181, the 1 1/2" shaft. Sounds like the 37xxx item #s are the 2 1/2" shaft.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Nov 17, 2011 12:39 pm    Post subject: Reply with quote
Hey Jim, I couldn't find the 1 1/2" shaft readily a few years ago when I added a wiper to the center window. So I bought the 2 1/2" and added a wood block spacer on the inside (with a fair amount of contouring), painted it with epoxy paint, works great. Just an alternate idea...
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Page generation time: 0.0464s (PHP: 67% - SQL: 33%) - SQL queries: 29 - GZIP disabled - Debug on
