Scum line on Bottom Paint
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Mon Oct 03, 2011 3:26 pm    Post subject: Scum line on Bottom Paint Reply with quote
How do you remove the scum line on the boats' bottom paint. Once i tried just washing it off but that didn't work at all. Do you lightly sand the scum line off and than re-coat or just apply a new coat of bottom paint over the scum line. Thanks Tug
PostPosted: Mon Oct 03, 2011 3:34 pm    Post subject: Re: Scum line on Bottom Paint Reply with quote
I'd try a Scotch-Brite Pad used wet with water. Rub only as hard as necessary. Pressure might vary a lot with different types of bottom paint (different hardness).
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Mon Oct 03, 2011 3:50 pm    Post subject: Reply with quote
Assuming it's just discoloration and not an actual build up, try a compound like 3m color restorer. I ordered Starbrite hull cleaner online for that purpose (oxalic acid), but while I waited for that to arrive I realized it came off easily with a light compound. Starbrite is nice since it doesn't require any abrasives, but it's harmful to bottom paint and galvanized trailers, so it requires masking, tarps, etc.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Mon Oct 03, 2011 5:14 pm    Post subject: Reply with quote
Thanks for the information, will try that.Tug
PostPosted: Tue Oct 04, 2011 12:22 am    Post subject: Reply with quote
Use the scotch pad--not the starbrite (oxalic acid) hull cleaner or 3 M color restorer (that is for gel coat--not bottom paint. A lot depends on what bottom paint you have used. Many copper based paints oxidize and there will be a very pronounced line. That may not come out as well as a scum line. Also bottom paints like Vivid clean up very well with the pad.
ferret30
Photos: Lily Pad
PostPosted: Tue Oct 04, 2011 1:41 am    Post subject: Reply with quote
Oops, I thought we were talking about the scum line right above the bottom paint, not on the bottom paint itself. Sorry.
Page generation time: 0.085s (PHP: 48% - SQL: 52%) - SQL queries: 19 - GZIP disabled - Debug on
