V berth storage
Goto page 1, 2, 3  Next
dutch123
City/Region: Prince George
Vessel Name: Reel Action
Photos: Reel Action
PostPosted: Wed Nov 09, 2011 11:41 pm    Post subject: V berth storage Reply with quote
Just looking for a flush hatch for in the v berth for storage. One around 24 by 12 inches anyone installed one or two of these?
My dream boat has arrived!
Kelly Lynn
City/Region: Springfield
Vessel Name: Kelly Lynn
Photos: Kelly Lynn
PostPosted: Thu Nov 10, 2011 7:26 am    Post subject: Reply with quote
I created storage in the v-berth. It was very easy and a great place to store items that we don't use everyday. I have some pictures of it in my album. The foam was the a little bit of a pain to get out.
Kelly Lynn
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Thu Nov 10, 2011 11:05 am    Post subject: Foam Reply with quote
My 2007 boat has the v-birth under area completely filled with foam as far as I can tell. Can anyone tell me if that is so? I have pulled a couple of little plugs and stuck a skewer into the foam and it appears to go all the way to the bottom.
If so, that brings up a question. Clearly, that much foam will help flotation, but does it also add some forward hull strength? Seems to me it might. If not, then it seems that cutting a hatch hole on both sides and getting the foam out and then using waterproof hatch covers may serve as well for flotation. I also wouldn't mind getting some weight forward in the boat. The v-birth might be a place that one could store water bottles and other heavier stuff.
Opinions welcome.
Testosterone Tales-Amazon.com
KG7RC
Kelly Lynn
Photos: Kelly Lynn
PostPosted: Thu Nov 10, 2011 11:44 am    Post subject: Reply with quote
The area is not completely filled with foam it is just where the injection holes are. I am sure it will help with flotation if the boat capsizes. It did not effect the integrity of the boat. I do not regret making more storage space.
PostPosted: Thu Nov 10, 2011 1:07 pm    Post subject: Reply with quote
It's been talked about/done before. Some seem to have foam; some don't. Lift up your cushions and look for plastic plugs. If you have them, you have foam; the holes are for pouring the liquid foam in to the void. Our '07 didn't.
http://greatlakesskipper.com/product/945_948_957-jim-black-innovative-product-solutions-deck-hatches/22337-hi-tide-manufacturing-group-innovative-product-solutions-m-1323-aw-520-303-13-x-23-arctic-white-boat-deck-hatch.html
Not totally flush, but under the cushions you can't feel it.
PostPosted: Thu Nov 10, 2011 1:09 pm    Post subject: Reply with quote
http://www.c-brats.com/viewtopic.php?t=10834&highlight=berth+hatches+storage
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Thu Nov 10, 2011 2:05 pm    Post subject: Reply with quote
We made this mod on Valkyrie and it is one of the best that we have undertaken. The amount of additional storage is incredible!
Once I made the cut and removed the piece of fiberglas I was amazed at how little foam was in the void. I removed it in about an hour using a small wallboard saw, pry bar and large screwdriver.
Nick
"Valkyrie"
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Nov 10, 2011 3:47 pm    Post subject: Reply with quote
I think the amount of foam must vary from boat to boat. Mine was as full as it could possibly be, and it was a pretty major effort to get it all out. Once you cut the hole, you are pretty much committed. I am happy with the results, but I am also glad the job is done.
Rob
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Thu Nov 10, 2011 7:00 pm    Post subject: Reply with quote
I find this thread interesting, but haven't followed it since the beginning.
Has anyone found a hatch cover that is actually flat, or is the only alternative a hatch cover that is slightly raised?
Casey
PostPosted: Thu Nov 10, 2011 7:07 pm    Post subject: Reply with quote
Don't think it can be really "flat" unless it's recessed into the bunk surface. The best you can hope for is tapered flanges and only slightly raised. An aid to not feeling it would be a piece of memory foam (thin) with a cutout that goes around the hatch to mitigate what you feel. And then another piece, thicker that goes over it all so you don't feel the hard surface.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu Nov 10, 2011 7:16 pm    Post subject: Reply with quote
The current boats are built with a hatch that sits flush in an aluminum channel. I would contact vthem to see if they will sell them to you, or if the can tell you who makes them.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
C-Gypsy
City/Region: Oriental
Vessel Name: C-Gypsy
Photos: C-Gypsy
PostPosted: Thu Nov 10, 2011 7:20 pm    Post subject: Reply with quote
Mobile East Marine installed 3 hatches in C-Gypsy's V-berth for me last spring.
There was very little foam, not enough to make removing it a major concern. Beer
richnkay
City/Region: Greenville
State or Province: SC
Vessel Name: Annalee
Photos: Annalee
PostPosted: Thu Nov 10, 2011 8:53 pm    Post subject: Reply with quote
Dutch 123,
There is a very easy and inexpensive means of making a flush hatch for the vee-berth storage. Lots of boat builders have used this method over the years. I removed the foam from the bow of my 25 and installed regular hatches because I thought it was a cleaner way of doing it but looking back at the expense and having to lift cushions up high enough to raise the hatches I would probably have done it the "old school" way.
Cut any size hatch hole you want in the vee berth deck and then install a support shelf, from the bottom, around the perimeter of your hatch hole. Use screws from the bottom, just long enough that they don't break through the vee berth deck. The support shelf should be about 1/2" smaller than the hole to provide good support for the hatch sitting on top. The hatch itself will be a piece of plywood the same thickness as the vee berth deck, with a finger hole to allow an easy means of removing it. If you are careful and make straight cuts, the piece you remove from the deck will make a perfect fitting hatch, just add the finger hole. It will take a bit of upside down drilling and driving screws but with a 12x24 hatch there should be enough room.
All of my earlier sail boats used this type of hatch under the vee berth cushions, if I haven't explained it clearly enough a trip to a marina or boat dealer and a peek in the cabin under a cushion should show you what I am talking about. I used a DeWalt saber saw and it did a good job, but I went through half a dozen blades, the glass really ate them up.
Rich
Where, then, lies the answer? In Choice. Which shall it be: bankruptcy of purse or bankruptcy of life? In other words, buy the boat!
dutch123
Photos: Reel Action
PostPosted: Fri Nov 11, 2011 12:33 am    Post subject: Reply with quote
Thats a great idea rich thanks for that. Initially my concern was feeling the hatch under you when lying down but your advice will solve that problem and its the right price too. Once again the cbrats come through thanks again!
potter water
City/Region: Logan
C-Dory Year: 1997
Vessel Name: Poopsy
PostPosted: Fri Nov 11, 2011 10:10 am    Post subject: Inexpensive Reply with quote
But one would lose any possibility of flotation in that area of the boat with that type of cover. I will likely do the "loose lid" mod to my boat, but with a normal doggable hatch, flotation might still hang in there for a while in the event of something catastrophic. Something to think about. However, and this is a question; are there many sources for water to get into the under birth area if the boat is flooded? If so, how tight a hatch is in the v-berth is not an issue. Then, the loose cover method is really the way to go in my opinion.
Page 1 of 3
Page generation time: 0.191s (PHP: 86% - SQL: 14%) - SQL queries: 32 - GZIP disabled - Debug on
