Suzuki Periodic Maintenance Schedule
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Wed Nov 02, 2011 8:31 pm    Post subject: Suzuki Periodic Maintenance Schedule Reply with quote
This season i put 137 hours on my 1999 Suzuki DF 70 4 stroke and had the dealer winterize it last month. This brings the total hours on my motor to 478, when i bought this boat it had only 272 hours.I asked the dealer to perform the 400 hour maintenace check.What he did was:
change the engine oil
Change the gear oil
change the engine oil filter
fog and run and put stabilizer in the fuel
i am to replace the spark plugs in the Spring after i run the boat for a few hours
The maintenance chart says to replace the water pump impeller and other engine parts after so many hours or years of service but the mechanic said it wasn't necessary.I just wonder if he said this because they really are not a Suzuki dealer and do not have the parts on hand.
The mechanic said the motor runs and sounds great..basically don't touch it.
Next Spring should i take the boat to a Suzuki dealer ( about 125 miles away ) and have the 400 hours maintenace work done on my boat or just leave it until a problem comes up. Tug
PostPosted: Wed Nov 02, 2011 8:54 pm    Post subject: Reply with quote
Watch and DIY. Lots of $$ saved!
PostPosted: Wed Nov 02, 2011 9:20 pm    Post subject: Reply with quote
The question is has the impeller been changed? If not, it definitely needs it from just a time standpoint--especially when outboards are stored for some time the impeller takes a set--and is deformed when the engine is restarted in the spring. The rubber also disintegrates with time. If the engine is run in salt water, or areas where there is sand, it is best to change the impeller every 200 hours or 2 years. You can go longer if the engine is run year around, in fresh water and no sand etc....but at 400 hours I would certainly change it.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Wed Nov 02, 2011 9:37 pm    Post subject: Reply with quote
Sounds advice, it would be better to be safe than stranded miles away from the dock with a busted impeller or water pump. Will change it next Spring. Thanks Tug
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Thu Nov 03, 2011 12:04 pm    Post subject: Reply with quote
I agree that an impellor / water pump service is in order. The other reason is to be sure that the lower unit comes apart. If it's never been apart in over 10 years it may require some extra persuasion (cursing and flame wrench Angry ).
We have seen the Suzuki water pumps last a very long time, so it would not be unusual to get 10 years out of one- it's just not recomended.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Thu Nov 03, 2011 12:24 pm    Post subject: Reply with quote
I just got off the phone with the service mechanic in Espanola,Ontario and he basically said the same thing. He said to bring it in next Spring and they would do the 400 hr/waterpump/impellor service the same day so i can wait there. I didn't feel comfortable doing the job myself because if any problems/issues occur ( and most likely will ) there are no Suzuki parts available where i live and that would definitely mess things up. Tug
fishingmark
City/Region: Kelseyville
Vessel Name: c-yah
PostPosted: Thu Nov 03, 2011 8:59 pm    Post subject: Reply with quote
I have the susuki df70 on my 22' Angler when I bought the boat it had 270 hours on it and changed the empeller was very simple just go to I boat forums or purchase a susuki manual.
mmitchell
City/Region: Whittier
Vessel Name: ShiRoz
Photos: ShiRoz
PostPosted: Thu Nov 03, 2011 9:23 pm    Post subject: Reply with quote
One thing to check is your thermostat if it's run in salt water:)
Life is Good
25 C-Dory ShiRoz 2006-sold 2012
32 Trawler Adirondack 2012-
PostPosted: Thu Nov 03, 2011 9:24 pm    Post subject: Reply with quote
Ask the dealer if you can watch while the lower unit is dropped and the impeller changed. Some ABSOLUTELY won't allow that. I use a shop that allows me to participate in any service work being done. If you can do this, it will give you confidence that you can do much of the service work yourself down the road.
A friend with a motorcycle shop used to have a sign that read:
Service work - $50 per hour
If you watch - $75 per hour
If you help - $100 per hour
Wink
http://captnjim.blogspot.com/
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Fri Nov 04, 2011 9:14 am    Post subject: Impellor Reply with quote
If you buy the service manual for the engine you can do the work with some basic tools, patience, and of course following instructions carefully. The cost for someone else to do maintenance is so high it provides a good incentive to learn Very Happy
Anyway great that you plan to get it done. I found the process relatively straight forward on my DF150's. The weight of the lower unit and shaft was a bit of a surprise but you can use some props to help.
Captain Matt
Matt Gurnsey
Dealer
PostPosted: Fri Nov 04, 2011 11:52 am    Post subject: Reply with quote
If you've tried to fix it yourself- $150
Shocked
petemos
State or Province: NS
Vessel Name: C-You-Later
Photos: C-You-Later
PostPosted: Fri Nov 04, 2011 11:54 am    Post subject: Impeller Reply with quote
I did my Impeller this year also on an 115DF. It’s a 2007, but only has 90 hours of salt water use on it. The biggest pain was that I had to take my Permatrim off first, so I could remove all the lower unit bolts. I had used a generous amount of 3M 4200 on the Permatrim install, so it took me an hour or so to pry the Permatrim plate off, as I was afraid of cracking the lower unit plate.
Once off the rest was pretty simple, just take your time. I only did this job to see how much, if any corrosion I had on the interior bolts and shift linkage bar, as the pee stream was fine. It turned out the impeller and bolts were fine. The impeller and back plate look new and I’m going to keep them for a spare. The shift linkage bar had very little, but some corrosion where the parts connect to the units. Without the Permatrim issue, it’s about an 1.5 hour job taking your time and assuming you have all the right tools.
Lessons learned; don’t put too much 3M 4200 on the Permatrim install if you are going to be changes the impeller yourself. Also these Impellers will last a long time, so the real reason to do this job is to check that the bolts don’t seize, if your pee stream does not have any problems.
Here is a great link from another member on the process:
http://www.c-brats.com/viewtopic.php?t=12563&highlight=impeller
Here is also a video on the change on a 140, but it’s almost the same process.
http://www.youtube.com/watch?v=Mg23ZkyjXGI
Good luck.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Fri Nov 04, 2011 12:03 pm    Post subject: Reply with quote
matt and Jim ..i do have the 1999 2nd Edition Suzuki Service Manual for the DF 60/DF70 4 -stroke from the Suzuki Motor Corporation that came with the boat on purchase. I have been going over the manual and watching YouTude video's on replacing the waterpump/impeller for some time now. Looks do-able, can you buy waterpump/impeller kits on-line. Tug
petemos
Photos: C-You-Later
PostPosted: Fri Nov 04, 2011 12:08 pm    Post subject: Parts Reply with quote
I get my parts at browns Point marine as they are only 20 mins from my home. They seem to have good prices on Engine parts, but maybe not so great on other things. But no tax for you.
Here is there link:
http://store.brownspoint.com
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Fri Nov 04, 2011 1:10 pm    Post subject: Re: Parts Reply with quote
Here is there link:
Ditto - that where I buy mine as well. See the following link for a diagram. (I did not create this image - I found it online).
Page generation time: 0.1068s (PHP: 43% - SQL: 57%) - SQL queries: 32 - GZIP disabled - Debug on
